I bought the module and installed it in my raspi. I managed to install the deCONZ software 2.04.35 from Dresden Elektronik. But i have no idea what to do next and how to bind this module to OH2 and start connecting my sensors.
I don’t have a lot of specifics to provide. But I can say that the Zigbee binding is not yet complete. I think there is a pre-alpha version of the binding available. You can find its initial checkin here. I do know it is only able to support one controller but I don’t know what one it is.
The binding might be available on the IoT Marketplace but you will need to install the snapshot to get access to that.
I bought some Dresden raspBee modules many months ago, but gave up someday on further trying to integrate via deCONZ. Meanwhile, it might be much better..
Anyway - I personally opted now for @Chris’s Zigbee binding.
Yes, as @rlkoshak said, it’s work in progress.
And yes, the raspBee or other Dresden Electronic coordinators (USB type) are not supported (yet?).
But: What’s implemented in the Zigbee binding so far is already working quite well!
All my Zigbee lamps from three different vendors (Philips, Osram, Ikea) are working with switching/dimming (for the RGB variants the color control is working as well) … without any separate gateway/bridge/hub
are there any news regarding implementing dresden-elektroniks raspbee zigbee modul?
Or has someone a good documentation how to set up manually? I am runing latest openhabian version an a Pi3. First installing all from sd card image.. when running openhab well i added the zigbee modul. I dont want do install now all the deconz stuff… maybe there is another way to integrate it in openhab.. or there had to be one because i think many people want to use it… ia also have a usb z-wave modul ZME E UZB1, but this is not connected already.. i first wanted to connect the raspbee modul and try to control ikea led’s…
hope to get answers and help here..
kind regards,
Oliver
Hi Chris, thanks for the fast respond. Do you have an aprox. time plan? I am planing a complete home automation for my new house and before planing and buying components i want to test everything…
I would like to use zigbee for controling the ilumination, z-wave for sensors and knx for windows-shutters and doors etc… i will try to put zigbee and z-wave on the raspberry and an external knx-ip-gateway from “Jung” f.ex.
Any idea, suggestion and help welcome.
kind regards,
is there anything which can be already tested for the RaspBee module ? 'happy to help and test things out. Is it possible to have a look at the current work ?
The ConBee driver is basically working, but I had some reliability issues so haven’t merged it into the binding. If you want to have a look at it, it would be great - I’m already spending a lot of time on the Ember and Telegesis sticks so if you can take a look at the ConBee driver it would be great.
Cool, thanks Let me try to tinker a bit with it. For the background: I’m an OpenHAB newbie but have a strong Java and open source background and some experiences in writing drivers.
Do you have a protocol specifications for the access protocol to ConBee / RaspBee ?
thank you for your great contribution. I plan to read out some xiaomi aqara temperature sensors and control our heating with that. I am fairly new to openhab and the raspberry itself. I hope my questions are not too dumb.Of course i tried to find answers to my questions on google etc., but that was unsuccessful.
I do have a Raspbee installed and already working on openhabian. In deconz, I was able to connect a sensor and read data.
From what I understood here, with your driver, it will be possible to get the data into openhab. Where I struggle is the installation of the driver. Is there a guide or tutorial that discribes the way to go?
My questions are:
Is there maybe a compiled version of the driver available?
How can I install it on the raspberry? Place the compiled version simply in the addons folder?
