Thanks for the quick reply. All dw2 are on firmware v1.9.4/20210115 as proposed by the Shelly Manager (btw. thanks for this great diagnosis tool).
I’ll check with the new firmware as soon as its published.
Allterco is release 1.10. This includes a lot of fixes and new features for all devices, details could be found here: API Reference. The description is technical / on the API level. Nevertheless I could say that many things have fixed, WiFi connectivity has been improved, Dimmer2 setup became easier etc.
Be careful upgrading your devices. A new major release could always create some backward compatibility issues working together with the binding. I didn’t had the time to do intense testing, there where various release candidates last week and it was hard to catch-up.
Please help on getting a status of 1.10+latest DEV build, include device type and firmware version details (Shown in Shelly Manager) on bug reports.
There are also some new features I’ll integrate into the binding during the next days, but first focus on compatibility.
…which is little bit different from my other dw2 where I receive the following:
2021-03-18 09:50:21.635 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@1402420286 name: 'shellydw2-yyyyy._http._tcp.local.' address: '(null):0' status: 'DNS: JmDNS-/192.168.178.87 [/192.168.178.87] state: probing 1 task: null', has NO data shellydw2-yyyyy._http._tcp.local.: ]
I recognized that the device xxxxx has entries with two different JmDNS addresses 87 & 54 while the functional device yyyyy has 87 only.
“192.168.178.87” is the Wi-Fi address of NUC where OH is located and 54 is the LAN IP of the NUC…
Could it be that:
The other dw2 are communicating with my OH using the Wi-Fi as they are close enough
The dw2 with the issue is using the mesh AP and thus communicates via LAN and in parallel with Wi-Fi
Please let me know if this helps or if I should try something else…
Ok, so I’ve updated to the dev binding, and the device is added via paper ui (rather than thing file). I should probably figure our if CoIot/Coap is getting through as openhab is docker, and shelly in in a different vlan for iot devices.
Should the shelly manager work in my normal openahb instance on port 8080, or do I need to change it’s port (and recreate the container) to set another port for it? as I get a 404 to http://openhab:8080/shelly/manager, with my openhab dashboard being http://openhab:8080/start/index
Oh…I may have just got updates working…I went into paper ui to the thing defintion and turned on Enable Sensor Events, I guess I assumed this might have been turned on by default
I have added Shelly1PM to Shelly network, upgraded the firmware and now I can add it to OH3. I cant see it in the Inbox. all other Shellys, which I added earlier (1+ months) are working fine.
What should I do to add it to OH3?
Tried:
OH Reboot
Shelly reboot
ColoT on/off in the binding
Autodiscovery on on Shelly
So the device wakes up and gets discovered by openhab, but then nothing else seem to happen. And the temperature in openhab hasn’t updated since I forcilbly woke the device up earlier.
If if turn on mqtt, will it turn of the coap/coIot updates?
Go to the OH Network Settings and select the interface you want to use. Having both interfaces active might cause issues (just an assumption).
Open the device UP, there is a section Settings->COAP
enter the OH ip address → sets unicast
leave empty → sets Multicast
You should prefer Unicast if there is no reason for Multicast
This is not just a hint. I would expect that you activated password protection for the device. 2nd indicator is the device name incl. shellydevice rather than the device type.
Please check device UI. You could set the credentials in the binding settings (default) or thing config (per thing). When using binding settings you should delete and re-discover the thing(s).
I don’t see a wakeup. This shows regular initialization.
The binding does not process any mqqt traffic
Use Shelly Manager to check if you see CoIoT packets for the device.
If you are using firmware 1.10 try to set Settings->COAP to OH ip, this activates CoIoT Unicast and might bypass issues with network routing when using Multicast.
Those log entries are what the binding puts out when the device come back online…even though openhab has a thing entry already. And then the device goes back to sleep without any item updates
Yes I understand that, I would make an mqtt item to get the temperature. Just wanting to confirm if the device would still work with the binding as well?
