Selection items with mappings in NEW OH3 UI
Hello everyone,
first of all i would like to give a feedback to the new UI: I think its a great idea to create a new UI with a fresh design an “more” options. But… the learning curve is really steep for a normal user ( not beginner ). So far that its getting pretty frustrating.
I would like if the normal widgets have more options for costumizations without the need to programm a whole widget on myself.
Anyways…
My reason for posting is that i cant figure out how to create sth. like a selection item like in the old basic ui. So 2 or more buttons clickcable for the same text item.
I cant believe there is no option to do that in the UI? Please show me the way how to do.
At least i want to give a big thank you to the programmers who spend their time on this project.
Like this
Thanks. Helps alot.
You should be able to do this without having to create your own widget.
In your Item:
  • Click Add Metadata
  • Click State Description
  • In the Options field set out your options. For example, for a Number Item:
1=Blue
2=Red
3=Yellow
Once saved, clicking on the Item’s widget in the UI should then show a selection list.
It is a bit different than the mappings parameter in a Sitemap. And if you want clickable buttons rather than a list to select from (you kind of mention both) then I think you will have to create your own widget.
Ohh interesting. Also thanks alot. Seems to work for now
