First noticed when updated to 5.0.1, but didn’t have time to investigate, so returned to 5.0.0 and issue was resolved. Updated today to 5.1.M1 and problem reappeared. In a nutshell I don’t get the .gif file from this DSL rule past 5.0.0.
Rather than revert back again to 5.0.0 after failing with different ffmpeg options, I decided to use an AI suggestion that is close to fifo, but doesn’t use it. The gifs seem comparable but are a little smaller byte-wise. I guess I’ll call this a solution since I’m tired of messing with it.
@matt1, could you please make this a default for the “GIF Out Options” for the IPCamera binding?
This is still an issue on openHAB 5.1.0 Snapshot #4852
Thx
This is only the default value so you can change it easily enough, however I agree the default should change to help new users out so thanks for pointing it out. I have not done a deep dive on the changes between them but scale=480:-2 will give a different output and will be the reason for the difference in the bytes of the file.
