I doubt it. Maybe if you host your own openHAB Cloud instance and change the code to allow it. Since it has to send an email to activate the account I doubt you can use anything but a valid email address to get an account set up.
@markus7017 and @rlkoshak I have successfully used the binding with MyOpenHAB.org and am able to see events coming in from Rachio via the MyOpenHAB.org proxy.
It took a bug fix on the Rachio end to handle ā@ā in the usernames in webhook Uriās and they fixed that already.
@markus7017 if you dont mind i would like to tidy up the binding and remove a bunch of the code to do with IP range checking etcā¦ I think it would be far simpler to adjust the setup docs etcā¦ to show people how to use MyOpenHAB.org for this. It is very simple to setup. I would also like to PR some more suggestions to bring the binding up to spec on the new conventions and discovery service system. Iāll submit a PR in the next day or two when complete.
This is really exciting! no more proxy or port forwarding or NGINX needed
For anyone interested in trying this new version out using MyOpenHab.org to proxy events from Rachio vs. opening ports etcā¦ here is a jar:
good news. Iāll look into that next week, pretty busy at the moment. There is cleanup and some re-factoring required to make it Review-ready. Maybe we could bring it in into 2.5.7/2.5.8
Did you created the PR to my repo?
Ah. I forked markus7017/org.openhab.binding.rachio. Iāll fork your openhab-addons repo and PR to there.
@markus7017 ok i forked the wrong repo and it looks like you have made quite a few changes since then, so i will have some work to do to merge my changes. ill work on that and get you a PR soon.
@markus7017 would you mind rebasing your repo on 2.5.X? There are changes to bring it up to 2.5.6 and i rebased my local branch in order to get those. My PR would be pretty big if it included all those.
ok, rebase to 2.5.6 is done and changes are pushed
Your PR has 7 conflicting files and 4.700 lines of code changed.
Did you rebased your fork before creating the PR?
@markus7017 yeah I rebased. not sure why its showing that much of a diff. I didnt change that much code. Iāll take another look.
done. PR should be a bit better now
Iāve installed the 2.5.6 binding from post 303 into my test system. I enabled debug logging and then trace logging later on. My cloud bridge comes online with seemingly no issues. Based on the trace, itās getting the JSON for all of the zones and the device. Unfortunately, nothing is showing up in the inbox to add for either. I was able to add it via text file and the things did come online.
For anyone reading this, because I couldnāt find it when searching through, the XXXXXXXX in the things file for device and zone is the mac address of the Rachio itself.
To note, I have my own reverse proxy already that Iāll be using instead of myopenhab.org for this setup.
There seems to be an API issue with the running and stopping of zones. When I send ON to run the zone I get an HTTP 429 error. When I hit stop, I get the same error, but it resets the run item back to ON. To note, the zone never actually activates. Iāll attempt to post logs when Iām not on a phone.
you need to manually add an Account Thing and then run the discovery. This will create the controller and zone entries in the Inbox
I did. I added the bridge and it came online. When I clicked the scan button at the top on paperui, Rachio does not display as something to force a discovery. I could however see everything when I run trace level logging when I restarted OH.
