The room card widget provides a quick overview for many states in one room and is fully configurable.
You can use a background image and you may use a header.
Color scheme and opacity is fully configurable for the columns.
This widget is part of my personal custom developed widget set, which is available on GitHub: openhab-conf/UI/widgets at main · florian-h05/openhab-conf · GitHub .
Data displayed
The widget can display up to three columns of data, each data field can and has to be configured:
Humidity and illumination
Current temperature, target temperature (in braces), heating & cooling state
Lights state (on/off + number of lights on), windows/doors (for each open/closed + number of open), one or two blinds position, speaker state
The widget was inspired by the cards of the location tab and credits for the basic concept go to @Integer at [OH3] Main UI Examples - #22 by Integer .
Screenshots
Changelog
The git history can be seen as a changelog: History for UI/widgets/florianh-widgetset/roomCard.yaml - florian-h05/openhab-conf · GitHub .
Resources
https://github.com/florian-h05/openhab-conf/raw/main/UI/widgets/florianh-widgetset/roomCard.yaml
Line 254 (actual temperature) should be
“=(items[props.temp].displayState ? items[props.temp].displayState : items[props.temp].state) + (props.settemp ? ’ (’ + items[props.settemp].state + ‘)’ : ‘’)”
instead of
“=(items[props.temp].displayState) + (props.settemp ? ’ (’ + items[props.settemp].displayState + ‘)’ : ‘’)”
in case of using innogy thermostat, but maybe on all other thermostats as well
@Andy_Eichhorst
Thanks for that tip.
I had no problems only using displayState, but yeah, sometimes displayState is not available, so I updated the whole widget to always fall back to state when displayState is not available.
bkumio
(Mario)
January 2, 2023, 6:40pm
4
Hi Florian, all
I like your widget. Interesting for me to learn yaml code.
I do have a question on your last lines of code. Instead of opening a new “page” (which I could do of course) I would like to use the semantic model functionality like the one form the the standard “label cell” to open a group popup Item (actionGroupPopupItem) instead.
what I did was to replace your last lines of code se below.
Your stuff :
- component: oh-link
action: navigate
actionPage: ='page:' + props.page
style:
height: 125px
left: 0px
position: absolute
top: 0px
width: 100%
visible: "=props.page ? true : false"
with my idea of using your “page” property to show the group as popup
action: group
actionGroupPopupItem: props.page
expandable: false
item: props.page
stateAsHeader: true
title: props.page
But when I hover over the room card unfortunately the mouse pointer is not changing to a “hand” indicating that you can even “click the card”. despite the fact the nothing is happening
I am not a developer just an advanced OH user currently migrating from OH2.5 to v3.4 and learning on how to use the new pages concept..,If you have an idea let me know
bkumio
(Mario)
January 3, 2023, 10:28am
5
I think I found an example from AndrasU : Widgets
which does the trick.
If I understand correctly in addition to the props: parameters: he added a props: parameterGroups function which allows in the UI config to select the “group” function and then from the sematic model you select the group you want to have displayed as button popup (without the need to create an additional page) .
parameterGroups:
- name: buttonAction
context: action
label: Action
description: Action to start
with a subsequent oh-button action
- component: oh-button
actionPropsParameterGroup: buttonAction
fill: false
style:
width: 100%
height: 100%
no-border: true
background: '=(props.backgroundImageUrl) ? "url(" + props.backgroundImageUrl + ")" : (props.colorCodeTop_d) ? (props.colorCodeTop_d) : "#AFDFFF"'
background-size: cover
class:
- no-padding
The design of the card itself is as everyone wants to configure but I quite like it…
So thanks Andras, I am learning ervery day
bkumio
Yes, thats quite practical. Most of my widgets actually use the action configuration via the parameter group in the UI, but my room card doesn‘t as I only use pages with it‘s action.
I would do it as following, but I guess it does the same as your modification:
- name: widgetAction
context: action
label: Action settings
description: Action to perform when the widget is clicked
actionPropsParameterGroup: widgetAction
style:
height: 125px
left: 0px
position: absolute
top: 0px
width: 100%
@bkumio BTW: I have a full custom widgetset, you can find it on GitHub: openhab-conf/UI/widgets at main · florian-h05/openhab-conf · GitHub .
Dom_KS
(Dom KS)
January 28, 2023, 4:40pm
7
Hello!
Great widget! Is there a chance that you add custom items ex. item one … /icon off … / icon on ?
I would add TV/PS4/AV or NestHub.
Unfortunately I‘ve no idea how to do that: dynamically adding custom items with custom icons. If you have an idea, please let me know.
