so far:
sudo openhabian-config.
go to #24, install influxdb+grafana (it will tell to go to this post: InfluxDB+Grafana persistence and graphing )
its asking me to install locally or use existing instance.
no idea what to pick so i try the first one. Install locally.
enter passwords for a few times. I enter all the same password for each of them.
Shall influxDB be configured with Openhab? I select Yes
downloading…
Operation Succesful!
OK.
If this is all correct, how can we add this into the tutorial so that others can benefit from this as well?,
[22:52:12] openhabian@openHABianPi:~$ sudo openhabian-config
2018-12-25_22:53:17_EET [openHABian] Checking for root privileges… OK
2018-12-25_22:53:17_EET [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2018-12-25_22:53:18_EET [openHABian] openHABian configuration tool version: [master]v1.4.1-430(67ea550)
2018-12-25_22:53:18_EET [openHABian] Checking for changes in origin… OK
2018-12-25_22:53:23_EET [openHABian] Setting up InfluxDB and Grafana…
Installing InfluxDB…
$ apt -y install apt-transport-https
Reading package lists… Done
Building dependency tree
Reading state information… Done
apt-transport-https is already the newest version (1.4.8).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
–2018-12-25 22:57:34-- https://repos.influxdata.com/influxdb.key
Resolving repos.influxdata.com (repos.influxdata.com)… 2600:9000:2074:1200:7:7790:e740:93a1, 2600:9000:2074:7800:7:779 0:e740:93a1, 2600:9000:2074:ca00:7:7790:e740:93a1, …
Connecting to repos.influxdata.com (repos.influxdata.com)|2600:9000:2074:1200:7:7790:e740:93a1|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 3108 (3.0K) [application/pgp-keys]
Saving to: ‘STDOUT’
2018-12-25 22:57:34 (76.7 MB/s) - written to stdout [3108/3108]
OK
$ apt update
Hit:1 Index of /debian stretch InRelease
Hit:2 Index of /raspbian stretch InRelease
Ign:3 http://repos.azulsystems.com/debian stable InRelease
Hit:4 http://repos.azulsystems.com/debian stable Release
Get:5 InfluxData - Package Repository stretch InRelease [4,732 B]
Ign:6 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Hit:7 https://deb.nodesource.com/node_8.x stretch InRelease
Hit:8 https://dl.bintray.com/openhab/apt-repo2 stable Release
Get:10 InfluxData - Package Repository stretch/stable armhf Packages [918 B]
Fetched 5,650 B in 2s (1,928 B/s)
All packages are up to date.
$ apt -y install influxdb
The following NEW packages will be installed:
influxdb
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 43.0 MB of archives.
After this operation, 93.2 MB of additional disk space will be used.
Get:1 InfluxData - Package Repository stretch/stable armhf influxdb armhf 1.7.2-1 [43.0 MB]
Fetched 43.0 MB in 39s (1,101 kB/s)
Selecting previously unselected package influxdb.
(Reading database … 46236 files and directories currently installed.)
Preparing to unpack …/influxdb_1.7.2-1_armhf.deb …
Unpacking influxdb (1.7.2-1) …
Setting up influxdb (1.7.2-1) …
Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
Processing triggers for man-db (2.7.6.1-2) …
Updating FireMotD available updates count … 2018-12-25 22:58:40,519: FireMotD: Error: Template folder doesn’t exist. U pgrading from an older version? Please run make again or run the install function “FireMotD -I -v”.
