Daikin Aircon / HVAC
Let me share with you a widget specifically for Daikin HVAC systems in “dark mode” with a few additonal options.
(I tried to give it a similar look as the OH3 widget: Grafana chart with time ranges.)
I used the Intensis aircon controller developed by @hmerk as a starting point.
Thank you for the great work!
@RGroll supported me with the functionality to hide/unhide rows by clicking on buttons or toggle switches in props. Thank you so much!
The widget supports the following features:
  • Switch HVAC ON/OFF
  • Set target temperature
  • Show Indoor/Outdoor temperature
  • Set Mode (Auto/Cool/Heat…)
  • Set fan speed via option button
  • Set fan swing via option button
Additional options can be activated via props:
  • Enable timer function (e.g. to switch on “cooling” for 30min)
  • Show power generated from solar plant / photovoltaic system
daikin_1
Open topics:
  • UoM (°C) missing on the oh-knob
    this is not supported yet, I think. Am I right?
  • The text on the buttons below the icons is not centered, whereas the icons (I believe) are.
    Any idea how to solve that?
Resources
YAML (updated on 2021-03-09 with optimized code and compatibility for dark & light-theme):
uid: Daikin HVAC
tags: []
props:
  parameters:
    - description: Location (room) or device name
      label: Title
      required: false
      type: TEXT
    - context: item
      description: Item for power channel
      label: Power
      required: false
      type: TEXT
    - context: item
      description: Item for indoor temperature channel
      label: Indoor temperature
      required: false
      type: TEXT
    - context: item
      description: Item for outdoor temperature channel
      label: Outdoor temperature
      required: false
      type: TEXT
    - context: item
      description: Item for target temperature channel
      label: Target temperature
      required: false
      type: TEXT
    - description: Set minimum target temperature (default = 0)
      label: Minimum Temperature
      required: false
      type: INTEGER
    - description: Set maximum target temperature (default = 100)
      label: Maximum Temperature
      required: false
      type: INTEGER
    - description: Set Target Temperature Stepsize (default = 1)
      label: Target Temperature Stepsize
      required: false
      type: DECIMAL
    - context: item
      description: Item for operation mode channel
      label: Operation mode
      required: false
      type: TEXT
    - context: item
      description: Item for fan speed channel
      label: Fan speed
      required: false
      type: TEXT
    - context: item
      description: Item for swing channel
      label: Swing mode
      required: false
      type: TEXT
    - description: Hide timer button and options
      label: Hide Timer Function
      required: false
      type: BOOLEAN
    - context: item
      description: Switch item for timer
      label: Switch Timer ON/OFF
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Item for timer duration
      label: Timer Duration
      required: false
      type: TEXT
      advanced: true
    - description: Timer minimum duration
      label: Timer minimum
      required: false
      type: DECIMAL
      advanced: true
    - description: Timer maximum duration
      label: Timer maximum
      required: false
      type: DECIMAL
      advanced: true
    - description: Timer step
      label: Timer step
      required: false
      type: DECIMAL
      advanced: true
    - description: Timer scale steps
      label: Timer scale steps
      required: false
      type: DECIMAL
      advanced: true
    - description: Timer scale sub steps
      label: Timer scale sub steps
      required: false
      type: DECIMAL
      advanced: true
    - description: Hide solarplant power
      label: Hide Solarplant AC power measurement
      required: false
      type: BOOLEAN
    - context: item
      description: AC Power item for solarplant
      label: Solarplant AC Power
      required: false
      type: TEXT
      advanced: true
  parameterGroups: []
timestamp: Mar 8, 2021, 7:41:03 PM
component: f7-card
  title: =props.title
  outline: true
  class:
    - no-padding
slots:
  default:
    - component: f7-row
        class:
          - margin-top-half
          - margin-left-half
          - margin-right-half
          - margin-bottom
      slots:
        default:
          - component: f7-col
              width: "50"
              large: "33"
            slots:
              default:
                - component: f7-segmented
                    class:
                      - segmented-strong
                    style:
                      --f7-segmented-strong-padding: 0px
                      --f7-segmented-strong-between-buttons: 5px
                      --f7-segmented-strong-button-font-weight: 300
                      --f7-segmented-strong-bg-color: transparent
                      --f7-segmented-strong-button-hover-bg-color: rgba(var(--f7-theme-color-rgb), 0.07)
                      --f7-button-fill-hover-bg-color: var(--f7-theme-color)
                      --f7-button-border-radius: 4px
                      --f7-button-padding-vertical: 0px
                      --f7-button-padding-horizontal: 0px
                  slots:
                    default:
                      - component: oh-button
                          outline: true
                          class:
                            - padding-top-half
                            - display-flex
                            - flex-direction-column
                          text: ON/OFF
                          action: toggle
                          actionItem: =props.itemPower
