just linking this post here if some of the shelly cracks here have a good solution for channel-based triggers
Hey Markus,
are you still using this rule?
How do you get the name of the triggering channel?
AFAIK there is only receivedEvent
available as implicit variable
My I ask where is Shelly Manager. I am total beginner.
/shelly/manager behind your openhab URL
There is documentation
Try updated DEV build - I made a change, but wonât expect that this changes anything
What is the output in events.log. If I read the DEBUG log correctly the binding receives the event and updates the channel, I canât see if the item is updated (thatâs handled by the framework)
Latest DEV builds: 2.5.13 - 3.1.0 - README - Installation - Avdanced Users - Shelly Manager - Bugs/Features - Firmware Index - Firmware Archive - API Doc
Note: The DEV build is always newer than the version in the official Distro or the Milestone builds (SNAPSHOTs); OH Distro 2.5 will not receive updates anymore, so you have to switch to DEV build when running OH 2.5, see installation notes.
I am having a strange issue with one of my Shelly RGBW2. The ON-OFF state is flipping for the device. I checked and on the device UI the state is not flipping; also on MQTT I cannot see any messages that the state would flip. Ofc when the state flips to ON IRL it is off. I recently changed from Home Assistant where Iâve never seen such issue. This is happening for the second time in the past 4 weeks. OH Restart is not solving the issue.
events log:
2021-04-08 10:45:00.206 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:11.718 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:13.376 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:14.813 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:15.234 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:26.718 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:28.355 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:29.814 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:30.240 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:41.727 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:43.401 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:44.895 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:45.259 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:45:56.732 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:45:58.376 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:00.088 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:46:00.207 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:11.737 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:46:13.376 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:15.095 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:46:15.232 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:26.867 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:46:28.353 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:30.250 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
2021-04-08 10:46:32.950 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from ON to OFF
2021-04-08 10:46:41.870 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RGBWLedStripLivingRoom_Power' changed from OFF to ON
openhab log Shelly - TRACE
2021-04-08 10:45:04.989 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: CoIoT Message from /192.168.2.2:5683 (MID=58978): {"G":[[0,9103,0],[0,1101,0],[0,5105,0],[0,5106,0],[0,5107,0],[0,5108,30],[0,5102,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"color"]]}
2021-04-08 10:45:04.990 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyrgbw2-6f856c: Channel device#heartBeat updated with 2021-04-08T10:45:04.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 10:45:04.990 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyrgbw2-6f856c: Watchdog restarted (expires in 70 sec)
2021-04-08 10:45:04.990 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: Serial 256 was already processed, ignore update
2021-04-08 10:45:19.989 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: CoIoT Message from /192.168.2.2:5683 (MID=58979): {"G":[[0,9103,0],[0,1101,0],[0,5105,0],[0,5106,0],[0,5107,0],[0,5108,30],[0,5102,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"color"]]}
2021-04-08 10:45:19.989 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyrgbw2-6f856c: Channel device#heartBeat updated with 2021-04-08T10:45:19.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 10:45:19.989 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyrgbw2-6f856c: Watchdog restarted (expires in 70 sec)
2021-04-08 10:45:19.989 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: Serial 256 was already processed, ignore update
2021-04-08 10:45:35.008 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: CoIoT Message from /192.168.2.2:5683 (MID=58980): {"G":[[0,9103,0],[0,1101,0],[0,5105,0],[0,5106,0],[0,5107,0],[0,5108,30],[0,5102,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"color"]]}
2021-04-08 10:45:35.008 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyrgbw2-6f856c: Channel device#heartBeat updated with 2021-04-08T10:45:35.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 10:45:35.008 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyrgbw2-6f856c: Watchdog restarted (expires in 70 sec)
2021-04-08 10:45:35.008 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyrgbw2-6f856c: Serial 256 was already processed, ignore update
Right now I am on OH 3.1.0M3, but earlier this happend on 3.1.0M1 as well. The logs here are filtered to this single device I have the problem with.
Hey Markus,
this is again about receiving a trigger from shelly1 (shelly:shelly1::relay#button) when button is in detached mode. this is currently not working. on shelly ix3 this is working fine. I am on OH3.1 M3, no dev build, shelly-FW v1.10.1-gf276b51
- shelly status before button press:
{"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-65},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:34","unixtime":1617906873,"serial":46,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":2,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":11}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":36072,"fs_size":233681,"fs_free":149094,"uptime":12640}
- shelly status after button press:
{"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-67},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:35","unixtime":1617906921,"serial":49,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":2,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":12}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":36952,"fs_size":233681,"fs_free":146835,"uptime":12688}
from the event count you can see that button press is registered: {âinputâ:0,âeventâ:"",âevent_cntâ:12}
Trace log before and after button press.
button press was between 20:34:29.196 and 20:35:30.464
2021-04-08 20:34:29.049 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Updating status (refreshSettings=false)
2021-04-08 20:34:29.050 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP GET for http://192.168.178.78/status
2021-04-08 20:34:29.121 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-66},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:34","unixtime":1617906869,"serial":45,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":11}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":37168,"fs_size":233681,"fs_free":149847,"uptime":12636}
2021-04-08 20:34:29.124 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel device#heartBeat updated with 2021-04-08T20:34:29.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 20:34:29.126 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Watchdog restarted (expires in 70 sec)
2021-04-08 20:34:29.127 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly1-84cca8a87ec1: Updating 1 relay(s)
2021-04-08 20:34:29.129 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP GET for http://192.168.178.78/status/relay/0
2021-04-08 20:34:29.196 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-66},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:34","unixtime":1617906869,"serial":45,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":11}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":38576,"fs_size":233681,"fs_free":149847,"uptime":12636}
2021-04-08 20:34:29.199 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel device#uptime updated with 12636 s (type class org.openhab.core.library.types.QuantityType).
