I tried the steps described in the topic already. I still get the same issue.
I am not on an SD card.
Well There is no entry in the log about the addon beeing uninstalled or installed but I found this in the logs:
2019-02-20 03:14:45.406 [ERROR] [rg.eclipse.smarthome.automation.core] - bundle org.eclipse.smarthome.automation.core:0.10.0.oh240 (199)[org.eclipse.smarthome.automation.core.internal.RuleRegistryImpl(277)] : The activate method has thrown an exception
at org.eclipse.smarthome.config.core.ConfigUtil.normalizeCollection(ConfigUtil.java:156) ~[?:?]
at org.eclipse.smarthome.config.core.ConfigUtil.normalizeType(ConfigUtil.java:78) ~[?:?]
at org.eclipse.smarthome.config.core.ConfigUtil.normalizeTypes(ConfigUtil.java:54) ~[?:?]
at org.eclipse.smarthome.config.core.Configuration.<init>(Configuration.java:78) ~[?:?]
at org.eclipse.smarthome.config.core.Configuration.<init>(Configuration.java:62) ~[?:?]
at org.eclipse.smarthome.automation.core.dto.ConditionDTOMapper.mapDto(ConditionDTOMapper.java:40) ~[?:?]
at org.eclipse.smarthome.automation.core.dto.ConditionDTOMapper.mapDto(ConditionDTOMapper.java:61) ~[?:?]
at org.eclipse.smarthome.automation.core.dto.RuleDTOMapper.map(RuleDTOMapper.java:37) ~[?:?]
at org.eclipse.smarthome.automation.core.ManagedRuleProvider.toElement(ManagedRuleProvider.java:60) ~[?:?]
at org.eclipse.smarthome.automation.core.ManagedRuleProvider.toElement(ManagedRuleProvider.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.lambda$0(AbstractManagedProvider.java:70) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:?]
at java.util.concurrent.ConcurrentHashMap$KeySpliterator.forEachRemaining(ConcurrentHashMap.java:3527) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.getAll(AbstractManagedProvider.java:74) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:378) ~[?:?]
at org.eclipse.smarthome.automation.core.internal.RuleRegistryImpl.addProvider(RuleRegistryImpl.java:410) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:128) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[?:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[?:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.activate(AbstractRegistry.java:99) ~[?:?]
at org.eclipse.smarthome.automation.core.internal.RuleRegistryImpl.activate(RuleRegistryImpl.java:149) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:334) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1162) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1576) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1014) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1801) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1053) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1007) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:161) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1116) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:997) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1025) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:964) ~[?:?]
2019-02-20 03:14:46.629 [WARN ] [rg.eclipse.smarthome.automation.core] - FrameworkEvent WARNING - org.eclipse.smarthome.automation.core
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
Only by rewriting them. They are completely different. This is also a good illustration for why it’s still called the “Experimental” NGRE. It would be helpful if you filed an issue on the openhab-core github repo.
That’s serious. One of the rule conditions configurations seem to contain a character or value that cannot be converted by the ConfigUtil class. But omg that should not pull down the entire engine.
Btw: That definitely need to be reported to the core github repository.
@salexes, would you mind posting or PMing your automation_rules.json file? I’d like to see if I can identify if something is corrupt, and possibly use it to recreate the issue while debugging.
Also, could you or a moderator please tag this thread with NGRE?
The issue was that @salexes had two rules using 'it is a certain day of the week’ Conditions, but the days were showing up in the file like this…
"days": [
"SAT",
"SUN",
null
I’ve corrected the file and waiting for a reply to confirm that the rules are working again. I can reproduce the problem by editing the json for one of my rules. How this occurred is unknown.
Another issue is that when I try to create a day of week trigger, I can’t select any days. There is already an issue created for this… https://github.com/eclipse/smarthome/issues/6670. I have modified my Regional Setings and tried multiple brownsers, but still can’t select days in order to test this further.
Well I created those rules when I was still on openhab 2.2 in chrome, back then the Weekday selection worked perfectly fine.
The really weird thing is that not every “certain day of the week” rule in the file had the entry “, null” in it. Also how was it still working and suddenly after restarting openhab it stopped working.
Can you amend the current bug report with that info? Thanks.
That is of course not a solution to the overall problem of basically no robustness for faulty rules in the automation bundle. We should probably add some tests that inject faulty rules on purpose.