Log messages Iām getting:
2020-06-28 09:26:22.911 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Starting zone 'Backyard North [6]' for 0 secs
2020-06-28 09:26:23.186 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0
2020-06-28 09:26:38.015 [WARN ] [g.rachio.handler.RachioBridgeHandler] - RachioBridge: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/person/REDACTED, GET https://api.rach.io/1/public/person/REDACTED, http code=0
2020-06-28 09:26:50.164 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Stop watering for the device
2020-06-28 09:26:50.421 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:26:55.388 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Starting zone 'Backyard South [5]' for 0 secs
2020-06-28 09:26:55.649 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0
2020-06-28 09:27:08.183 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Stop watering for the device
2020-06-28 09:27:08.439 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:27:17.801 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Stop watering for the device
2020-06-28 09:27:18.063 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:27:38.264 [WARN ] [g.rachio.handler.RachioBridgeHandler] - RachioBridge: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/person/REDACTED, GET https://api.rach.io/1/public/person/REDACTED, http code=0
2020-06-28 09:27:50.175 [INFO ] [ing.rachio.handler.RachioZoneHandler] - RachioZone: Stop watering for the device
2020-06-28 09:27:50.417 [WARN ] [ing.rachio.handler.RachioZoneHandler] - RachioZoneHandler: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:26:22.905 [ome.event.ItemCommandEvent] - Item 'RachioZone6_Run' received command ON
2020-06-28 09:26:22.911 [nt.ItemStatePredictedEvent] - RachioZone6_Run predicted to become ON
2020-06-28 09:26:22.916 [vent.ItemStateChangedEvent] - RachioZone6_Run changed from OFF to ON
2020-06-28 09:26:23.186 [hingStatusInfoChangedEvent] - 'rachio:zone:1:REDACTED-6' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0
2020-06-28 09:26:50.163 [ome.event.ItemCommandEvent] - Item 'RachioZone6_Run' received command OFF
2020-06-28 09:26:50.164 [nt.ItemStatePredictedEvent] - RachioZone6_Run predicted to become ON
2020-06-28 09:26:50.421 [hingStatusInfoChangedEvent] - 'rachio:zone:1:REDACTED-6' changed from OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0 to OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:26:55.378 [ome.event.ItemCommandEvent] - Item 'RachioZone5_Run' received command ON
2020-06-28 09:26:55.388 [nt.ItemStatePredictedEvent] - RachioZone5_Run predicted to become ON
2020-06-28 09:26:55.398 [vent.ItemStateChangedEvent] - RachioZone5_Run changed from OFF to ON
2020-06-28 09:26:55.650 [hingStatusInfoChangedEvent] - 'rachio:zone:1:REDACTED-5' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0
2020-06-28 09:27:08.182 [ome.event.ItemCommandEvent] - Item 'RachioZone5_Run' received command OFF
2020-06-28 09:27:08.182 [nt.ItemStatePredictedEvent] - RachioZone5_Run predicted to become ON
2020-06-28 09:27:08.439 [hingStatusInfoChangedEvent] - 'rachio:zone:1:REDACTED-5' changed from OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0 to OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/device/stop_water, PUT https://api.rach.io/1/public/device/stop_water, http code=0
2020-06-28 09:27:17.800 [ome.event.ItemCommandEvent] - Item 'RachioZone5_Run' received command OFF
2020-06-28 09:27:17.800 [nt.ItemStatePredictedEvent] - RachioZone5_Run predicted to become ON
2020-06-28 09:27:50.174 [ome.event.ItemCommandEvent] - Item 'RachioZone5_Run' received command OFF
2020-06-28 09:27:50.174 [nt.ItemStatePredictedEvent] - RachioZone5_Run predicted to become ON
2020-06-28 09:32:32.175 [ome.event.ItemCommandEvent] - Item 'RachioZone5_Run' received command OFF
2020-06-28 09:32:32.175 [nt.ItemStatePredictedEvent] - RachioZone5_Run predicted to become ON
2020-06-28 09:32:51.245 [ome.event.ItemCommandEvent] - Item 'RachioZone4_Run' received command ON
2020-06-28 09:32:51.265 [nt.ItemStatePredictedEvent] - RachioZone4_Run predicted to become ON
2020-06-28 09:32:51.266 [vent.ItemStateChangedEvent] - RachioZone4_Run changed from OFF to ON
2020-06-28 09:32:51.509 [hingStatusInfoChangedEvent] - 'rachio:zone:1:REDACTED-4' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/zone/start, PUT https://api.rach.io/1/public/zone/start, http code=0
Iām not sure what has changed but my cloud connector bridge is refusing to come online for the past day or so. Iāve restarted OH a few times and it doesnāt seem to fix anything.
2020-07-03 16:54:38.959 [DEBUG] [g.rachio.handler.RachioBridgeHandler] - RachioBridge: Connecting to Rachio cloud
2020-07-03 16:54:38.959 [TRACE] [nding.rachio.internal.api.RachioHttp] - RachioHttp[Call #1]: Call Rachio cloud service: GET 'https://api.rach.io/1/public/person/info')
2020-07-03 16:54:39.225 [WARN ] [g.rachio.handler.RachioBridgeHandler] - RachioBridge: Exception: {0} (Server returned HTTP response code: 429 for URL: https://api.rach.io/1/public/person/info, GET https://api.rach.io/1/public/person/info, http code=0
