I tried the Daikin aircon /HVAC widget by copying the code to a new widget.
But when i try to save the code, the content of the code is alternated.
Some lines are deleted or parts of the line is missing.
I tried it with multiple widgets code from the widget marketplace.
Same result.
Do i do something wrong?
Is my “widget” file corrupt?
Rest of my OH 3.3.0 is working fine only widgets give me problems.
Best course of action would be to contact the creator of the widget and ask them to add the proper tags (published) to the post to get the widget to appear in the regular marketplace.
However, you can still get to it because it is in the marketplace category even if it doesn’t have the proper tags. You can go to your settings and click on Community Marketplace under the system settings. There you check the option for “Show unpublished entries” and save the setting. Then you’ll be able to see all the widgets that don’t have the published tag as well (including the Daikin widget).
That said, you are correct that copy-pasting the entry should also work, and I just tested it and it does work just fine for me. This means that it has something to do with the system that you are copy-pasting with. Did you highlight all the code manually or did you click on the copy button in the upper right-hand corner of the code frame?
