Issue of the topic: I am using a tradfri motion sensor connected to openhab via Phoscon/Congbee binding to dimm two dimmable lights depending on the hour of the day. I want the light to be dimmed to 0 (turned off) after 5min of no motion detected. I tried with expire binding but failed. Turning on the lights with a different intensity works pretty good for every specified timeframe. But it simply does not turn off. As I am relatively new to the art of writing rules by hand, I most probably forgot something or missed a step during the setup of the rule. May I kindly ask the help of the community?
Please post configurations (if applicable):
Items configuration related to the issue:
This is the âflur.itemsâ file I created which includes the expire binding code:
Group:Dimmer Licht_im_Flur_5minOFF âLicht im Flur nach 5min offâ { expire=â5m,command=Offâ } // dimm Light to 0 after Xmin
Rules code related to the issue:
This is the âflur.rulesâ I created for this. Turning on the lights works. But does not expire as defined in âflur.itemsâ
rule âFlurlicht nach Bewegung und Zeitâ
Item BewegungsmelderFlurIKEAOfSweden_Presence changed from OFF
var Number hour = now.getHourOfDay
if ((hour >= 18) && (hour < 19 )) {
sendCommand(Licht_im_Flur_5minOFF, 30)
else if ((hour >= 19) && (hour < 20)) {
sendCommand(Licht_im_Flur_5minOFF, 50)
else if ((hour >= 20) && (hour < 22)) {
sendCommand(Licht_im_Flur_5minOFF, 80)
else if ((hour >= 22) && (hour < 0)) {
sendCommand(Licht_im_Flur_5minOFF, 40)
else if ((hour >= 0) && (hour < 6)) {
sendCommand(Licht_im_Flur_5minOFF, 20)
else if ((hour >= 6) && (hour < 8)) {
sendCommand(Licht_im_Flur_5minOFF, 60)
} // your logic here
Why this is a Group? I donât think this will work that way.
It is a group, because it holds the two dimmable lights. I read in the docs it is possible to define a dimmer group and so far the manual manipulation of the lights with sliders works. But I am open for suggestions. What approach would you chose to command the two lights?
command=OFF
I changed the âcommand=OFFâ. Thanks.
What is the â50â command here?
The 50 is the Number in Percent for the dimmable lights. It works. For avery timeframe there is a different dimming of the lights.
Attempting to link expire binding to a Group type Item used to throw an error at xxx.items file load time. Binding configuration of type 'expire' of item 'XXX' could not be parsed correctly.
Donât you get something like that?
While the expire binding could never be fully functional with Group Items - you could never update a Group state for example - there would be sensible use cases for using expire in âcommandâ mode wih a Group.
I think it simply does not work though, due to that validation error.
Curious. I just copy-paste your Group config into my working OH 2.5.0
(after fixing quotemarks) -
openhab.log
2020-04-26 20:22:31.056 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'doors.items'
2020-04-26 20:22:31.069 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'expire' of item 'Licht_im_Flur_5minOFF' could not be parsed correctly.
Yes, itâs a pretty standard use for createTimer.
Thanks for the hint. I stumbled across the Design Patter. Motion Sensor Timer already and thought I understood. This obviously was wrong. So I might need some more clarifications:
The pattern uses two items (Switch Occupancy1 and MotionDetector1) both expire after 5 min. Why? Can I use the Dimmable Light item directly to be switched if any motion is detected? Like this?
flur.items:
Dimmer Licht_im_Flur_amBad5minOFF âLicht im Flur am Bad nach 5min offâ { expire=â5m, 0â } // dimm Light to 0 after Xmin
Dimmer Licht_im_Flur_anKueche5minOFF âLicht im Flur an KĂŒche nach 5min offâ { expire=â5m, 0â } // dimm Light to 0 after Xmin
flur.rules:
if ((hour >= 11) && (hour < 19 )) {
sendCommand(Licht_im_Flur_amBad5minOFF, 30)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 30)
sendCommand(Licht_im_Flur_amBad5minOFF, 50)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 50)
sendCommand(Licht_im_Flur_amBad5minOFF, 80)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 80)
sendCommand(Licht_im_Flur_amBad5minOFF, 40)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 40)
sendCommand(Licht_im_Flur_amBad5minOFF, 20)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 20)
sendCommand(Licht_im_Flur_amBad5minOFF, 60)
Thread::sleep(100)
sendCommand(Licht_im_Flur_anKueche5minOFF, 60)
This is my actual setup as I changed according to your hint regarding the problem with expire and groups.