$ systemctl daemon-reload
$ systemctl enable influxdb.service
$ systemctl restart influxdb.service
OK Configure InfluxDB admin account… {“results”:[{“statement_id”:0}]}
OK Configure listen on localhost only…
$ sed -i -e /^# Determines whether HTTP endpoint is enabled./ { n ; s/^# enabled = true/enabled = true/ } /etc/influxdb/ influxdb.conf
$ sed -i s/# bind-address = “:8086”/bind-address = “localhost:8086”/g /etc/influxdb/influxdb.conf
$ sed -i s/# auth-enabled = false/auth-enabled = true/g /etc/influxdb/influxdb.conf
OK
Setup of inital influxdb database and InfluxDB users… {“results”:[{“statement_id”:0}]}
OK Installing Grafana…
$ wget https://s3-us-west-2.amazonaws.com/grafana-releases/release/grafana_5.3.4_armhf.deb
–2018-12-25 22:59:07-- https://s3-us-west-2.amazonaws.com/grafana-releases/release/grafana_5.3.4_armhf.deb
Resolving s3-us-west-2.amazonaws.com (s3-us-west-2.amazonaws.com)… 52.218.144.72
Connecting to s3-us-west-2.amazonaws.com (s3-us-west-2.amazonaws.com)|52.218.144.72|:443… connected.
Length: 27059330 (26M) [application/x-debian-package]
Saving to: ‘grafana_5.3.4_armhf.deb’
grafana_5.3.4_armhf.deb 100%[========================================================================================================================================>] 25.81M 393KB/s in 42s
2018-12-25 22:59:50 (633 KB/s) - ‘grafana_5.3.4_armhf.deb’ saved [27059330/27059330]
$ apt update
Ign:2 http://repos.azulsystems.com/debian stable InRelease
Hit:3 Index of /raspbian stretch InRelease
Hit:5 InfluxData - Package Repository stretch InRelease
Hit:6 https://deb.nodesource.com/node_8.x stretch InRelease
Ign:7 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
$ apt-get install -y adduser libfontconfig
Note, selecting ‘libfontconfig1’ instead of ‘libfontconfig’
adduser is already the newest version (3.115).
libfontconfig1 is already the newest version (2.11.0-6.7).
libfontconfig1 set to manually installed.
$ dpkg -i grafana_5.3.4_armhf.deb
Selecting previously unselected package grafana.
(Reading database … 46262 files and directories currently installed.)
Preparing to unpack grafana_5.3.4_armhf.deb …
Unpacking grafana (5.3.4) …
Setting up grafana (5.3.4) …
Adding system user grafana' (UID 112) ... Adding new user grafana’ (UID 112) with group grafana' ... Not creating home directory /usr/share/grafana’.
NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
sudo /bin/systemctl daemon-reload
sudo /bin/systemctl enable grafana-server
You can start grafana-server by executing
sudo /bin/systemctl start grafana-server
Processing triggers for systemd (232-25+deb9u6) …
$ systemctl enable grafana-server.service
Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable grafana-server
Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /usr/lib/systemd/system/grafana-server.service.
$ systemctl start grafana-server.service
OK
Updating Grafana admin password…{“message”:“User password updated”}OK Updating Grafan configuration…
$ sed -i -e /^# disable user signup / registration/ { n ; s/^;allow_sign_up = true/allow_sign_up = false/ } /etc/grafana/grafana.ini
$ sed -i -e /^# enable anonymous access/ { n ; s/^;enabled = false/enabled = true/ } /etc/grafana/grafana.ini
$ systemctl restart grafana-server.service
Connection Grafana to InfluxDB…{“datasource”:{“id”:1,“orgId”:1,“name”:“openhab_home”,“type”:“influxdb”,“typeLogoUrl”:“”,“access”:“proxy”,“url”:“http://localhost:8086”,“password”:“xxxx”,“user”:“”,“database”:“openhab_db”,“basicAuth”:true,“basicAuthUser”:“”,“basicAuthPassword”:“xxxxx”,“withCredentials”:false,“isDefault”:false,“secureJsonFields”:{},“version”:1,“readOnly”:false},“id”:1,“message”:“Datasource added”,“name”:“openhab_home”}Adding openHAB dashboard tile for Grafana… 2018-12-25_23:00:33_EET [openHABian] Adding an openHAB dashboard tile for ‘grafana’… OK
Adding install InfluxDB with database configuration to OpenHAB
$ touch /etc/openhab2/services/influxdb.cfg
2018-12-25_23:01:55_EET [openHABian] Checking for default openHABian username:password combination… FAILED
2018-12-25_23:01:56_EET [openHABian] We hope you got what you came for! See you again soon
