unfortunately openHAB doesn’t come with any official Ring doorbell binding, but I was lucky to find this project on GitHub GitHub · Where software is built
It uses the Ring API, this means your Ring device has to be connected to the Cloud, but a Ring protection plan / subscription is NOT required.
Long story short, using mqtt-ring openHAB will be notified when motion is detected and when someone rings the bell. Even without a Ring protection plan subscription. Eventually I use the chromecast binding to play a DingDong sound on my Google Home devices. On top openHAB sends a Telegram message with a still picture in case someone rings my doorbell (out of the box integration, image provided via mqtt topic by ring-mqtt) or if motion is detected (manual image generation via ffmpeg connecting to the rtsp stream)
Why is the latter needed? Unfortunately “low powered” devices like my doorbell gen 2 (using 8-24V AC input) don’t provide an image snapshot in case motion is detected. At least without a Ring protection plan. This means, once openHAB detects motion I have to use ffmpeg to connect to the ring-mqtt rtsp stream and generate a still image. Then I will send the image via Telegram binding. This is always delayed and very rarely (not sure how to fix) the image is scrambled (google for smearing). However, I’m happy with the result.
I’m using ring-mqtt as docker image. It was really easy to set it up.
sounds really great.
I’m running Openhabian, so I don’t have Docker Hub. I did pull the ring-mqtt docker image from CLI, but thats where my Linux knowledge ends
Installing it manually (though not recommended) seemed to have worked for me. However, I’m having issue manually starting the service and accessing it via MQTT.
I’d say quick enough, check the video I did record for you.
BUT I need to say that I use two chime systems. One system is an audio group that consists of several Google Home Assitant devices. Once openhab detects the ding event, it will connect to the audiogroup and ask to play a local mp3 file (provided as http URL). The other system is a self-built esp8266 with physical mp3 player and loudspeaker. All in all you will hear three sounds being played. The outside rind doorbell itself, my esp doorbell and the google devices. The esp reacts a bit faster compared to google homes. Anyway, all in all it’s still pretty fast. maybe 500ms delay.
btw guys, now after few weeks testing without a Ring protection plan, I need to admit that the ffmpeg to ring-mqtt connection (to create the still image) isn’t 100% satisfying. The main issues are:
The process to grab the still image is very slow and leads to a delay between motion event and image finally loaded on my smartphone
Quite rare, but sometimes the image is corrupted (seems to be udp issue, but I wasn’t able to make it run using tcp)
It happened to me a few times that ring-mqtt rtsp stream stopped working. then of course you won’t get any image. the developer said he has to implement more errorhandling. so maybe it will work better in the future.
Summarized, I’m thinking about purchasing the ring protection plan. Then AWS will take care about all videos.
I haven’t figured out how to debug and get the logs with the manual install unfortunately
I did set up the mqtt generic thing in MainUI (using the built-in mqtt broker, not mosquitto), but I guess I have to create the channels manually as well, right (at least that’s how I did it in OH 2.5 with the configuration files). Would you mind sharing your YAML thing definition?
Sorry for reviving this old thread. I can’t for the life of me get the MQTT authentification to work. Maybe @Mario084 or @StefanH can help me with this one…
I’m on openHABian running OH 5.2. I just installed mosquitto via openhabian-config and docker as well as ring-mqtt 5.9.2 via SSH.
mosquitto.conf:
If I enable allow_anonymous everything’s working fine, however, if I disable it, I get “connection refused”
ring-mqtt.js version: 5.9.2
Node version v22.21.1
NPM version 10.9.4
git version 2.52.0
Running ring-mqtt...
2026-01-24T00:19:15.773Z ring-mqtt Detected runmode: docker
2026-01-24T00:19:15.778Z ring-mqtt Configuration file: /data/config.json
2026-01-24T00:19:16.357Z ring-mqtt Reading latest data from state file: /data/ring-state.json
2026-01-24T00:19:16.366Z ring-mqtt WARNING - Unhandled Promise Rejection
2026-01-24T00:19:16.366Z ring-mqtt Invalid URL
2026-01-24T00:19:16.367Z ring-mqtt TypeError: Invalid URL
at new URL (node:internal/url:827:25)
at Config.init (file:///app/ring-mqtt/lib/config.js:49:25)
2026-01-24T00:19:17.010Z ring-mqtt Attempting connection to Ring API using saved refresh token...
2026-01-24T00:19:22.111Z ring-mqtt Successfully established connection to Ring API using saved token
2026-01-24T00:19:22.112Z ring-mqtt Received updated refresh token
2026-01-24T00:19:22.112Z ring-mqtt Saving updated refresh token to state file
2026-01-24T00:19:23.132Z ring-mqtt Successfully saved updated state file: /data/ring-state.json
2026-01-24T00:19:24.111Z ring-mqtt Attempting connection to MQTT broker...
2026-01-24T00:19:24.155Z ring-mqtt Unable to connect to MQTT broker Connection refused: Not authorized
(The “Invalid URL” is thrown in both cases, so I don’t think this has anything to do with it).
It seems to me you have a problem with your mosquitto passwd file. The broker uses its own user database and does not support to use usernames and passwords of host users. You can see this in your mosquitto conf. The content of the passwd file should look like:
/etc/mosquitto/passwd contains both the host user and the one I created for Ring.
Using mosquitto_sub and mosquitto_pub does work - I can send messages to the broker manually. Only when I try it in ring-mqtt I get the “Not authorized” message.
I wonder if the issue is in the communication between mosquitto and the docker container.
Good catch. Try to access the console aka terminal interface of your docker Container. If needed use apt to install mosquitto_sub/pub and check if it works to connect to your broker
Further to this, I just worked out how to get the timestamp of the last snapshot, and how to download the snapshot using curl; so now I ‘just’ need to code it
https://smedley.id.au/tmp/org.openhab.binding.ring-5.2.0-SNAPSHOT.jar works except for the upgrade part - so right now, to use it, you need to remove the things and recreate them. Once I work out how to get the upgrade working, I’ll submit a PR and it should be included in OH 5.2.0
Come to think of it, I should just add the new channels to the Device Status group, rather than trying to create a new group….
I force-removed the old things I created with the official release, uninstalled the old binding, restarted, installed the .jar but now I’m stuck with “Invalid username or password” when creating a new Bridge thing.
I left username/pw blank and just added the 2FA code.
