I found interesting correlation about lag problem described at the beginning of this thread (often rules restart/reload and need to wait ~8 seconds).
I add log to System started:
[INFO ] [pse.smarthome.model.script.variables] - Event System started raised
Now I know more precisely when the reload happen. For this test I removed cyclic cron rule to force rules wakeup and be ready for real motion sensor events. So in the logs I can find correlation between System started event and [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED] which belongs to zwave danfoos LC-13 thermostat. Filtered log:
2020-05-03 18:54:50.971 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 18:54:59.743 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 18:59:43.617 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 18:59:52.305 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:04:36.233 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:04:44.733 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:09:28.818 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:09:36.824 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:14:21.409 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:14:29.911 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:19:14.067 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:19:22.784 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:24:06.644 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:24:14.618 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
2020-05-03 19:28:59.214 [INFO ] [veClimateControlScheduleCommandClass] - NODE 4 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-05-03 19:29:07.700 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
Further tests give me more facts:
- other communication with this device also causes rules restart (when i push middle button on thermostat to wake it up or set something in configuration (paperui/habmin) and save it)
- remove battery from this thermostat cause no rules reload takes place
So it looks like there is a problem with configuration of this device. @chris please take look at this.
I use openHab 2.5.4 Release build, updated today. This problem probably didn’t occur in openHab 2.3.
The zwave debug log after wakeup button press:
2020-05-03 22:18:54.950 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 49 84 18 10 04 08 04 80 46 81 72 8F 75 43 86 84 EF 46 81 8F 0D
2020-05-03 22:18:54.963 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=24, callback=132, payload=84 18 10 04 08 04 80 46 81 72 8F 75 43 86 84 EF 46 81 8F
2020-05-03 22:18:54.969 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=24, callback=132, payload=84 18 10 04 08 04 80 46 81 72 8F 75 43 86 84 EF 46 81 8F
2020-05-03 22:18:54.971 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-03 22:18:54.973 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2020-05-03 22:18:54.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2020-05-03 22:18:54.980 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=24, callback=132, payload=84 18 10 04 08 04 80 46 81 72 8F 75 43 86 84 EF 46 81 8F
2020-05-03 22:18:54.983 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 24: Application update request. Node information received. Transaction null
2020-05-03 22:18:54.985 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:54.988 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 24: Application update request. Requesting node state.
2020-05-03 22:18:54.990 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveDelayedPollEvent
2020-05-03 22:18:54.992 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling initialised at 1800 seconds - start in 175 milliseconds.
2020-05-03 22:18:54.994 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 24: Application update - no transaction.
2020-05-03 22:18:54.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:54.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:55.167 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling...
2020-05-03 22:18:55.169 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling zwave:device:77badcb7:node24:thermostat_setpoint_heating
2020-05-03 22:18:55.171 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 24: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2020-05-03 22:18:55.173 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 24: Creating new message for application command THERMOSTAT_SETPOINT_GET (Heating)
2020-05-03 22:18:55.175 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:55.178 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2020-05-03 22:18:55.180 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling zwave:device:77badcb7:node24:battery-level
2020-05-03 22:18:55.182 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 24: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2020-05-03 22:18:55.184 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:55.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2020-05-03 22:18:55.189 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling zwave:device:77badcb7:node24:time_offset
2020-05-03 22:18:55.191 [DEBUG] [ternal.converter.ZWaveClockConverter] - NODE 24: Generating poll message for COMMAND_CLASS_CLOCK endpoint 0
2020-05-03 22:18:55.193 [DEBUG] [.commandclass.ZWaveClockCommandClass] - NODE 24: Creating new message for command CLOCK_GET
2020-05-03 22:18:55.195 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:55.197 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_CLOCK is NOT required to be secured
2020-05-03 22:18:55.200 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling zwave:device:77badcb7:node24:alarm_general
2020-05-03 22:18:55.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 118 priority from Get to Immediate
2020-05-03 22:18:55.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2020-05-03 22:18:55.206 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 118 to queue - size 5
2020-05-03 22:18:55.208 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:55.211 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 119 priority from Get to Immediate
2020-05-03 22:18:55.213 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2020-05-03 22:18:55.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 119 to queue - size 6
2020-05-03 22:18:55.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:55.220 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 120 priority from Get to Immediate
2020-05-03 22:18:55.222 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2020-05-03 22:18:55.224 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 120 to queue - size 7
2020-05-03 22:18:55.227 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:55.247 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Is awake with 3 messages in the queue
2020-05-03 22:18:55.249 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Start sleep timer at 1000ms
2020-05-03 22:18:55.251 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-05-03 22:18:55.272 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:thermostat_setpoint_heating unlinked - polling stopped.
