[SOLVED] Restore Amanda backup
If you still have your backups, could you please try if using this makes them accessible from Amanda again ?
[11:29:09] backup@openhabianpi:~$ amreindex
USAGE:  amreindex [ --timestamp|-t timestamp ] [-o configoption]* <conf>
USAGE:  amreindex [-o configoption]* [--exact-match] <conf> [hostname [diskname [datestamp [hostname [diskname [datestamp ... ]]]]]]
    amreindex re-index Amanda dump images by reading them from storage volume(s)
    Arguments:
        config       - The Amanda configuration name to use.
        -t timestamp - The run of amdump or amflush to check. By default, check
                        the most recent dump; if this parameter is specified,
                        check the most recent dump matching the given
                        date or timestamp.
        --exact_match   - host, disk and datestamp must match exactly.
        -o configoption - see the CONFIGURATION OVERRIDE section of amanda(8)
[11:29:47] backup@openhabianpi:~$