                          actionCommand: ON
                          actionCommandAlt: OFF
                          icon-f7: power
                          iconSize: 15
                          fill: "=(items[props.itemPower].state === 'ON') ? true : false"
                          style:
                            --f7-button-border-width: 1px
                            --f7-button-border-color: var(--f7-card-outline-border-color)
                            height: auto
                            font-size: 8px
                          visible: =!props.hideTimerFunction
                          text: TIMER
                          action: toggle
                          actionItem: =props.itemTimerSwitch
                          actionCommand: ON
                          iconF7: timer
                          iconSize: 15px
                          fill: "=(items.ac_timer_on_off.state === 'ON') ? true : false"
                          outline: false
                          class:
                            - display-flex
                            - padding-top-half
                          style:
                            font-size: 8px
                            height: auto
          - component: f7-col
              width: "33"
            slots:
              default:
                - component: f7-row
                    class:
                      - padding-right-half
                  slots:
                    default:
                      - component: f7-col
                          width: "25"
                        slots:
                          default:
                            - component: f7-icon
                                class:
                                  - float-right
                                f7: house
                      - component: f7-col
                          width: "75"
                        slots:
                          default:
                            - component: Label
                                class:
                                  - float-right
                                text: =items[props.itemIndoorTemp].state
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  text-overflow: elipsis
                                  font-size: 12px
                - component: f7-row
                    class:
                  slots:
                    default:
                      - component: f7-col
                          width: "25"
                        slots:
                          default:
                                class:
                                  - float-right
                                f7: tree
                      - component: f7-col
                          width: "75"
                        slots:
                          default:
                            - component: Label
                                class:
                                  - float-right
                                text: =items[props.itemOutdoorTemp].state
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: 12px
                - component: f7-row
                    visible: =!props.hideSolarplant
                    class:
                  slots:
                    default:
                      - component: f7-col
                          width: "25"
                        slots:
                          default:
                                class:
                                  - float-right
                                f7: sun_max
                      - component: f7-col
                          width: "75"
                        slots:
                          default:
                            - component: Label
                                class:
                                  - float-right
                                text: =items[props.itemSolarplantACPower].state
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: 12px
    - component: f7-row
        class:
          - justify-content-center
      slots:
        default:
          - component: oh-knob
              item: =props.itemTargetTemp
              min: =props.MinimumTemperature
              max: =props.MaximumTemperature
              stepSize: =props.TemperatureStepsize
              secondaryColor: var(--f7-card-outline-border-color)
              primaryColor: var(--f7-theme-color)
              responsive: false
              strokeWidth: "12"
        visible: true
        class:
          - margin-left-half
          - margin-right-half
          - margin-top
          - margin-bottom-half
        style:
          --f7-button-font-size: 8px
          --f7-button-text-color: "=themeOptions.dark === 'light' ? 'black' : 'white'"
          --f7-button-outline-border-width: 1px
          --f7-button-font-weight: 300
      slots:
        default:
          - component: oh-repeater
              sourceType: array
              for: modeRow
              in:
                - icon: arrow_2_squarepath
                  command: AUTO
                  text: AUTO
                - icon: thermometer_snowflake
                  command: COLD
                  text: COOL
                - icon: thermometer_sun
                  command: HEAT
                  text: HEAT
                - icon: drop_fill
                  command: DEHUMIDIFIER
                  text: DRY
                - icon: wind
                  command: FAN
                  text: FAN
              fragment: true
            slots:
              default:
                    iconF7: =loop.modeRow.icon
                    iconSize: 15px
                    fill: "=(items[props.itemMode].state === loop.modeRow.command) ? true : false"