2020-05-03 22:18:55.277 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:battery-level unlinked - polling stopped.
2020-05-03 22:18:55.292 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:time_offset unlinked - polling stopped.
2020-05-03 22:18:55.301 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:alarm_general unlinked - polling stopped.
2020-05-03 22:18:55.310 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:thermostat_setpoint_heating linked - polling started.
2020-05-03 22:18:55.318 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:battery-level linked - polling started.
2020-05-03 22:18:55.321 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:time_offset linked - polling started.
2020-05-03 22:18:55.327 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Channel zwave:device:77badcb7:node24:alarm_general linked - polling started.
2020-05-03 22:18:55.333 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 24: Node Status event - Node is AWAKE
2020-05-03 22:18:55.751 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 3 Messages waiting, state DONE
2020-05-03 22:18:56.252 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 3 Messages waiting, state DONE
2020-05-03 22:18:56.254 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: No more messages, go back to sleep
2020-05-03 22:18:56.258 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 24: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2020-05-03 22:18:56.260 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:56.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2020-05-03 22:18:56.267 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@16c1154
2020-05-03 22:18:56.271 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 121 priority from Immediate to Immediate
2020-05-03 22:18:56.273 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2020-05-03 22:18:56.275 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 121 to queue - size 8
2020-05-03 22:18:56.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:56.283 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 18 03 43 02 01 25 50 C8
2020-05-03 22:18:56.287 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 0A 00 13 18 03 43 02 01 25 50 C8
2020-05-03 22:18:56.290 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-05-03 22:18:56.293 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-05-03 22:18:56.293 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 118: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.296 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 118: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-05-03 22:18:56.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.312 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-05-03 22:18:56.312 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-05-03 22:18:56.319 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.323 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.325 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 118: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.329 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.333 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 118: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.337 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.340 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2020-05-03 22:18:56.340 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 50 00 00 02 B9
2020-05-03 22:18:56.342 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 118: Advanced to WAIT_REQUEST
2020-05-03 22:18:56.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 118: Transaction not completed
2020-05-03 22:18:56.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.352 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=80, payload=50 00 00 02
2020-05-03 22:18:56.353 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-05-03 22:18:56.357 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=80, payload=50 00 00 02
2020-05-03 22:18:56.359 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 18 06 43 03 01 42 08 34 D6
2020-05-03 22:18:56.358 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 118: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.361 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.363 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 118: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 80
2020-05-03 22:18:56.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 06 43 03 01 42 08 34
2020-05-03 22:18:56.365 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 118: (Callback 80)
2020-05-03 22:18:56.367 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-05-03 22:18:56.369 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 118: callback 80
2020-05-03 22:18:56.371 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=80, payload=50 00 00 02
2020-05-03 22:18:56.373 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 80, Status = Transmission complete and ACK received(0)
2020-05-03 22:18:56.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 118: Advanced to WAIT_DATA
2020-05-03 22:18:56.378 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 118: Transaction not completed
2020-05-03 22:18:56.380 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 06 43 03 01 42 08 34
2020-05-03 22:18:56.382 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-03 22:18:56.383 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-05-03 22:18:56.385 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.386 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2020-05-03 22:18:56.388 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:56.389 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V1 THERMOSTAT_SETPOINT_REPORT
2020-05-03 22:18:56.391 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 24: Thermostat Setpoint report Scale = 0
2020-05-03 22:18:56.392 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 24: Thermostat Setpoint Value = 21
2020-05-03 22:18:56.394 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 24: Thermostat Setpoint Report, Type Heating (1), value = 21
2020-05-03 22:18:56.395 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveThermostatSetpointValueEvent
2020-05-03 22:18:56.397 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_THERMOSTAT_SETPOINT, value=21
2020-05-03 22:18:56.399 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:77badcb7:node24:thermostat_setpoint_heating to 21 °C [QuantityType]
2020-05-03 22:18:56.403 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-05-03 22:18:56.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18f01fd.
