@aksnet, thanks for your scripts, very interesting. Just one question : why didn’t you consider using amanda as a basis for your backups?
I did set Amanda up, have it running and yes, what I see is that it is not backing up influxdb & grafana stuff but I was thinking that might be possible to add it to the amanda config file and yet you did choose another way, so I thought I’d ask the question
@thefathefa, When i started to work on the script i guess amanda was not yet implemented or only in some beta versions already.
So i have never looked into it to be honest.
I just opened the 2 main Amanda pages and will see if a switch might be an option.
@mstormi, would it be possible to stop the grafana service as well before the backup via amanda? Or do i have to do this manually before starting amanda?
You can write a simple script to do this and run Amanda afterwards.
Then again I don’t think it’s required to stop Grafana, it’s more of a myth. Try to backup a runnning Grafana and to then restore it if to prove this if you feel uncomfortable about this.
I’m using a custom script for backing up openHAB, Grafana and InfluxDB on my Ubuntu machine. The 3 zip files get afterward synced to Google Drive (Grive2). The script get executed automatically with a dedicated Cron job.
#!/usr/bin/env bash
# Date with Timestamp
echo "+-+-+-+-+-+-+ Set Timestamp +-+-+-+-+-+-+-+-+"
DATE=`date +%Y_%m_%d-%H_%M_%S`
# Backup openHAB
echo "+-+-+-+-+-+-+ openHAB Backup +-+-+-+-+-+-+-+-+"
sudo openhab-cli backup
# Backup Grafana
echo "+-+-+-+-+-+-+ Grafana Backup +-+-+-+-+-+-+-+-+"
#Stop Grafana service
sudo systemctl stop grafana-server
#Backing up ini file
mkdir /var/lib/openhab2/backups/tmp_grafana/
mkdir /var/lib/openhab2/backups/tmp_grafana/$DATE/
sudo cp -arv /etc/grafana/grafana.ini /var/lib/openhab2/backups/tmp_grafana/$DATE/grafana.ini
#Backing up a database
sudo cp -arv /var/lib/grafana/grafana.db /var/lib/openhab2/backups/tmp_grafana/$DATE/grafana.db
#Start Grafana service
sudo systemctl start grafana-server
#Create Zip File
cd /var/lib/openhab2/backups/tmp_grafana/$DATE
sudo zip -r /var/lib/openhab2/backups/grafana-backup-$DATE.zip ./*
#delete tmp folder
rm -rf /var/lib/openhab2/backups/tmp_grafana
# Backup Influxdb
echo "+-+-+-+-+-+-+ Influxdb Backup +-+-+-+-+-+-+-+"
#Backing up the metastore
influxd backup /var/lib/openhab2/backups/tmp_influxdb/$DATE/
influxd backup -database openhab_db /var/lib/openhab2/backups/tmp_influxdb/$DATE/
#Backing up conf file
cp -arv /etc/influxdb/influxdb.conf /var/lib/openhab2/backups/tmp_influxdb/$DATE/influxdb.conf
#Create Zip File
cd /var/lib/openhab2/backups/tmp_influxdb/$DATE
zip -r /var/lib/openhab2/backups/influx-backup-$DATE.zip ./*
#delete tmp folder
rm -rf /var/lib/openhab2/backups/tmp_influxdb
# Sync to Google Drive
sudo cp -vnpr "/var/lib/openhab2/backups/." "/home/smarty/grive/@Backups/openHAB smarty-nuc"
cd "/home/smarty/grive/"
grive -s "@Backups/openHAB smarty-nuc"
# vim: filetype=sh
Thanks Markus, I think I see it for Grafana, yes, but what about influxdb? If the only way to do backhup is to use influxdb backup then, I’m not sure how Amanda would work?
Well I don’t know where influxdb is placing its data but as can be seen in the script above you can actually run an influx command to create a backup. Place these into a directory and add that to Amanda disklist.
@mstormi, thanks for this.
I’m trying to have all the backup related stuff in one place and was looking at how to configure a script to be executed before Amanda performs the backup but before I spend time on this I was wondering if any of you are backing up influxdb by just backing up the folder mentioned by @rlkoshak Rich (Usually its /var/lib/influxdb). Something tells me it is probably not a good idea, but I thought I’d check.
As I could not find the public location of the source, I am asking here. My
openhab-cli backup (or /usr/share/openhab2/runtime/bin/backup) does actually not produce a file , I think due to a bug towards the end of the file.
a) is this known?
b) where is the right place to provide a pull req ?
I need to move from one VM to another.
The original VM is Debian 32 bit with latest openHABian (OH2), and I would like to move to Debian 64 bit (as Grafana 32 bit is not supported).
Do I need to install java 32 bit? is sudo openhab-cli backup/restore the right way, considering I’ve also a lot of zwave devices (xml files to be moved as well)?
Though if the new VM will be running the same OH version, you can just copy over /etc/openhab2 and /var/lib/openhab2 to the new VM and you will have everything.
Uhh, now while not completely wrong, that’s a somewhat dangerous statement.
A typical openHABian setup consists of more than just plain OH and it’s config files: mosquitto, NGINX, …