Note that you can install from the marketplace and then modify the widget to your needs.
Dom_KS
(Dom KS)
January 28, 2023, 8:26pm
9
Yes! I mod it!
I added:
TV
Settop box (android/sattelite etc.)
Changed speaker icon to hifi speaker ( home cinema)
Console
Google speaker
Should or can I post it here?
Feel free to post here if you want to, I will see if I add those to the widget. (Note that I cannot add all icons/Items that people use, because then the widget would end up getting huge. I mean, everyone can add anything he wants to to the widget and further customize it.)
My „problem“ with the hifispeaker icon is, that there is no icon version to display the off state. How do you handle that state? Hide the icon?
Same goes for the console icon.
Dom_KS
(Dom KS)
February 1, 2023, 10:28am
11
I just add next items and icons. I don’t have binds so it isn’t displayed.
For ON state i use filled (black) icons for OFF white ones.
uid: roomCard_max
tags:
- community.openhab.org
- florianh-widgetset
props:
parameters:
- description: Title to display in upper right corner
label: Header
required: false
type: TEXT
- description: web address of background image
label: Background image
required: false
type: TEXT
- default: black
description: HEX, rgba or name, e.g. white or black
label: Background color
required: true
type: TEXT
- default: "0.6"
description: decimal, e.g. 0.6
label: Background opacity
required: true
type: TEXT
- default: white
description: icon & text color, e.g. black or white
label: Icon & text color
required: true
type: TEXT
- description: Page which will be navigated to
label: Page ID
required: false
- context: item
description: item/group for light(s)
label: Light(s) item
required: false
type: TEXT
- context: item
description: Group:Number:COUNT(ON) item for numbers of lights on
label: Number of lights on
required: false
type: TEXT
- context: item
description: item for windows(s)
label: Window(s) item
required: false
type: TEXT
- context: item
description: Group:Number:COUNT(CLOSED) item for numbers of windows open
label: Number of windows open
required: false
type: TEXT
- context: item
description: item for temperature
label: Temperature item
required: false
type: TEXT
- context: item
description: item for set temperature
label: Set temperature item
required: false
type: TEXT
- context: item
description: item for blinds
label: Blind(s) item
required: false
type: TEXT
- context: item
label: Blind 2 item
required: false
type: TEXT
- context: item
description: item for heating state
label: Heating state item
required: false
type: TEXT
- context: item
description: item for cooling state
label: Cooling state item
required: false
type: TEXT
- context: item
description: item for humidity
label: Humidity item
required: false
type: TEXT
- context: item
description: item for illuminance
label: Illuminance item
required: false
type: TEXT
- context: item
description: item for door state(s)
label: Door state(s)
required: false
type: TEXT
- context: item
description: item for door lock(s)
label: Door lock(s)
required: false
type: TEXT
- context: item
description: Item for garagedoor state(s)
label: Garagedoor state(s)
required: false
type: TEXT
- context: item
description: item for TV
label: TV(s) item
required: false
type: TEXT
- context: item
description: item for TV Box
label: TV Box item
required: false
type: TEXT
- context: item
description: item for speaker(s)
label: Speaker(s) item
required: false
type: TEXT
- context: item
description: item for gaming console
label: Gaming console
required: false
type: TEXT
- context: item
description: item for Google speaker
label: Google speaker
required: false
type: TEXT
timestamp: Jan 28, 2023, 9:14:40 PM
component: f7-card
style:
--f7-chip-bg-color: rgba(255, 255, 255, 0.0)
--f7-chip-height: 22px
--f7-chip-padding-horizontal: 10px
--f7-chip-text-color: =props.color
background-image: ='url(' + props.image + ')'
background-position: center
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
class:
- padding: 0px
height: 130px
margin-left: 5px
margin-right: 5px
noShadow: false
slots:
content:
- component: f7-block
style:
background: =props.bgcolor
border-radius: 7px
opacity: =props.bgopacity
position: absolute
right: 16px
top: -5px
visible: "=props.text_header ? true : false"
slots:
default:
- component: Label
style:
color: =props.color
font-size: 20px
font-weight: 600
margin-left: 0px
margin-top: 0px
text: =props.text_header
style:
border-radius: 7px
bottom: -75px