                    outline: true
                    class:
                      - display-flex
                      - padding-top-half
                    style:
                      height: auto
                    text: =loop.modeRow.text
                    action: command
                    actionItem: =props.itemMode
                    actionCommand: =loop.modeRow.command
              iconF7: ellipsis_vertical
              iconSize: 15px
              action: variable
              actionVariable: options
              actionVariableValue: "=vars.options || vars.options === undefined ? false : true"
              fill: "=vars.options || vars.options === undefined ? false : true"
              outline: true
              class:
                - display-flex
              style:
                height: auto
                width: 50%
        visible: =vars.options === false
        class:
          - margin-left-half
          - margin-right-half
          - margin-top
        style:
      slots:
        default:
              sourceType: array
              for: optionsRow
              in:
                - icon: wind ellipsis_vertical
                  option: fanspeed
                - icon: move ellipsis_vertical
                  option: swing
              fragment: true
            slots:
              default:
                    iconF7: =loop.optionsRow.icon
                    iconSize: 15px
                    fill: "=vars[loop.optionsRow.option] || vars[loop.optionsRow.option] === undefined ? false : true"
                    outline: true
                    class:
                      - display-flex
                    style:
                      height: auto
                    action: variable
                    actionVariable: =loop.optionsRow.option
                    actionVariableValue: "=vars[loop.optionsRow.option] || vars[loop.optionsRow.option] === undefined ? false : true"
              action: variable
              actionVariable: timer_menu
              actionVariableValue: "=vars.timer_menu || vars.timer_menu === undefined ? false : true"
              fill: "=vars.timer_menu || vars.timer_menu === undefined ? false : true"
              iconF7: timer ellipsis_vertical
              iconSize: 15px
              outline: true
              style:
        visible: "=vars.fanspeed === false && vars.options === false ? true : false"
        class:
          - margin-left-half
          - margin-right-half
          - margin-top
        style:
      slots:
        default:
              sourceType: array
              for: fanspeedRow
              in:
                  command: AUTO
                - icon: zzz
                  command: SILENCE
                - command: LEVEL_1
                  text: 1
                - command: LEVEL_2
                  text: 2
                - command: LEVEL_3
                  text: 3
                - command: LEVEL_4
                  text: 4
                - command: LEVEL_5
                  text: 5
              fragment: true
            slots:
              default:
                    iconF7: =loop.fanspeedRow.icon
                    iconSize: 15px
                    fill: "=(items[props.itemFanSpeed].state === loop.fanspeedRow.command) ? true : false"
                    outline: true
                    class:
                      - display-flex
                    style:
                      height: auto
                    text: =loop.fanspeedRow.text
                    action: command
                    actionItem: =props.itemFanSpeed
                    actionCommand: =loop.fanspeedRow.command
        visible: "=vars.swing === false && vars.options === false ? true : false"
        class:
          - margin-left-half
          - margin-right-half
          - margin-top
        style:
      slots:
        default:
              sourceType: array
              for: swingRow
              in:
                - command: STOPPED
                  text: OFF
                - icon: resize_v
                  command: VERTICAL
                - icon: resize_h
                  command: HORIZONTAL
                - icon: view_3d
                  command: VERTICAL_AND_HORIZONTAL
              fragment: true
            slots:
              default:
                    iconF7: =loop.swingRow.icon
                    iconSize: 15px
                    fill: "=(items[props.itemSwing].state === loop.swingRow.command) ? true : false"
                    outline: true
                    class:
                      - display-flex
                    style:
                      height: auto
                    text: =loop.swingRow.text
                    action: command
                    actionItem: =props.itemSwing
                    actionCommand: =loop.swingRow.command
    - component: f7-row
        visible: "=vars.timer_menu === false && vars.options === false && !props.hideTimerFunction === true ? true : false"
        class:
          - margin-left-half
          - margin-right-half
      slots:
        default:
          - component: f7-col
            slots:
              default:
                - component: oh-slider-card
                    outline: true
                    item: =props.itemTimerDuration
                    min: =props.TimerMinimum
                    max: =props.TimerMaximum
                    step: =props.TimerStep
                    scaleSteps: =props.TimerScaleSteps
                    scaleSubSteps: =props.TimerScaleSubSteps
                    scale: true
                    unit: min
                    label: true
Hope some of you find it useful :slightly_smiling_face:
Hey @maxmaximax
nice work!
