Roku Support
I am not sure what is wrong, it may help to set a rule when the switch is activated and add a log such as
rule "RokuMB Home"
  Item RokuMBHome changed from ON to OFF or
  Item RokuMBHome changed from OFF to ON
	logInfo("Roku", "Roku Home pressed")
This will let you know that Openhab is seeing the command.
I also have the http binding installed, but not sure if that is required?
Thanks BK, but I’ve found that the only thing that works is to put very stripped-out items in the .items file
(e.g.)
Switch RokuPlayPause “Roku PlayPause”
then a corresponding rule in a .rules file
(e.g.)
rule “RokuPlay” when
Item RokuPlayPause changed
executeCommandLine(“curl -XPOST http://192.168.0.10:8060/keypress/play”)
and then it all seems to work OK.
Thanks also for posting your widget; just one thing, do you know how to make the “Play” button a toggle as once it sends “On” then Roku is paused and the actual button on the remote control is a toggle On/Off = Play/Pause??
Thanks again for your help; I only heard of openHAB on Monday so I’m on a very steep learning curve :slight_smile:
I came across this post for a Roku binding. From the thread, it appears to be mostly done, maybe some final touches and testing needed. The author has opened it up for someone else to pick up. Maybe worth taking a look at?..
I’m definitely interested in a Roku binding. I just don’t do code…
https://www.bountysource.com/issues/46584945-roku-roku-binding-initial-contribution
@morph166955 I copied and pasted your code and it works great!
I had a little trouble getting the searchRokus.py script to run. First you have to make the file executable with
sudo chmod a + x /etc/openhab2/scripts/searchRokus.py
I still had trouble getting this to run, and discovered an EOL issue that I could fix in the edit menu of Notebook++. Once that was fixed, the script worked great.
I was able combine your example with the Habpanel in post #35 above by @bkyle.
@morph166955
Did you post the latest v3 code anywhere. I seem to be having trouble getting this to work. So far I had to update the roku.rules to point to where the python script was. (Yes Im testing all this out on a windows PC)
val String ssdp = executeCommandLine(“C:/openhab2/conf/scripts/searchRokus.py”, 20000)
However, I am still getting an error
19:53:00.002 [ERROR] [untime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘ROKU APPINFO’: 1
Any ideas?
I’ve updated this for OH3 to use the new HTTP binding. See: ROKU Support on OH3 using HTTP binding
Check these out for some examples:
Not sure if your still looking for one but im just about done a roku remote widget
@mediatech15
Hi Kyle, did you ever finish your roku remote widget?
Sorry on late reply. I have not Im willing to share what I have. That said it is not “serviceable” at the moment.
I have done a rough widget and rule that works with Telstra TV (roku).
Rule code:
configuration: {}
triggers:
  - id: "1"
    configuration:
      itemName: rokuitem
    type: core.ItemStateUpdateTrigger
conditions: []
actions:
  - inputs: {}
    configuration:
      type: application/javascript
      script: >-
        //need below to log to openhab.log file
        //below is if you are going to use the ececute command
        var Exec = Java.type("org.openhab.core.model.script.actions.Exec");
        //below is also needed for the execute command
        var Duration = Java.type("java.time.Duration");
        var HttpUtil = Java.type("org.openhab.core.io.net.http.HttpUtil");
        var HttpGet = Java.type("org.openhab.core.model.script.actions.HTTP");
        //below is the Telstra TV settings
        var PORT = "8060"
        var IP = "192.168.1.161"
        var stateof = event.itemState.toString() ;
        logger.info("results = " + stateof);
        switch(stateof) {
         case "KEY_POWER":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Home", 20000);
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/PowerOff", 20000);
          logger.info('Play key pressed');
            break;
          case "KEY_PLAY":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Play", 20000);
            break;
          case "KEY_PAUSE":
            break;
          case "KEY_REWIND":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Rev", 20000);
            break;
          case "KEY_FF":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Fwd", 20000);
            break;
          case "KEY_UP":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Up", 20000);
            break;
          case "KEY_LEFT":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Left", 20000);
            break;
          case "KEY_ENTER":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Select", 20000);
            break;
          case "KEY_RIGHT":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Right", 20000);
            break;
          case "KEY_DOWN":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Down", 20000);
            break;
          case "KEY_HOME":
            break;
          case "KEY_RETURN":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/InstantReplay", 20000);
            break;
          case "KEY_BACK":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/keypress/Back", 20000);
            break;
          case "KEY_NETFLIX":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/launch/12", 20000);
            break;
          case "KEY_AMAZON":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/launch/13", 20000);
            break;
          case "KEY_SBS":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/launch/65507", 20000);
          logger.info('SBS key pressed');
            break;
          case "KEY_IVIEW":
             HttpUtil.executeUrl("POST","http://"+IP+":"+PORT+"/launch/73305", 20000);
          logger.info('KEY_IVIEW key pressed');
            break;
          default:
              logger.info('Nothing ran');
        curl  "http://192.168.1.50:8060/query/apps"
        <?xml version="1.0" encoding="UTF-8" ?>
        <apps>
        	<app id="62034" type="appl" version="3.7.0">Telstra TV Box Office</app>
        	<app id="587447" type="appl" version="1.8.4">Binge Entertainment</app>
        	<app id="71361" type="appl" version="3.27.3321">Stan</app>
        	<app id="12" type="appl" version="4.2.98018037">Netflix</app>
        	<app id="262035" type="appl" version="1.17.134">Kayo Sports. Stream Live Sport</app>
        	<app id="13" type="appl" version="11.4.2020092816">Prime Video</app>
        	<app id="65509" type="appl" version="4.5.0">7plus</app>
        	<app id="65575" type="appl" version="3.8.116">9Now</app>
        	<app id="74349" type="appl" version="5.1.2">10 play</app>
        	<app id="73305" type="appl" version="5.0.3">ABC iview</app>
