Issue of the topic:
I have heating managment allready runing on pi0 , now I just want OH2 to read gpio state and present it as on/off icon (green/red io ) in basic UI just for info purpose so I’ve created a sript that reads gpio state , transform it from 0,1 to on/off but cant make icon to change state probably because exec:command outputs string.
Is it possible to make icons change state and how to do it ?
Or as i read Skript i think an other solution is using the exec binding and transformation. Maybe you might find some helpfull infos in the following tutorials.
I looked at gpio binding but I think its too agresive ie setting startup initial values etc, setting input output pins , exporting on exit etc ..basically binding designed to control pins…but I allready have subsys in control of them that is raspi image based so any real interfering will probably brake something thats why I opted for readonly status..
Nevertheless I do get number value of gpio pin 1 and 0 but how to make it control the icon is still eluding me