Edit: I changed all command=0 to 0. Now the light turns on at specified dimming level, but does not turn off after the 5 min defined in flur.items.
Because Rick has given you two examples of using the expire binding as a timer.
The design pattern contains multiple different solutions.
âSimple Example: Expire Binding Versionâ is unrelated to âSimple Example: Timers Versionâ and they use quite different techniques.
Your original problem revolved around the combination of choosing to use expire and using it with a Group, where it does not play nice.
You might now choose instead to use expire with âordinaryâ Items or use createTimer methods with a Group, itâs your choice.
I donât see anything immediately wrong with your current use of expire.
There is a flaw in your rule - else if ((hour >= 22) && (hour < 0)) {
those can never be true at the same time
Expire is a binding. You do have to install it. Maybe thatâs why you donât get an error message about use with Groups.
Thanks. I will go for the expire with ordinary items.
Thanks. I changed to âelse if ((hour >= 22) && (hour < 24))â
Indeed a good point. But I had it installed in the first place. It just does not show up under configuration>Bindings but in the Addons section of PaperUI it is marked as installed. Nevertheless. Just to be sure, I reinstalled it.
Iâve just realised that is not what you want.
If you default the expire action, you get a state update. Thatâs not a command.
You should see this action in your events.log
If you want a command, you must tell it. { expire="5m, command=0"}
Thatâs what I had used in a try and error test yesterday. But it lead to the lights not even being turned on any longer (when also used in the flur.rules file). As I modified it back to just 0 it worked again for turning on the light. For testing reasons I now modified it back to âcomman=0â in the flur.items file.
After reinstalling the expire binding cat events.log | grep expire gives me:
2020-04-24 10:36:01.706 [thome.event.ExtensionEvent] - Extension âbinding-expire1â has been installed.
2020-04-27 11:42:56.548 [thome.event.ExtensionEvent] - Extension âbinding-expire1â has been uninstalled.
2020-04-27 11:57:08.170 [thome.event.ExtensionEvent] - Extension âbinding-expire1â has been installed.
I also detached the dimmer items I previously had created for the things (dimmalbe bulbs) from the things so they are only connected to the dimmer item with { expire=â5m, command=0â}.
When your xxx.items file loads, you should get this error in your openhab.log
If you do not, the binding is not active
2020-04-27 11:33:42.202 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'doors.items'
2020-04-27 11:33:42.214 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'expire' of item 'testExpireBinding' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: The string 'rhubarb' does not represent a valid command for item testExpireBinding
No. The first installation was, as I guessed, on 24th right before I started taking on the automation with the motion sensor. After you mentioned there might be a problem with the installation I uninstalled it (27th 11:42) and reinstalled it (27th 11:57).
It works now with this setup:
flur.items:
Dimmer Licht_im_Flur_amBad5minOFF âLicht im Flur am Bad nach 5min offâ { expire=â1m, command=0â} // dimm Light to 0 after Xmin
Dimmer Licht_im_Flur_anKueche5minOFF âLicht im Flur an KĂŒche nach 5min offâ { expire=â1m, command=0â } // dimm Light to 0 after Xmin
flur.rules:
Thread::sleep(50)
Thread::sleep(50)
sendCommand(Licht_im_Flur_anKueche5minOFF, 90)
Thread::sleep(50)
sendCommand(Licht_im_Flur_amBad5minOFF, 90)
else if ((hour >= 22) && (hour < 24)) {
Thread::sleep(50)
Thread::sleep(50)
Thread::sleep(50)
