Hi there,
Can anybody help. Is there a way to activate or deactivate a rule from within another rule?
I have an application where, if this is possible, will make my programming much more elegant.
Thanks for the help.
Regards
Hi there,
Regards
Create a proxy item like Rule01_active.
You can set this item to on or off via another rule or manually in the sitemap.
Add an if statemant to your existing rule so it only gets executed when Rule01_active is on.
for a little more background see here:
In addition to Proxy Item, look at Design Pattern: Separation of Behaviors.