Sadly, theres no easy way to remove the margin-left on the text, as its hardcoded. The elements would normaly be aligned in a row instead of a column so this margin serves the purpose of bringing some space between the text and the icon.
You could recreate the button mechanic with blocks and a overlaying action-component like oh-link or oh-button, but I’m not sure if it’s worth the effort.
Some other things that I recognized here which you might like to check:
  • Most of the elements are designed to work in the dark-theme and have hardoced color styles. Either you could make them dependant on the used theme or leave some of the values at their default styling settings to let the framework do the work for you. This would make this widget also usable for the light-theme.
  • You used lots of repeating styles on the button-components. Most of them could be assigned to the surrounding elements and would inherit to it’s childs - you would save a lot of lines that way.
  • The actionCommand on your oh-buttons has a leading = - this isn’t necessary IMHO as this is no expression.
  • Another possibility to save a lot of code and make adjustments way easier would be to use the oh-repeater component. To give you a rough understanding of how this could work in your widget, I attached a small example of the bottom-row:
         visible: true
         class:
           - margin-left-half
           - margin-right-half
           - margin-top
         style:
           --f7-button-text-color: white
           --f7-theme-color: rgba(255,255,255,.15)
           --f7-button-text-transform: none
       slots:
         default:
               sourceType: array
               for: bottomRow
               in:
                   command: AUTO
                   command: COLD
                   command: HEAT
                 - icon: drop_fill
                 - icon: wind
                   command: FAN
               fragment: true
             slots:
               default:
                     iconF7: =loop.bottomRow.icon
                     iconSize: 15px
                     fill: "=(items[props.itemMode].state === loop.bottomRow.command) ? true : false"
                     outline: true
                     class:
                       - display-flex
                       - padding-top-half
                     style:
                       height: auto
                       width: =loop.bottomRow.width
                     text: =loop.bottomRow.command
                     action: command
                     actionCommand: =loop.bottomRow.command
               iconSize: 15px
               action: variable
               outline: true
               class:
                 - display-flex
               style:
                 height: auto
                 width: 50%
Keep up the good work!
Hey @RGroll
thanks a lot for your helpful remarks…
I’m on my way optimizing the code with oh-repeater and avoiding repeating styles - already saved more than 200 lines :slightly_smiling_face:
Also trying to improve for dark/light-theme compatibility.
It seems I need to make some color styles dependent on the used dark/light-theme.
What would be right code for below example?
     style:
There is some strange effect for the button border color.
     style:
       --f7-button-border-color: rgba(255,255,255,.15)
In dark-theme the borders are visible - in light-theme no borders visible.
Why is that?
Hey @maxmaximax
Glad to hear!
Something like this would work:
style:
The rgba values 255,255,255,.15 stands for white with an opacity of 15% - white on white isn’t easy to see. :wink:
You could use the same mechanic as above here:
style:
  --f7-button-border-color: "=themeOptions.dark === 'light' ? 'rgba(255,255,255,.15)' : 'rgba(0,0,0,.15)'"
Hey @RGroll
This works perfectly well !
Thanks !
This makes quite some sense… :sweat_smile:
Here I would prefer to use exactly the same colors as the outline of the f7-cards.
What would be the best way to refer to the colors in dark/light-theme?
… alternatively hardcoding both colors, if I knew the codes …
Thank you.
I don’t think that the f7-card is using any borders - theres just this box-shadow --f7-card-box-shadow: 0px 1px 2px rgba(0,0,0,0.15), which isn’t visible in the dark theme.
What you could do, is using the color of the line between the header and the content area and let the framework do the work for you:
--f7-button-border-color: var(--f7-card-header-border-color)
Hey @RGroll
Your idea got me there - I found a style for “card outline” for the framework - I used that one instead:
style:
and - I updated the code in the first post with the optimized code.
Thanks a lot !
