I have a switch called SceneCleaning and when that is turned to on i switch on all lamps in group Cleaning.
What i want to do is when Scene Cleaning is set to OFF i want to return the state of all lamps in group Cleaning to what it was when I entered tthe Cleaning mode.
I will try to save the time in an item when i press the clean button and then when i press cleaning off restore the items to the historical value before i pressed the button.
