In openHAB 3, it’s working fine!.. very strange, because I didn’t changed anything on my 2.5 setup.
I also tried the DEV version first (I want to connect my UNI), but I get an error when putting the .jar file (I first stoped OH, added californium-core-2.0.0 & element-connector-2.0.0 and started OH again without errors):
2021-04-13 17:53:30.296 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.binding.shelly-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.shelly [291]
Unresolved requirement: Import-Package: org.osgi.framework; version=“[1.9.0,2.0.0)”
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
My OH3 setup is running on Docker, my 2.5 setup on a Pi.
They are working on updating the core components of the framework, in fact Karaf with OSGi. That means even I didn’t changed my code the build environment puts in dependencies on newer component versions than 3.0/3.1M1…3 have. Let me try to work around. Switching back to an older build environment should fix that issue, but I need to think of a proper way to keep backward compatibility. Having 3 versions (2.5.x, 3.0 and 3.1 latest) is no option.
Well, 3.0 build hopefully will not be needed anymore, after OH 3.1 stable release. Till then, temporary building of shelly binding in 3.0.x environment should be solution?
Damn should have come here first. Have the same error as well, after updating a friend’s installation to test issues with another binding. I suspected cache problems and cleaned out all bindings and cache, then added them again. Didn’t help. But if it’s a general 3.1m3 problem, I’ll just wait. Or is there an older version I could fall back to?
2021-04-15 22:12:14.593 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.shelly-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.shelly [208]
Unresolved requirement: Import-Package: org.osgi.framework; version="[1.9.0,2.0.0)"
2021-04-15 23:49:49.207 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.shelly-3.1.0-SNAPSHOT.jar
Yes, as Daniel said, still indeed the same error with 3.1.0.202104061052 build of binding.
Just let me add that my version of OH is a stable release build 3.0.1. May be upgrade to 3.1.0.M3 is needed?
Anyone know why the RGBW2 (COLOR MODE) channel description is gone from the official Shelly Binding page on OH website now? I see White mode, but no color mode any longer…
Which is correct as per the “V2” binding page, but nothing happens with that channel. When i send an ON or OFF command, i see in the log:
2021-04-17 21:15:03.752 [ome.event.ItemCommandEvent] - Item 'play_strip_sw' received command ON
2021-04-17 21:15:03.760 [nt.ItemStatePredictedEvent] - play_strip_sw predicted to become NULL
I’m using DEV build 2.5.13 . Any suggests on what i’m doing wrong here
Cheers!
Please try the latest DEV build. It should create a channel control#power. Maybe you need to delete and re-discover the thing. Please try first within PaperUI before defining in the .things file.
You should see a message “Switch light xx” (ON/OFF) in the log if you enable DEBUG, You’ll also find the link to the matching README below.
Was having some problems with the motion sensor not responding again, but after a factory reset it seems to work again for now. Since the internal webserver wasn’t reachable either, this has to be something else.
Good morning together,
I tried figuring out my issue by cross reading this thread, but didn’t find a solution yet.
Any quick approach for my issue would be highly appreciated.
Here is my setup:
Raspberry with Openhab 3.
Shelly Binding 3.0.1, yesterday switched to latest DEV 3.1.
Different Shelly’s in use, one of them in detached mode.
Shellys with each newest firmware.
Issue:
I’m using the input#relay or last event channels to control some lights. That was working for me over the last months with small delays (<2sec.).
Since 2 days, the delay until Openhab receives input relay status increased to roughly 10-20 seconds.
No changes to the setup were made.
I yesterday tried to install the DEV built and I factory reset yes the Shelly 1. I ensured coloT with mcast being activated.
Autodiscovery doesn’t work, shellys are recognized by manual adding over IP.
The delay remains after installing new binding and factory reset.
Any idea what to try next?
Might there be some data to delete on the raspberry (cache files,…) from the binding?
Controlling the shellys over Openhab works flawlessly and with no delay.
Highly appreciate your answers,
Best wishes, Christian
I’m having the same issue as Christian, my config:
Raspberry Pi 3 with Debian Buster
Openhabian / Openhab 3.01
Shelly binding version 3.1.0.202104211647
same delay issue on a Shelly i3 with firmware version 1.9.4: it takes about 20-40 seconds to get the updated status in Openhab while on the Shelly site, the update is shown instantly.
I didn’t see anything specific in the logs in DEBUG mode.
I now somehow got it fixed.
I remember that I deactivated and activated CoIoT several times in the Shelly interface. Additionally I set a device name and enabled the discoverable option. Now at least for the moment I get immediate response within Openhab.
I’ll try the same with my Shelly i3 tomorrow and let you know whether I also got it fixed.
you could use Shelly Manager (see README on how to launch) and check if the binding is receiving CoIoT messages, these is also an action to switch btw CoIoT Multicast and Peer mode