See my previous replies re: shelly manager. With the .13 Dev snapshot, should I be able to see something at http://openhab:8080/shelly/manager? Or do I have to something or install something to get shelly manager working? If I go to that link I get a 404 not found error.
Initialisation of the binding? I can show that, but if the device it not awake to report a value, it just sits as unknown.
So I have a longer log here…I have a ping running as well and just moved the device to a warm spot, so it should wake up every 0.5 degree to report it’s temperature. But you can see from this log snipping a long period of nothing, then when I moved it to a warm spot it woke up to report a sensor reading…this is NOT from pressing the action button…is there a different method for a sensor report?
It was awake for about 20 seconds (I can see from teh ping) then went offline again.
2021-03-20 08:30:07.345 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:30:07.346 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:30:10.338 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:31:13.344 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:31:13.346 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:31:16.338 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:32:19.345 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:32:19.346 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:32:22.338 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:33:25.346 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:33:25.347 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:33:28.338 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:34:31.345 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:34:31.368 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:34:34.345 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:35:37.352 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:35:37.353 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:35:40.344 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:36:43.353 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:36:43.355 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:36:48.357 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:37:51.395 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:37:51.396 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:37:52.349 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:38:55.356 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:38:55.357 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:38:58.349 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:40:01.356 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:40:01.358 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:40:04.348 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:41:07.414 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:41:07.415 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:41:10.359 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:42:13.365 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:42:13.366 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:42:16.359 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:43:19.366 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:43:19.367 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:43:22.362 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:44:25.542 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:44:25.543 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:44:28.359 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:45:31.365 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:45:31.366 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:45:36.368 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:46:39.378 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:46:39.400 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:46:40.368 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:47:43.375 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:47:43.376 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:47:46.371 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:48:49.397 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:48:49.399 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:48:52.369 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:49:55.377 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:49:55.378 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:49:58.369 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:51:01.375 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:51:01.376 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:51:04.378 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:52:07.386 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:52:07.387 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:52:10.379 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:53:13.385 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:53:13.386 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:53:13.393 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:54:16.401 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:54:16.402 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:54:19.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:55:22.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:55:22.397 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:55:25.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:56:28.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:56:28.397 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:56:31.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:57:34.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:57:34.397 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:57:37.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:58:40.395 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:58:40.414 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:58:43.391 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 08:59:46.417 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 08:59:46.418 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 08:59:49.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:00:52.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:00:52.397 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:00:55.389 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:01:58.