Hey @Ferryb4
there are commands in the integration protocol to open doors and they have been implemented in 1.x version of the binding. However I did not move this feature to 2.x as there was no feedback regarding it.
I am adding this to my list, but I will need your help as I don’t have INT-R module.
Guys, good news. Event log feature has been merged into master and now it is available in OH 2.5 snapshot.
I hope to implement next feature from my list soon.
Is it true that I can not control any outputs from OH with this binding?
In DloadX my output is pulse(25) but i can not control this output from OH.
I used the items en things from from the docs.
That’s definitely not true. How did you come to this conclusion?
If you have everything configured properly on OH side, perhaps your user in Integra system does not have permission to control BI, MONO, TEL outputs?
For those interested in reading ATD-100 temperature I prepared a version with preliminary support for this device: Release Added ATD-100 support · druciak/org.openhab.binding.satel · GitHub. Try and let me know if this is working at all. You would need this device manualy as it cannot be detected automatically.
Sorry it was indeed a problem with the rights in dloadx.
It works perfectly now.
I’m only getting the log going.
I tried it through the paperui and via the things file from the documents, but I do not get anything out of this.
The user has access to the log in dloadx
Is OH the only client connecting to ETHM-1? The module accepts only one connection, so make sure you don’t have another client (for instance OH 1.x) connected to it.
Next double check your configuration. Do you have encryption enabled? If yes, please double check if this is done on both sides (OH and DloadX), and on both sides you have the same encryption key.
You could also disconnect ethernet cable for a moment in case your ETHM-1 hung up on an old connection.
Thank you @druciak. I tested with and without encryption but after removing and re-adding the ETHM-1 module in OpenHAB it suddenly worked. Maybe the same as I saw in the previous replies about the internal OpenHAB database where something about the encryption is stored and cannot be changed.
Anyway, it works now. Great binding and also perfect how everything is discovered automatically.
Hello all,
I have built a new version of the binding. It contains following changes:
new channels for wireless devices; zone and output now have new configuration parameter ‘wireless’ - when set to ‘true’, the thing will have “Low battery” and “No communication” channels,
new thing type ATD-100 for wireless temperature sensor.
Hi all,
A silly question about satel integration: I would like to integrate my Satel alarm system with openHAB and use alarm motion sensors to control lights. Will the binding receive all the zone notifications even if the alarm is disarmed?
