So I plan to start a simple binding for it. But if somebody already does it silently (there is no Feature Request in github yet), please let me know so we can join forces.
Great! I ordered my Robonect hardware today, with a little luck that means I can try this binding out soon. Iāll get back with input. First question though: Is this a OH2 binding? Most of my current things come from the z-wave binding, so Iām not used to fiddling with .items and .things files
Great! Itās a very nice module once it is installed
Itās an OH2 binding. You just need to add a thing via PaperUI entering the IP of your robonect module. Of course the IP must be reachable from the network OH2 runs. So donāt try to enter the default IP of the Robonect exposed WLAN but properly integrate Robonect into your WLAN. After that all channels are mappable via PaperUI to items if you donāt like item files
Also please note that this is build on Openhab 2.1 SNAPSHOT. So Iām not sure if it runs with current OH 2.0 stable. You should install a OH2.1 Snapshot version to be sure.
Ok, got the module installed now (on my Automower 310, you might want to add that model to the supported ones, Iāve got fw 0.9e). The binding doesnāt work well though, I donāt know if it might be because Iām still on 2.0 stable or something else? I get this in the log:
11:40:54.324 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing ārobonect:mower:051c4307ā has been added.
11:40:54.366 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ārobonect:mower:051c4307ā changed from UNINITIALIZED to INITIALIZING
11:40:54.482 [ERROR] [ing.robonect.handler.RobonectHandler] - Exception when trying to initialize
org.openhab.binding.robonect.RobonectCommunicationException: Could not send command http://http://192.168.168.70/json?cmd=version
at org.openhab.binding.robonect.RobonectClient.sendCommand(RobonectClient.java:211)[249:org.openhab.binding.robonect:2.1.0.201706272144]
at org.openhab.binding.robonect.RobonectClient.getVersionInfo(RobonectClient.java:216)[249:org.openhab.binding.robonect:2.1.0.201706272144]
at org.openhab.binding.robonect.handler.RobonectHandler.refreshVersionInfo(RobonectHandler.java:313)[249:org.openhab.binding.robonect:2.1.0.201706272144]
at org.openhab.binding.robonect.handler.RobonectHandler.initialize(RobonectHandler.java:335)[249:org.openhab.binding.robonect:2.1.0.201706272144]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:713)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
Caused by: java.util.concurrent.ExecutionException: java.nio.channels.UnresolvedAddressException
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:110)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:655)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.openhab.binding.robonect.RobonectClient.sendCommand(RobonectClient.java:205)[249:org.openhab.binding.robonect:2.1.0.201706272144]
⦠10 more
Caused by: java.nio.channels.UnresolvedAddressException
at org.eclipse.jetty.util.SocketAddressResolver$Async$1.run(SocketAddressResolver.java:169)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
⦠1 more
11:40:54.506 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ārobonect:mower:051c4307ā changed from INITIALIZING to OFFLINE
Of course the url starting with āhttp://http://ā doesnāt work. Any idea if this is something the binding does or OH itself?
Sorry for being a little reluctant to upgrading my environment to 2.1. Many things that could be broken
Hahaha⦠I feel kinda stupid now, donāt I? Why on earth do Firefox do that? I mark the IP address and copy it and then Firefox silently inserts āhttp://ā in front of it. I do not want that! I only want to copy the stuff I actually marked!
Seems to work fine now. Iāll get back when Iāve tried some more.
Yep, I can confirm everything works perfectly. This is with the combination Automower 310/Hx/0.9e and HA 2.0 stable. Thanks for a very good job!
edit: Btw, one thing in the readme that you could add is info about units used for the pollinterval and offlineTimeout settings. Are they seconds or minutes?
edit2: Doh. Just realized 2.1 was released, guess itās time to upgrade now. Well, now we know that it works for 2.0 as well anyway
@reyem
I have the problem, that the Error code and the Error message receive no update.
When I raise my automower, the Error date updates, but the code and message are still UNDEF.
Currently the error message/code is just set if the mower is in error status. However, I could introduce a channel for last error message and last error code if this helps. Theoretically the full list of errors would aldo be available from the module. But I donāt know a good way/channel type to provide it in OH. Is the last error enough or do you need more?
That would be possible, but when the error changed really fast back to the normal state, the items donāt get updated.
So it would be nice to always the the last error message from that api.
