RFXCom binding reporting wrong signal level?
Just build a new OH2 system and slowly migrating stuff over. RFXCom is the first one.
What I see is the following:
2017-02-01 15:12:57.878 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received message from bridge: rfxcom:bridge:bf8f0750 message: Raw data = 0A520CA60001003C5D0369, Packet type = TEMPERATURE_HUMIDITY, Seq number = 166, Sub type = TH12, Device Id = 1, Temperature = 6.0, Humidity = 93, Humidity status = WET, Signal level = 6, Battery level = 9
What I see in BasicUI is
Signaal level (Bak links) 2 %
No translation is taking place en when shifting my RFXCom back to OH1 I get signal level 6
Things file
	Thing temperaturehumidity sensor_bak_links [deviceId="1", subType="TH12"]
Item file
Number RFXTemp_4_Raw { channel="rfxcom:temperaturehumidity:bf8f0750:sensor_bak_links:temperature" }
Number RFXTemp_4 "Temperatuur (Bak links) [%.1f °C]" <temperature>
Rules file
rule "Adjust RFX Sensor 4"
    Item RFXTemp_4_Raw received update or
    postUpdate(RFXTemp_4, RFXTemp_4_Raw.state as DecimalType)
Site file
		Text item=RFXTemp_4
Binding error?
Binding error?
No, see RFXCOM binding(rfxtrx433e) poor signal in openhab, betterin windows
Thx Pauli,
did not find that in my search. Strange that for battery level translation was made from 0-9 into % and for signal strenght from 0-9 into 0-4 :thinking:
rgds
If you look Eclipse SmartHome specification from
you can see that this is not RFXCOM binding specific but more global approach.
