Radio Browser Basic Widget for finding internet radio streams with the UI
This widget is designed to make using the new binding called Radio Browser very easy and will start/send the streams the binding finds, to your Chromecast or other devices like Squeezebox that can accept a URL sent as a command. Please feel free to copy and adjust the code as much as you like to make nicer looking versions for a stand alone widget. Love to see what people come up with if you can post the code and images.
Show Your Thanks
If you enjoy the binding and/or widget, then please consider sponsoring or giving a once off tip as a thank you via the links.
Sponsor @Skinah on GitHub
https://github.com/sponsors/Skinah/
Paypal can also be used via
matt A-T pcmus D-O-T C-O-M
Setup
  1. Install the Radio Browser binding from the marketplace and add a radio thing.
  2. If not already done, setup an item for the Play URI channel from any Chromecast, or the stream channel from a Squeezebox. You may need to click show advanced to see the channel.
  3. Use the add equipment from thing feature to create an equipment and all the items for you from the main UI. This is to ensure all the items are named correctly for this widget to auto setup based from 1 equipment group.
  4. Install this widget and setup the items using the radio thing’s equipment group item.
  5. Start using the widget and enjoy tons of internet streams from around the world.
Some stations will block you from streaming if your not in the same country.
Screenshots
Resources
uid: Radio_Browser_Basic
tags:
  - multimedia
props:
  parameters:
    - context: item
      description: Select the Radio Browser you wish to use at an equipment item level
      label: Select Radio Browser
      required: true
      type: TEXT
      filterCriteria:
        - value: Group
    - context: item
      description: Select Chromecast_PlayURI or Sqeezebox_Stream Item to send the radio URL.
      label: Chromecast_PlayURI or Sqeezebox_Stream
      required: true
      type: TEXT
      filterCriteria:
        - value: String
    - context: item
      description: Select the volume control item
      label: Volume Item
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Feb 21, 2024, 9:37:22 PM
component: oh-list-card
  accordionList: true
  colorTheme: "=themeOptions.dark === 'dark' ? 'gray' : 'black'"
  outline: true
  style:
    border: none
    margin: none
    padding: none
slots:
  default:
    - component: oh-list-item
        accordionItemOpened: false
        accordionList: true
        after: =`Show/Hide Controls`
        mediaItem: true
        style:
          border: none
          margin: none
          padding: none
        title: Radio Browser
      slots:
        accordion:
            slots:
              default:
                - component: f7-row
                  slots:
                    default:
                      - component: f7-col
                          style:
                            padding: 0px
                            padding-left: 0%
                            padding-right: 0%
                            width: 20%
                        slots:
                          default:
                            - component: oh-image
                                item: =props.radioBrowser+'_Icon'
                                style:
                                  border: 0px
                                  border-radius: 6px
                                  margin: 0px
                                  padding: 0px
                                  width: 108%
                      - component: f7-col
                          style:
                            - width: 80%
                        slots:
                          default:
                            - component: f7-row
                                class:
                                  - justify-content-left
                                style:
                                  border: none
                                  margin: none
                                  padding: none
                              slots:
                                default:
                                  - component: oh-button
                                      action: options
                                      actionItem: =props.radioBrowser+'_Country'
                                      iconF7: globe
                                      text: "=(items[props.radioBrowser+'_Country'].state === 'ALL') ? 'Country' : items[props.radioBrowser+'_Country'].state"
                                      action: options
                                      actionItem: =props.radioBrowser+'_State'
                                      iconF7: globe
                                      text: "=(items[props.radioBrowser+'_State'].state === '' ) ? 'State' : items[props.radioBrowser+'_State'].state"
                                      action: options
                                      actionItem: =props.radioBrowser+'_Genre'
                                      iconF7: music_note_list
                                      text: "=(items[props.radioBrowser+'_Genre'].state === 'ALL' || items[props.radioBrowser+'_Genre'].state === '' ) ? 'Genre' : items[props.radioBrowser+'_Genre'].state"
                            - component: f7-row
                                class:
                                style:
                                  margin: none
                                  padding: none
                                  padding-left: 10px
                                  padding-right: 0px
                              slots:
                                default:
                                      action: variable
                                      actionVariable: showVolume
                                      actionVariableValue: =!(vars.showVolume === true)
                                      color: "=(vars.showVolume) ? 'blue' : 'gray'"
                                      iconF7: '=(Number.parseInt(items[props.volume].state) >= 75) ? "speaker_3_fill" : (Number.parseInt(items[props.volume].state) > 50) ? "speaker_2_fill" : (Number.parseInt(items[props.volume].state) > 10) ? "speaker_1_fill" : (Number.parseInt(items[props.volume].state) > 0) ? "speaker_fill" : (Number.parseInt(items[props.volume].state) == 0) ? "speaker_slash_fill" :"speaker_slash_fill"'
                                      iconSize: 20
                                      style:
                                        padding: 0px
                                      visible: =(props.volume !== UNDEF)
                                      action: command
                                      actionCommand: "=(items[props.playURI].state === items[props.radioBrowser+'_Stream'].state ) ? ' ' : items[props.radioBrowser+'_Stream'].state "
                                      actionItem: =props.playURI
                                      iconF7: playpause_fill
                                      iconSize: 20
                                      style:
                                        padding: 0px
                                      action: options
                                      actionItem: =props.radioBrowser+'_Recent'
                                      iconF7: music_albums
                                      iconSize: 20
                                      style:
                                        padding: 0px
                                      action: variable
                                      actionVariable: showSearch
                                      actionVariableValue: =!(vars.showSearch === true)
                                      color: "=(vars.showSearch) ? 'blue' : 'gray'"
                                      iconF7: search
                                      iconSize: 20
                                      style:
                                        padding: 0px
                                      action: options
                                      actionItem: =props.radioBrowser+'_Language'
                                      iconF7: chat_bubble_text
                                      text: "=(items[props.radioBrowser+'_Language'].state === 'ALL' || items[props.radioBrowser+'_Language'].state === '' ) ? 'Language' : items[props.radioBrowser+'_Language'].state"
                            - component: f7-row
                                style:
                                  border: none
                                  margin: none
                                  margin-right: 6px
                                  padding: none
                                  padding-left: 2px
                                  padding-right: 0px
                              slots:
                                default:
                                      action: options
                                      actionItem: =props.radioBrowser+'_Station'
                                      iconF7: antenna_radiowaves_left_right
                                      text: =items[props.radioBrowser+'_Station'].state
                - component: oh-slider
                    color: blue
                    item: =props.volume
                    style:
                      margin-left: 10px
                      margin-top: 0px
                      width: 95%
                    visible: =(props.volume !== UNDEF && vars.showVolume === true)
                - component: oh-input
                    clearButton: true
                    inputmode: text
                    item: =props.radioBrowser+'_Station'
                    outline: true
                    placeholder: Enter your search here, then press the tick.
                    sendButton: true
                    type: text
                    visible: =(vars.showSearch === true)
Would love to hear back from users, how well this widget and binding work when used with the following bindings that have the ability to stream URI’s. I use the Chromecast binding, but what about these other ones, are anyone using it without issues with these?
Squeezebox - Bindings
This binding has the channel stream that the widget should work with.
Volumio - Bindings
This binding has the channel play-uri that the widget should work with.
Denon HEOS - Bindings
This binding has the channel PlayUrl that the widget should work with.
Kodi - Bindings
This binding has the channel playuri that the widget should work with.
Sonos - Bindings
I don’t use your widget, but I send the stream url to squeezebox per rules DSL..
it’s working fine..
Greets