Hmm didn’t saw that style in the dev tools - so obviously there is some border present at the f7-card component.
Glad, you found a way, that works for you!
Yes, the border = outline of every “card” can be switched on when you configure the widget:
i am struggling how to combine this mechanics with the following background color condition:
  style:
    background-color: '=(items[props.item].state === "OFF") ? "rgba(228,228,228,0.9)" : "white"'
i tried all kind of versions with the expression tester but this did not work out. What i want to achieve is:
  1. if themeOption.dark is “light”, then the above condtion should work, ( OFF= rgba, ON= white ), but when the themeOption.dark is “dark”, then the backgroud should be set to different colors e.g. ( OFF= black, ON = yellow )
Thank for some guidance here!
Hey @muelli1967
it would work like this for example:
background-color: "=themeOptions.dark === 'light' && items[props.item].state === 'ON' ? 'white' : themeOptions.dark === 'light' && items[props.item].state === 'OFF' ? 'rgba(228,228,228,0.9)' : themeOptions.dark === 'dark' && items[props.item].state === 'ON' ? 'yellow' : 'black'"
There are ways to make this conditional statment shorter but this is easier to understand for now, I think.
thanks, Rainer! This works as expected. Much appreciated. I guess i was on a too complex path. :slight_smile:
For using " or in these kind of expressions it does not seem to matter as long as you are consistent or is there any condition to take into consideration?
Exactly you could use whatever you like the most (if you are consistent) within the expression afaik.
Hi Rainer @RGroll , i seem to struggle with the " or ’ in such expressions. For the background image of an OH3 page, i have tried following:
  style:
    background-image: "=themeOptions.dark === 'dark' ? '#d6ab00' :  'url('/static/images/Wallpapers/hk-Office1.jpg')'"
unfortunately this does not work and i suspect that the ’ from inside the url () are preventing from success. I tried to rework everything to:
background-image: '=themeOptions.dark === "dark" ? "#d6ab00" : "url('/static/images/Wallpapers/hk-Office1.jpg')"'
this works in the widget expression tester but throws an error in the code of the site.
background-image: can’t handle color values like rgb, hsl, hex or whatever, so you have to use background: here. See https://www.w3schools.com/cssref/pr_background-image.asp
Correct, you can escape these characters with \\:
background: "=themeOptions.dark === 'dark' ? '#d6ab00' : 'url(\\'/static/images/Wallpapers/hk-Office1.jpg\\')'"
Hi Rainer,
i re-worked it according to your suggestions and also have removed the color values with another background but this does not seem to work yet, neither wiht background-image nor on background.
It is a background for a page. i want to change the background with dark / light theme.
  label: Büro
  sidebar: true
  style:
    background-image: "=themeOptions.dark === 'dark' ? 'url(\\'/static/images/Wallpapers/hk-Office1bw.jpg'\\)' : 'url(\\'/static/images/Wallpapers/hk-Office1.jpg'\\)'"
I am sure i miss something here. It still shows no background with these lines.
You’ve set the escape characters at the wrong place - the’ve to be in front of the char you want to escape, so it would be:
background-image: "=themeOptions.dark === 'dark' ? 'url(\\'/static/images/Wallpapers/hk-Office1bw.jpg\\')' : 'url(\\'/static/images/Wallpapers/hk-Office1.jpg\\')'"
yes, you are right. Hmm, still does not work…
working is this one:
  style:
    background-image: url('/static/images/Wallpapers/hk-Office1bw.jpg')
not working:
  style:
    background-image: url(\\'/static/images/Wallpapers/hk-Office1bw.jpg\\')
not working:
  label: Büro
  sidebar: true
  style:
    background-position: center;
    background-repeat: no-repeat;
    background-size: cover
Try:
background-image: "=themeOptions.dark === 'dark' ? 'url(/static/images/Wallpapers/hk-Office1bw.jpg)' : 'url(/static/images/Wallpapers/hk-Office1.jpg)'"
Don’t use semicolon in styles
still does not work :frowning: . I attach a screenshot this time )
this works:
  label: Büro
  sidebar: true
  style:
    background-image: url(/static/images/Wallpapers/hk-Office1.jpg)
