Thank you for your reply Markus!
Sorry, mentioning of Shelly 1 was of course not correct here… The Dimmer 2 reports the current power consumption just fine so it does have a power meter.
All devices were currently turned off while I requested the status but they were online for a couple of days/weeks and thus should be reporting something. I downloaded the latest DEV build about two days ago.
This is the output for a Plug-S:
{"wifi_sta":{"connected":true,"ssid":"amft-home","ip":"10.9.0.30","rssi":-76},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":2803,"has_update":true,"mac":"E09806B4CDA5","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"source":"input"}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"temperature":31.71,"overtemperature":false,"tmp":{"tC":31.71,"tF":89.08, "is_valid":true},"update":{"status":"pending","has_update":true,"new_version":"20210318-141150/v1.10.0-geba262d","old_version":"20210115-103659/v1.9.4@e2732e05"},"ram_total":51040,"ram_free":38192,"fs_size":233681,"fs_free":161895,"uptime":174938}
Shelly 2.5:
{"wifi_sta":{"connected":true,"ssid":"amft-home","ip":"10.9.0.20","rssi":-51},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":3257,"has_update":false,"mac":"68C63AF91AFD","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"http","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":1,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":52.28,"overtemperature":false,"tmp":{"tC":52.28,"tF":126.11, "is_valid":true},"temperature_status":"Normal","update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20210115-103025/v1.9.4@e2732e05"},"ram_total":49368,"ram_free":33924,"fs_size":233681,"fs_free":119727,"voltage":229.89,"uptime":251065}
Dimmer 2:
{"wifi_sta":{"connected":true,"ssid":"amft-home","ip":"10.9.0.10","rssi":-53},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":25494,"has_update":false,"mac":"D8BFC019F402","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"source":"http","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":100}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true, "timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":1,"event":"L","event_cnt":53},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":43.74,"tF":110.74, "is_valid":true},"calibrated":true,"calib_progress":0,"calib_status":0,"calib_running":0,"wire_mode":1,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20210211-130125/v1.9.5-DM2_autocheck@a99a156a"},"ram_total":48704,"ram_free":36048,"fs_size":233681,"fs_free":111193,"uptime":1902424}
