Continuing the discussion from [SOLVED] Restore Amanda backup:
Hello, not sure if relating to this this oldtopic is appropriate, but the topic header fits for my problem, and I know @mstormi is certainly the expert.
I have successfully installed Amanda (OH3.3 / bullseye. / openhabian ) and I am able to do backups form individual files to my Synology NAS.
Moreover, I can do backups of the SD card by adding the mmcblk0 device into the config, which results in a compressed image file, which can also be restored by the amfetchdump command to an SD image file of the old size - all without error message.
The problem is: if I write the image file back to SD card and try to mount it, there is only one partition visible, which does not contain any files or data.
Here is what I get if I try to mount the image file to a loop device (as proposed in the old post):
wille@wille-Linux:~$ fdisk -l test_shrink.img
Festplatte test_shrink.img: 8,5 GiB, 9130746368 Bytes, 17833489 Sektoren
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes
E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes
Festplattenbezeichnungstyp: dos
Festplattenbezeichner: 0xb618c86c
Gerät Boot Anfang Ende Sektoren Größe Kn Typ
test_shrink.img1 8192 532479 524288 256M c W95 FAT32 (LBA)
test_shrink.img2 532480 17833488 17301009 8,2G 83 Linux
wille@wille-Linux:~$ mount -o ro,loop,offset=532480 test.img /mnt/temp
mount: /mnt/temp: das Loop-Gerät für test.img konnte nicht eingerichtet werden.
wille@wille-Linux:~$ mount -o ro,loop,offset=532480 test_shrink.img /mnt/temp
mount: /mnt/temp: das Loop-Gerät für /home/wille/test_shrink.img konnte nicht eingerichtet werden.
wille@wille-Linux:~$ sudo losetup --offset 532480 /dev/loop20 test_shrink.img
wille@wille-Linux:/mnt/temp$ sudo mount /dev/loop20 /mnt/temp
mount: /mnt/temp: Falscher Dateisystemtyp, ungültige Optionen, der Superblock von /dev/loop20 ist beschädigt, fehlende Kodierungsseite oder ein anderer Fehler.
As you see, the fdisk check shows two partitions in the original file, which seems reasonable,
In all my attempts by the dd command, only the small one at the beginning is restored (the same for a windows card writer).
Consequently, when I try to boot from the SD card, nothing happens.
Does anyone have an idea, what is going wrong here?
Is there something wrong with the configuration of Amanda, when the full card backup is written?