        	<app id="65507" type="appl" version="2.5.226">SBS On Demand</app>
        	<app id="837" type="appl" version="1.0.80000314">YouTube</app>
        </apps>
    type: script.ScriptAction
Widget code:
uid: Remote roku
tags: []
props:
  parameters:
    - context: item
      description: Select the remote you wish to use at an equipment item level
      label: Select Equipment
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Jul 3, 2021, 4:54:59 PM
component: f7-block
  style:
    box-shadow: 2px 3px rgb(150,150,150)
    background-color: rgb(192, 192, 192)
    --f7-card-margin-horizontal: 0px
    border-radius: 30px
    width: 15rem
    height: 40rem
slots:
  default:
    - component: f7-badge
        bgColor: black
        style:
          position: absolute
          left: 65px
          top: 20px
          width: 110px
          height: 40px
          border-radius: 12px
    - component: oh-link
        style:
          position: absolute
          top: 28px
          left: 108px
          color: red
        iconF7: power
        iconSize: 25
        action: command
        actionCommand: KEY_POWER
        actionItem: =props.item
        bgColor: black
        style:
          position: absolute
          left: 90px
          top: 110px
          width: 60px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 116px
          left: 95px
          color: white
        iconF7: play
        iconSize: 25
        action: command
        actionCommand: KEY_PLAY
        style:
          position: absolute
          top: 116px
          left: 117px
          color: white
        iconF7: pause
        iconSize: 25
        action: command
        actionCommand: KEY_PAUSE
        bgColor: black
        style:
          position: absolute
          left: 20px
          top: 110px
          width: 60px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 117px
          left: 35px
          color: white
        iconF7: backward
        iconSize: 25
        action: command
        actionCommand: KEY_REWIND
        style:
          position: absolute
          top: 117px
          right: 35px
          color: white
        iconF7: forward
        iconSize: 25
        action: command
        actionCommand: KEY_FF
        bgColor: black
        style:
          position: absolute
          right: 20px
          top: 110px
          width: 60px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 197px
          left: 103px
          color: white
          z-index: 2
        iconF7: arrowtriangle_up
        iconSize: 35
        action: command
        actionCommand: KEY_UP
        style:
          position: absolute
          top: 263px
          left: 35px
          color: white
          z-index: 2
        iconF7: arrowtriangle_left
        iconSize: 35
        action: command
        actionCommand: KEY_LEFT
        bgColor: black
        style:
          position: absolute
          left: 80px
          top: 242px
          width: 80px
          height: 80px
          border-radius: 50%
          border: gray solid 1px
          z-index: 2
        bgColor: black
        style:
          position: absolute
          left: 30px
          top: 190px
          width: 180px
          height: 180px
          border-radius: 50%
          z-index: 1
        text: OK
        style:
          font-size: 25px
          position: absolute
          top: 261px
          left: 103px
          color: white
          z-index: 3
        iconSize: 75
        action: command
        actionCommand: KEY_ENTER
        style:
          position: absolute
          top: 263px
          right: 35px
          color: white
        iconF7: arrowtriangle_right
        iconSize: 35
        action: command
        actionCommand: KEY_RIGHT
        style:
          position: absolute
          top: 330px
          left: 103px
          color: white
        iconF7: arrowtriangle_down
        iconSize: 35
        action: command
        actionCommand: KEY_DOWN
        bgColor: black
        style:
          position: absolute
          left: 80px
          top: 385px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 392px
          left: 108px
          color: white
        iconF7: house
        iconSize: 25
        action: command
        actionCommand: KEY_HOME
        bgColor: black
        style:
          position: absolute
          left: 20px
          top: 440px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 446px
          left: 45px
          color: white
        iconF7: arrow_left
        iconSize: 25
        action: command
        actionCommand: KEY_BACK
        bgColor: black
        style:
          position: absolute
          right: 20px
          top: 440px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 447px
          right: 45px
          color: white
        iconF7: arrow_counterclockwise
        iconSize: 25
        action: command
        actionCommand: KEY_RETURN
        bgColor: black
        style:
          position: absolute
          right: 20px
          top: 495px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 505px
          right: 35px
          color: white
        iconSize: 25
        action: command
        actionCommand: KEY_AMAZON
        text: Amazon
        bgColor: black
        style:
          position: absolute
          left: 20px
          top: 495px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 505px
          left: 35px
          color: white
        iconSize: 25
        action: command
        actionCommand: KEY_NETFLIX
        text: Netflix
        bgColor: black
        style:
          position: absolute
          left: 20px
          top: 545px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 555px
          left: 35px
          color: white
        iconSize: 25
        action: command
        actionCommand: KEY_SBS
        text: SBS
        bgColor: black
        style:
          position: absolute
          right: 20px
          top: 545px
          width: 80px
          height: 40px
          border-radius: 12px
        style:
          position: absolute
          top: 555px
          right: 35px
          color: white
        iconSize: 25
        action: command
        actionCommand: KEY_IVIEW
        text: iVeiw
        color: red
        style:
          font-size: 25px
          position: absolute
          left: 25px
          top: 600px
          width: 200px
          height: 40px
          display: flex
        text: Telstra TV
It is a bit rough but works.
Just create a string item called rokuitem and it should work.
Also set your IP address as static so it stays the same as that is hard coded into the rule.
No warranty. :grinning:
