RRD4J inspector: How to use it
Hi folks,
during my upgrade process from OH 2 to OH 3 (great improvement!) I am struggeling with the rrd4j persistence. Therefore I wanted to look inside the newly created rrd4j data files. If you are using docker container (recommended…), these files are located here: …/openhab/userdata/persistence/rrd4j/.
There are some post in this forum about the usage of the inspector, but they are incomplete. So go to this site: https://repo1.maven.org/maven2/org/rrd4j/rrd4j/3.3.1/ and download these TWO files:
  • rrd4j-3.3.1-inspector.jar AND
  • rrd4j-3.3.1.jar
Put both files into the same directory. Use a CLI and change into this directory. Start the inspector with
java -cp rrd4j-3.3.1-inspector.jar org.rrd4j.inspector.RrdInspector
Select a rrd4j file for inspection. If you get an error like Exception in thread “main” java.lang.NoClassDefFoundError: org/rrd4j/core/RrdDb, then you are missing the 2nd .jar-file from above!
This should clarify the usage of the rrd4j inspector. Don’t use later versions of the inspector, the required class is not there anymore… Additionally the inspector requires a graphical interface (Windows-PC is fine) and does not work on headless systems.
Have fun!
Thanks for this input.
It used to work with the single (-inspector) jar file. However now you do need both.
Did my test with the 3.4 Version.
Thanks, works like a charm on my Win11 Laptop with Oracle Java 1.8.0_221
Just drop both java files in a directory, click on the inspector and browse the OH3.4.2-1 persistence folder in a samba share.
Java 8 ? Really ? openHAB 3 requires Java 11 to work properly…
Yes, I confirm. My Rasbian is headless, I need to run the tool on Windows.
Yesterday I did just open the RRD file to take a look, I didn’t want to stop OH.
But now, to be sure, I stopped OH and could change a NaN value in the database and checked that the file was properly updated.
In the manifest of RRdInspector I can read JDK 11:
Manifest-Version: 1.0
Created-By: Apache Maven 3.5.2
Built-By: travis
Build-Jdk: 11
Main-Class: org.rrd4j.inspector.RrdInspector
Class-Path: rrd4j-3.3.1.jar
But it runs on JSE 8.0
Microsoft Windows [version 10.0.22000.1696]
(c) Microsoft Corporation. Tous droits réservés.
C:\Wintools\rrd4j>java -version
java version "1.8.0_221"
Java(TM) SE Runtime Environment (build 1.8.0_221-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.221-b11, mixed mode)
And yes on the RPi3B, OH3.4.2-1 runs on Java 11
mu@Pivert:~$ java -version
openjdk version "11.0.18" 2023-01-17 LTS
OpenJDK Runtime Environment Zulu11.62+17-CA (build 11.0.18+10-LTS)
OpenJDK Client VM Zulu11.62+17-CA (build 11.0.18+10-LTS, mixed mode)
RRD File Inspector
It is just about the rrd viewer that runs with java 8. Not about OH3.
Just wanted to let you know that your solution worked for me with Openhab 4.3.3.
I have VSCode on Windows installed and called the inspector from its terminal.
To change values you have to enter them with a dot and not with a comma.
