I’m coming close to giving up here. I’m using OH3.
My plan is simple: save the current time upon change (in an item); next change, compare and do things
I’m finding all sorts of info but it would seem the OH2 code no longer works for OH3.
First, how do I save the current time to an Item which later on I can use for comparing?
How do I compare if three hours have passed since latest update?
Do I save this as a number (seconds since epoch) and then compare it later?
Do I use this DateTimeType thing?
This all seems a bit overly complex for a reasonably common question I presume.
That doesn’t solve my issue or either I’m missing it but.
How do I compare a date stored in an item.
And what kind of item would I use, datetime, number for seconds…
I get I could use now.isBefore but that doesn’t work with for example mydatetimeitem.state.