2020-05-03 22:18:56.407 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18f01fd.
2020-05-03 22:18:56.410 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:118 DONE
2020-05-03 22:18:56.412 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-05-03 22:18:56.415 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2020-05-03 22:18:56.419 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-03 22:18:56.421 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:56.425 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 18 02 80 02 25 51 09
2020-05-03 22:18:56.428 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 09 00 13 18 02 80 02 25 51 09
2020-05-03 22:18:56.432 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-05-03 22:18:56.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.430 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-05-03 22:18:56.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 119: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.440 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-05-03 22:18:56.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.447 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.449 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 119: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.451 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-05-03 22:18:56.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.454 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 119: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.457 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 51 00 00 02 B8
2020-05-03 22:18:56.458 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.460 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 119: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=81, payload=51 00 00 02
2020-05-03 22:18:56.461 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.464 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2020-05-03 22:18:56.466 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 119: Advanced to WAIT_REQUEST
2020-05-03 22:18:56.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 119: Transaction not completed
2020-05-03 22:18:56.469 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 18 03 80 03 30 5A
2020-05-03 22:18:56.470 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=81, payload=51 00 00 02
2020-05-03 22:18:56.471 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 119: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.474 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 80 03 30
2020-05-03 22:18:56.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.480 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 119: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 81
2020-05-03 22:18:56.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 119: (Callback 81)
2020-05-03 22:18:56.484 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-05-03 22:18:56.486 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 119: callback 81
2020-05-03 22:18:56.488 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=81, payload=51 00 00 02
2020-05-03 22:18:56.490 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 81, Status = Transmission complete and ACK received(0)
2020-05-03 22:18:56.493 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 119: Advanced to WAIT_DATA
2020-05-03 22:18:56.496 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 119: Transaction not completed
2020-05-03 22:18:56.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 80 03 30
2020-05-03 22:18:56.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-03 22:18:56.501 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-05-03 22:18:56.502 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.505 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2020-05-03 22:18:56.506 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:56.508 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2020-05-03 22:18:56.509 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 24: Battery report value = 48
2020-05-03 22:18:56.511 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-05-03 22:18:56.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=48
2020-05-03 22:18:56.514 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:77badcb7:node24:battery-level to 48 [DecimalType]
2020-05-03 22:18:56.518 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-05-03 22:18:56.520 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@37071d.
2020-05-03 22:18:56.522 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@37071d.