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:01:58.397 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:02:01.388 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:03:04.396 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:03:04.398 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:03:04.408 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:04:07.416 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:04:07.435 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:04:10.424 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:05:13.432 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:05:13.434 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:05:16.425 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:06:19.435 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:06:19.436 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:06:22.419 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:07:25.426 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:07:25.427 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:07:28.428 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:08:31.438 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:08:31.449 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:08:34.432 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:09:37.438 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:09:37.439 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:09:40.429 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:10:43.436 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:10:43.437 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:10:46.432 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:10:52.084 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellyht-74e3d3: Shelly device discovered with empty IP address (service-name=[ServiceInfoImpl@1773926315 name: 'shellyht-74E3D3._http._tcp.local.' address: '(null):0' status: 'DNS: JmDNS-/192.168.10.27 [/192.168.10.27] state: probing 1 task: null', has NO data
shellyht-74E3D3._http._tcp.local.: ])
2021-03-20 09:10:52.093 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyht-74e3d3: Shelly device discovered: IP-Adress=192.168.100.38, type=shellyht
2021-03-20 09:10:52.121 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/settings
2021-03-20 09:10:52.220 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP Response 200: {"device":{"type":"SHHT-1","mac":"242424","hostname":"shellyht-74E3D3","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellyht-74E3D3","key":""},"wifi_sta":{"enabled":true,"ssid":"IOT","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"mqtt:1883","user":"","id":"ht-01","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":">B/eeV","name":"SHELLY-HT-01","fw":"20210318-140427/v1.10.0-geba262d","discoverable":false,"build_info":{"build_id":"20210318-140427/v1.10.0-geba262d","build_timestamp":"2021-03-18T14:04:27Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":false},"timezone":"Pacific/Auckland","lat":999,"lng":999,"tzautodetect":true,"tz_utc_offset":46800,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["report_url","temp_over_url","temp_under_url","hum_over_url","hum_under_url"]},"sensors":{"temperature_threshold":0.5,"temperature_unit":"C","humidity_threshold":5.0},"sleep_mode":{"period":12,"unit":"h"},"external_power":0,"temperature_offset":0.0,"humidity_offset":0.0}
2021-03-20 09:10:52.231 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyht-74e3d3: Shelly settings : {"device":{"type":"SHHT-1","mac":"242423424","hostname":"shellyht-74E3D3","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellyht-74E3D3","key":""},"wifi_sta":{"enabled":true,"ssid":"IOT","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"mqtt:1883","user":"","id":"ht-01","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":">B/eeV","name":"SHELLY-HT-01","fw":"20210318-140427/v1.10.0-geba262d","discoverable":false,"build_info":{"build_id":"20210318-140427/v1.10.0-geba262d","build_timestamp":"2021-03-18T14:04:27Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":false},"timezone":"Pacific/Auckland","lat":0999,"lng":999,"tzautodetect":true,"tz_utc_offset":46800,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["report_url","temp_over_url","temp_under_url","hum_over_url","hum_under_url"]},"sensors":{"temperature_threshold":0.5,"temperature_unit":"C","humidity_threshold":5.0},"sleep_mode":{"period":12,"unit":"h"},"external_power":0,"temperature_offset":0.0,"humidity_offset":0.0}
2021-03-20 09:10:52.232 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellyht-74e3d3: thingType=shellyht, deviceType=SHHT-1, mode=<standard>, symbolic name=SHELLY-HT-01
2021-03-20 09:10:52.233 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyht-74e3d3: Adding Shelly SHELLY-HT-01, UID=shelly:shellyht:74e3d3
2021-03-20 09:11:50.111 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:11:50.112 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:11:50.282 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:12:53.294 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@1302362264 name: 'shellyht-74E3D3._http._tcp.local.' address: '(null):80' status: 'DNS: JmDNS-/192.168.10.27 [/192.168.10.27] state: probing 1 task: null', has NO data, empty]
2021-03-20 09:12:53.308 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:12:53.309 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:12:56.281 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
2021-03-20 09:13:59.363 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Updating status
2021-03-20 09:13:59.364 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyht-74e3d3: HTTP GET for http://192.168.100.38/status
2021-03-20 09:14:02.279 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyht-74e3d3: Ignore API Timeout for battery powered device
I had set openhab to Update internal of 65 seconds and enable CoIot Events and Enable sensor events.
So further to this…finally after 24 hours the device seemed to be awake for that reporting period when openhab was polling for a value. Does that mean I should have the update internal to less that 65 seconds. Does that have any impact on the openhab machine?
After changing it to 10 seconds (and having moved device to somewhere warm where it’s triggering a sensor report), it’s now working. But if the device is only going to report temps say every hour, openhab it trying to hit it every 10 seconds, seems a little inefficient.
I asked this a couple of weeks ago but since this is still not working for me I’m wondering why this only seems to be an issue for me: I always get 0 from the total power and last minute power channels. I’m on the latest DEV build and I see the same behaviour for Shelly 1, 2.5, Dimmer 2 and Plug-S. Has anyone got any ideas what could be wrong?
Hi, I controlled a dimmer2 with an I3.
I3 trigger is going well
I have pinned the button directly on the dimmer2 and the triggers of the dimmer2 do not work. Neither ‘button’ nor ‘button1’ or ‘button2’.
What’s wrong? The i3 trigger is shown in the log… From Dimmer2 buttons nothing is shown
In the webui is set detached.
When I set one button mode, the switch works.
could you a bit more clear, because as far as i know the dimmer doesn’t really have ‘buttons’ it has readable input and controllable outputs not controllable inputs