left: 16px
position: absolute
slots:
default:
- component: f7-chip
iconColor: =props.color
iconF7: "=items[props.light].state == 'ON' ? 'lightbulb_fill' : 'lightbulb_slash'"
iconSize: 18
text: "=props.lights_number ? ((items[props.light].state == 'ON') ? items[props.lights_number].state : '') : ''"
visible: "=props.light ? true : false"
visible: "=props.garagedoor_state ? true : false"
slots:
media:
- component: oh-icon
icon: "=items[props.garagedoor_state].state === 'CLOSED' ? 'mygaragedoor-closed' : 'mygaragedoor-open'"
iconSize: 24
style:
height: 24px
visible: "=props.door_state ? true : false"
slots:
media:
icon: "=items[props.door_state].state === 'CLOSED' ? 'door-closed' : 'door-open'"
iconSize: 24
style:
height: 24px
text: "=(items[props.window].state == 'OPEN') ? (props.windows_number ? items[props.windows_number].state : '') : ''"
visible: "=props.window ? true : false"
slots:
media:
icon: "=items[props.window].state === 'CLOSED' ? 'window-closed' : 'window-open'"
iconSize: 24
style:
height: 24px
iconF7: "=items[props.door_lock].state === 'ON' ? 'lock_open' : 'lock'"
iconSize: 18
visible: "=props.door_lock ? true : false"
iconF7: arrow_up_arrow_down
iconSize: 18
text: "=props.blinds2 ? items[props.blinds].state + ' | ' + items[props.blinds2].displayState : items[props.blinds].displayState"
visible: "=props.blinds ? true : false"
iconF7: "=items[props.tv].state === 'ON' ? 'tv_fill' : 'tv'"
iconSize: 18
visible: "=props.tv ? true : false"
iconF7: "=items[props.tvbox].state === 'ON' ? 'ticket_fill' : 'ticket'"
iconSize: 18
visible: "=props.tvbox ? true : false"
iconF7: "=items[props.speaker].state === 'ON' ? 'hifispeaker_fill' : 'hifispeaker'"
iconSize: 18
visible: "=props.speaker ? true : false"
iconF7: "=items[props.console].state === 'ON' ? 'gamecontroller_fill' : 'gamecontroller'"
iconSize: 18
visible: "=props.console ? true : false"
iconF7: "=items[props.google_speaker].state === 'ON' ? 'logo_google' : 'nosign'"
iconSize: 18
visible: "=props.google_speaker ? true : false"
style:
border-radius: 7px
bottom: -45px
left: 16px
position: absolute
slots:
default:
iconF7: thermometer
iconSize: 18
text: "=(items[props.temp].displayState ? items[props.temp].displayState : items[props.temp].state) + (props.settemp ? ' (' + (items[props.settemp].displayState ? items[props.settemp].displayState : items[props.settemp].state) + ')' : '')"
visible: "=props.temp ? true : false"
iconF7: flame
iconSize: 18
visible: "=props.heating ? items[props.heating].state === 'ON' : false"
iconF7: circle_grid_hex
iconSize: 18
visible: "=props.cooling ? items[props.cooling].state === 'ON' : false"
style:
border-radius: 7px
bottom: -15px
left: 16px
position: absolute
slots:
default:
iconF7: drop
iconSize: 18
text: "=items[props.humidity].displayState ? items[props.humidity].displayState : items[props.humidity].state"
visible: "=props.humidity ? true : false"
iconF7: sun_min
iconSize: 18
text: "=items[props.illuminance].displayState ? items[props.illuminance].displayState : items[props.illuminance].state"
visible: "=props.illuminance ? true : false"
action: navigate
style:
height: 125px
left: 0px
position: absolute
top: 0px
width: 100%
Dom_KS
(Dom KS)
February 1, 2023, 10:49am
12
Do you know how I can hide icons? It could be interesting.
Dom_KS
(Dom KS)
February 4, 2023, 9:02pm
13
Is there a possibility that click on the widget navigates to location ex. Livingroom ?
IMO the other way (black for off, on for white) makes more sense, but that’s up to you You can modify the widget in any way you want.
Yes, the widget actually already does this for all icons if the corresponding Item is not set.
Just set the visible parameter of the f7-chip to an expression like:
"=items[props.someitem].state === 'ON' ? true : false"
This will display the icon if the Item defined in the someitem property has the state ON and hide the icon for all other Item states. Note that for the existing f7-chips you need to extend the expression because it already covers the case that an Item property is not set.
AFAIK no, there is no way to navigate to the auto-generated page of a semantic location (if you mean that).
Please only ask questions related to my card widget in this thread, not widgets from other authors.
bkumio
(Mario)
January 19, 2026, 7:02am
17
Understood. Thought this is a good place. I have just deleted my post and will re-submit in the setup-configuration-and-use / Widgets section as this widget was never part of the marktet place.