2021-04-08 20:34:29.201 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Watchdog restarted (expires in 70 sec)
2021-04-08 20:35:29.206 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Updating status (refreshSettings=false)
2021-04-08 20:35:29.208 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP GET for http://192.168.178.78/status
2021-04-08 20:35:30.464 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-67},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:35","unixtime":1617906930,"serial":49,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":2,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":12}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":37108,"fs_size":233681,"fs_free":146333,"uptime":12697}
2021-04-08 20:35:30.467 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel device#heartBeat updated with 2021-04-08T20:35:30.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 20:35:30.468 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Watchdog restarted (expires in 70 sec)
2021-04-08 20:35:30.470 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly1-84cca8a87ec1: Updating 1 relay(s)
2021-04-08 20:35:30.473 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP GET for http://192.168.178.78/status/relay/0
2021-04-08 20:35:32.070 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-84cca8a87ec1: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"myWLAN2","ip":"192.168.178.78","rssi":-67},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"20:35","unixtime":1617906931,"serial":49,"has_update":false,"mac":"84CCA8A87EC1","cfg_changed_cnt":2,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"timer"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":12}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20210323-104500/v1.10.1-gf276b51","old_version":"20210323-104500/v1.10.1-gf276b51","beta_version":"20210405-091013/v1.10.2-rc5-gc86c23a"},"ram_total":50224,"ram_free":37284,"fs_size":233681,"fs_free":146082,"uptime":12698}
2021-04-08 20:35:32.072 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel device#uptime updated with 12697 s (type class org.openhab.core.library.types.QuantityType).
2021-04-08 20:35:32.074 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel relay#eventCount updated with 12 (type class org.openhab.core.library.types.DecimalType).
2021-04-08 20:35:32.077 [DEBUG] [lly.internal.util.ShellyChannelCache] - shelly1-84cca8a87ec1: Channel device#heartBeat updated with 2021-04-08T20:35:32.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2021-04-08 20:35:32.078 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-84cca8a87ec1: Watchdog restarted (expires in 70 sec)
@DileRGorE @Oliver2
please try the DEV build, as you know I made a change that button events are not filtered in detached mode. Iâm not sure which code base was merged into 3.1M3
I am not using detached mode. Anyway I will try the dev build and will get back to you. Thanks!
fyi: PR#10276 has been merged. This includes Shelly Manager. I would expect that this will be part of 3.1M4 (and the DEv build anywaysđ)
Shelly Manager is already part of M3
Merge was before releaseâŠ
@Polo or @Tomibeck I started working on this. Itâs included in the DEV build, waiting on feedback.
I am interested to help developing this add on. For me itâs working with one sensor, but with two it gives same readings.
70 year old beginner, slow learner. Donât blame me
Iâve a problem with the shelly binding, so I created a new topic in den binding-section, but after reading this thread, I thing it should be better placed in this thread.
[OH3.1M3] [shelly] CoIoT Unicast behind reverse proxy
I would like to configure CoIoT Unicast, but I get the following message âCoIoT peer in device settings does not point this to this host, disabling CoIoTâ, because I run openHAB in docker container behind a reverse proxy.
Is there any way to solve this problem?
Thomas
why do you use a reverse proxy?
Iâve setup my 3EM a couple of months ago with the shelly binding. I configured the thing with an updateInterval
of 300. This always worked fine, but since a couple of days my items are modified on every change. So this meens, these items are changing non-stop. I already restarted openHAB and updated the firemware of my 3EM (Current version: 20210323-110413/v1.10.1-gf276b51). What else can be wrong? This binding is running on OH 2.5.12.
what does that mean?
try DEV build
I updated the DEV build and keep the warning, but removed disabling CoIoT by default. Maybe there are good reasons for a setup like that (like yourâs). You need to update to the latest DEV build.
I installed 2.5.13, but I get the same issue: the updateInterval
doesnât do anything
I even reinstalled openhab completely, so the thing is completely new.
I will test the 3.0 version in my test 3.x setup later today.
Hi Markus,
thanks for the fast reply.
I have several docker container running on my synology and I found the warnings from the browsers annoying, when going to the pages with http.
Also I found the different ports from the different services annoying.
So I decided to start a container with traefik reverse proxy, so I could reach all services with https (traefik manages the certificates) and on the same port.
The only thing is, that this construct only works with dns-names and not with ip-adresses, when connecting over traefik.
Thanks a lot.
I will give it a try at the weekend.
Thomas
