I’ve created an unboxing, installation and testing video covering the new and very nice door & window sensor called Strips, from Sensative. Anyone who is about to buy some magnetic sensors should really have a look at this new one as it’s just… cool
Unfortunately not yet. On the positive side they just opened a branch of Kjell & Company in my town - and they have Sensative Strips in their catalogue. On the negative side they are not currently in stock so I need to wait some more. I hope to have them in hand by Christmas, though.
I just got two of those nice Strips, but I cannot manage to install them properly.
I use OpenHab 1.9. I only have the Aeon Z-stick gen 5 and two strips in the network. The two strips are sending signals to the controller, but I can only read the CLOSED signal. And the Strips show up as dead in Habmin (1.5), even though I can remove that status by opening and closing them.
Furthermore, the Strips are not recognized in Habmin.
I haven’t specified the command class like that, but Sensative called me today and they said they didn’t use command classes (or something).
However, I tried configure it like you have and it made no difference for me.
This leaves us the only answer, which is the configuration parameter 1, which I still have in default setting (which is 1, I beleive).
What do you use to set that parameter? I’ve tried Habmin on Openhab 1.7 and 1.8 but the Strips wont be recognized in Habmin. I’ve tried InControl as well, but that didn’t work either.
That would be strange - command classes are a fundamental part of the protocol…
Can you provide a debug log of what’s happening - if HABmin is showing the device is DEAD, then there’s something fundamentally wrong with communications…
Please note you will need the zwave addon from around mid November (or later) to have openHAB supporting Strips. If you haven’t downloaded a new zwave addon since then, pay https://openhab.ci.cloudbees.com/job/openHAB/ a visit.
Once you are using the new zwave addon you should see Strips when using HABmin and you are able to set the config parameter #1 to value 0, which is what I had to do to get it working.
When I think about, it might be that they didn’t use any specific command. The command I can see when I run OpenHab i debug mode is Alarm. And that is what he said that they are using. I think.
Note that I have about two days z-wave experience and that I did not talk to a tech person at Sensative
HABmin can’t provide you information about configuration etc until the device has initialised. Currently, the binding has not been able to initialise the device, so HABmin can’t provide much information.
Thanks for the logs - I’ll take a look tomorrow morning…
