I am proudly to present: The worlwide first implementation for Text To Speech on Alexa devices for a home automation platform.
Itâs a native implemenation, so you must not hack any hardware and I do not use the bluetooth connection. I use the brand new feature of a routine with custom text. I hope it is in all amazon regions already available. Itâs currently tested with amazon.de
You will find the Release Candidate download link on the top of this thread
I does not expect any problems. Only the Discover feature is refactored, but this is only be used while installation phase. The binding itself works now since 7 month on my installation without any problems. But if you are not sure, you can wait for the response of other users.
And this release should be the last one, with breaking changes.
The release will be the merge binding in the office distribute, but currently I do not know when this happen. Maybe the binding fail to reach the 2.3, then it will take a very long waiting time.
My amazon account stays at uninitialised
If I add the amazon site (in my case amazon.com) PaerUI shows an error 500 Internal server error, then going back to the thing, the site is not saved.
OK I donwloaded the jar and put in my addons. Not sure if im running it as the binding didnt auto install nor the one in the list show any different - shows market id still.
The next time I went through the install though everything worked - binding came up and installed ok and changing account saved and went online. Not sure if this helps or confuses anythingâŠ
Can anyone tell me how I know if I am running on JAR or market binding?
I cant find the location of the alarm IDs You mention:
Do get the ID of your sound, follow the steps in âHow To Get IDâsâ
Write down the text in the square brackets. e.g. ECHO:system_alerts_repetitive01 for the nightstand sound
I have endabled IDs in GUI in the binding but cant see where I would find a list of alarm IDs?
You canât have both bindings version installed. First you have to make a decision: market binding or manual installing the jar in addons folder.
If you want to install it as jar in your addons folder, you have to uninstall the market place binding version first.
Also note that placing a jar in addons folder wonât show up in PaperUI: you wonât see the binding marked as âinstalledâ.
Also note that there were breaking changes, so you will have to first delete all things regarding the binding.
After you installed the binding, either through market place OR as jar in your addons folder, you need to set up your âAmazon Accountâ thing. After doing that all the other things will be in your inbox automatically.
Because of your âwrongâ setup you probably need to restart openHAB before setting up your âAmazon Accountâ thing.
Please take a look in this post above. The screenshots are in german, but I hope it helps. Maybe you have to refresh your browser window to see the drop-downs!
I think @The-Elk is just hoping for a sound before the TTS - I too am looking at this as I use alexa to tell me whats coming up in my calendar 1 hour and 1/2 our before they begin and just jumping in to the TTS might mean the first bit is missed as people stop talkingâŠ
So if Im right he wants the reminders style of announcement but not twice (as is documented a feature of amazon in this thread)
I think a well timed playalarmSound before the TTS might do the job
Thanks for the info - I think I ticked all the boxes you mentioned before trying the jar version - I think based on this I am still running teh market one which is what I prefer anyway.