2020-05-03 22:18:56.523 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:119 DONE
2020-05-03 22:18:56.527 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-05-03 22:18:56.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2020-05-03 22:18:56.530 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-03 22:18:56.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.533 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:56.536 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 18 02 81 05 25 52 0C
2020-05-03 22:18:56.538 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 09 00 13 18 02 81 05 25 52 0C
2020-05-03 22:18:56.540 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-05-03 22:18:56.543 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-05-03 22:18:56.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.552 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-05-03 22:18:56.556 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 120: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.555 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.560 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 120: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-05-03 22:18:56.567 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 52 00 00 02 BB
2020-05-03 22:18:56.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 120: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=82, payload=52 00 00 02
2020-05-03 22:18:56.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 120: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.579 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.579 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 18 04 81 06 F6 12 8E
2020-05-03 22:18:56.581 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2020-05-03 22:18:56.583 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 120: Advanced to WAIT_REQUEST
2020-05-03 22:18:56.583 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 04 81 06 F6 12
2020-05-03 22:18:56.585 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 120: Transaction not completed
2020-05-03 22:18:56.588 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=SendData[19], type=Request[0], dest=0, callback=82, payload=52 00 00 02
2020-05-03 22:18:56.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 120: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 120: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 82
2020-05-03 22:18:56.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 120: (Callback 82)
2020-05-03 22:18:56.596 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-05-03 22:18:56.598 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 120: callback 82
2020-05-03 22:18:56.599 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=82, payload=52 00 00 02
2020-05-03 22:18:56.601 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 82, Status = Transmission complete and ACK received(0)
2020-05-03 22:18:56.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 120: Advanced to WAIT_DATA
2020-05-03 22:18:56.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 120: Transaction not completed
2020-05-03 22:18:56.608 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 04 81 06 F6 12
2020-05-03 22:18:56.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-03 22:18:56.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-05-03 22:18:56.613 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.615 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_CLOCK, endpoint 0
2020-05-03 22:18:56.616 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-05-03 22:18:56.618 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_CLOCK V1 CLOCK_REPORT
2020-05-03 22:18:56.619 [DEBUG] [.commandclass.ZWaveClockCommandClass] - NODE 24: Received clock report: niedziela 22:18
2020-05-03 22:18:56.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-05-03 22:18:56.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CLOCK, value=Sun May 03 22:18:56 CEST 2020
2020-05-03 22:18:56.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:77badcb7:node24:time_offset to 0 [DecimalType]
2020-05-03 22:18:56.628 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-05-03 22:18:56.630 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2bc774.
2020-05-03 22:18:56.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2bc774.
2020-05-03 22:18:56.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:120 DONE
2020-05-03 22:18:56.636 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-05-03 22:18:56.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2020-05-03 22:18:56.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-03 22:18:56.640 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:18:56.644 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 18 02 84 08 25 53 05
2020-05-03 22:18:56.647 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 09 00 13 18 02 84 08 25 53 05
2020-05-03 22:18:56.648 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-05-03 22:18:56.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 121: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.651 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-05-03 22:18:56.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.655 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-05-03 22:18:56.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.659 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-05-03 22:18:56.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-05-03 22:18:56.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 121: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.675 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 53 00 00 03 BB
2020-05-03 22:18:56.680 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-05-03 22:18:56.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=83, payload=53 00 00 03
2020-05-03 22:18:56.685 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2020-05-03 22:18:56.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 121: Advanced to WAIT_REQUEST
2020-05-03 22:18:56.689 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 121: Transaction not completed
2020-05-03 22:18:56.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=83, payload=53 00 00 03
2020-05-03 22:18:56.693 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.695 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-05-03 22:18:56.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 121: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 83
2020-05-03 22:18:56.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 121: (Callback 83)
2020-05-03 22:18:56.700 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-05-03 22:18:56.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 121: callback 83
2020-05-03 22:18:56.704 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=83, payload=53 00 00 03
2020-05-03 22:18:56.706 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 83, Status = Transmission complete and ACK received(0)
2020-05-03 22:18:56.708 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-05-03 22:18:56.710 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 121: Transaction COMPLETED
2020-05-03 22:18:56.711 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Response processed after 61ms
2020-05-03 22:18:56.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 121: Transaction completed
2020-05-03 22:18:56.715 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:121 DONE
2020-05-03 22:18:56.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-05-03 22:18:56.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 121: Transaction event listener: DONE: DONE ->
2020-05-03 22:18:56.718 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Went to sleep COMPLETE
2020-05-03 22:18:56.718 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-03 22:18:56.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-03 22:19:03.324 [INFO ] [pse.smarthome.model.script.variables] - Event System started raised
