Shelly Binding
I also recently stumbled over the red triangle symbols. (Yes, I see the information in the popup.) The question is, need the symbols be green to work properly? What are criterias to get a green dot? I haven’t found anything about that in the documentation.
For those who want to give it a try: org.openhab.binding.shelly-3.3.0-gen2.jar
  • Please keep in mind: It’s work in progress.
  • The binding supports Gen 1 and Gen 2 devices at the same time. Gen 1 compatibility is not yet fully tested.
  • Gen1+2 devices get discovered, channels are filled (maybe some may not working), output can be controlled. Device recovery should work on communication problems. README is not yet updated.
  • Handling of input events (button pressed) are not fully implemented yet.
  • Shelly Manager is not yet adapted.
How to install
  • Backup your data and existing DEV build (if installed).
  • Existing devices should be deleted and will be re-discovered by the new binding. OH will also restore the channel/item linkage.
  • The regular version, which comes with the distribution nor another DEV build must NOT be installed. Deinstall Shelly Binding from UI or delete the DEV build jar from the addons folder before you install the -gen2.jar
  • Set log level to DEBUG while testing. Include proper information when reporting problems.
  • If not yet done you need to install the Californium jars, check READMEbeta .
  • copy the jar(s) to the addons folder, wait 30sec and check with bundle:list on the OH console that the binding is active
  • check Main UI that things come ONLINE
the red bell is nothing to worry about, as it is just a notification. I never came across a red exclamation mark. Probably a mouse over will give you more information.
yes, hover over the symbol and check the documentation
Have you checked the Thing status in OH? I had an issue and had to restart OH to clear these.
Thangs for the answers :slight_smile:
The reason, why I am asking: I have openHab 3.x running for about a year now and the shelly integration worked flawless. Now, I recently added 3 new shelly (to 9 in total) and updated the software version of the shellys. And since then, every now and then, the buttons in OH stop working.
As soon as I remove the binding and add it again, the issue is gone.
Does that ring a bell for someone. Any hints how to debug that further?
Thanks in advance.
It is recommended to
  • replace the binding by dev binding from markus
  • delete and re-add all shelly things (do not delete items as all channel linking will be reestablished by openhab)
  • make sure to enable CoIoT on all devices
Any idea, why the Boost timer from the TRV looks like that, and is not a flat line with 60min?
DEV binding from today in use, and OH 3.2.0, TRV has the RC5 from the 2.1.5 in use.
fyi: The pending PR 12325 has been merged. This brings TRV and Motion2 support as well as various bug fixes into the next milestone build.
This PR does not add Plus/Pro support, this will be the next PR, but it’s not yet done
Does anybody has connected a Shelly Plus 2PM or Shelly Pro 2/2PM connected to a roller and could help testing the Gen2 build of the binding?
Trying to use the shelly binding with some window and HT sensors. Seems that most of the sensors are working, except the temperature? That one isn’t sending the data (properly)?
Humidity, Lux, OPEN/CLOSE are all sending.
Any idea what I’m missing?
Some logs:
2022-04-21 13:53:11.973 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly016_Update' changed from 2022-04-21T12:55:00.000+0200 to 2022-04-21T13:53:11.000+0200
2022-04-21 13:53:11.977 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@227c0179[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:11.977 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@e44463f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...,"label}
2022-04-21 13:53:11.978 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@e44463f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...,"label} complete=false committing=false callback=Blocker@79e6e9e8{null}
2022-04-21 13:53:11.981 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@6635b58f[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:11.983 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@2e53d3a2[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:11.984 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@4c26690b[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:11.985 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@4c26690b[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@59cf44b1{null}
2022-04-21 13:53:11.988 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5ef038d5[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:11.989 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3dc295b[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:11.989 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3dc295b[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@5a57bf13{null}
2022-04-21 13:53:11.982 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@24fd8a89[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:11.991 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@24fd8a89[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@5d523c7b{null}
2022-04-21 13:53:11.992 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@75e4f0f0[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:11.992 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@6d33f211[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:11.993 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@6d33f211[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@4e17e2fb{null}
2022-04-21 13:53:11.995 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@397482f3[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.001 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@57bb8f46[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...EMINI",}
2022-04-21 13:53:12.001 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@57bb8f46[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...EMINI",} complete=false committing=false callback=Blocker@3e3bc1db{null}
2022-04-21 13:53:11.996 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@4b8e3e88[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.004 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@235ce44[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...Sp2OJ/d}
2022-04-21 13:53:12.005 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@2da4c748[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.014 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@63763e3a[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.015 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@a832c9[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...{"value}
2022-04-21 13:53:12.016 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly016_Helderheid' changed from 8159 lx to 3883 lx
2022-04-21 13:53:12.010 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@2aa45133[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.004 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@235ce44[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...Sp2OJ/d} complete=false committing=false callback=Blocker@6f031a22{null}
2022-04-21 13:53:12.019 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@2aa45133[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@56182ca3{null}
2022-04-21 13:53:12.021 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@243fbd1a[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.022 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@4f8f3e44[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.017 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@a832c9[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...{"value} complete=false committing=false callback=Blocker@3012ac23{null}
2022-04-21 13:53:12.022 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@1c82b393[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.023 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@100ee93d[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.029 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@25796c14[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.022 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@4f8f3e44[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@3eb40830{null}
2022-04-21 13:53:12.031 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@7efcc487[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.032 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@62702b10[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.032 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@4663ee72[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.032 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@62702b10[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@fb80a74{null}
2022-04-21 13:53:12.039 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@4663ee72[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1212565{null}
2022-04-21 13:53:12.026 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@100ee93d[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1fcff9bc{null}
2022-04-21 13:53:12.043 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@1d49fdd0[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.044 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@41cd4102[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...},"edit}
2022-04-21 13:53:12.044 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@41cd4102[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...},"edit} complete=false committing=false callback=Blocker@76d37f80{null}
2022-04-21 13:53:12.039 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@3c27e7eb[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.049 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@6c45c265[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.051 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@65246b3f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE}
2022-04-21 13:53:12.048 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@c4724f3[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ind":"S}
2022-04-21 13:53:12.053 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@c4724f3[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ind":"S} complete=false committing=false callback=Blocker@51c0479e{null}
2022-04-21 13:53:12.056 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@65246b3f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE} complete=false committing=false callback=Blocker@4466f37c{null}
2022-04-21 13:53:12.078 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@11b6812e[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.078 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@4048c460[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.082 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@38b98758[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.083 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3c860410[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.084 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3c860410[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@7dbb0e2b{null}
2022-04-21 13:53:12.092 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5a10a36d[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.092 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5e2f3c70[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.127 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5e2f3c70[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1f12364b{null}
2022-04-21 13:53:12.080 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@44775836[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.133 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@44775836[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@54a520d{null}
2022-04-21 13:53:12.079 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@15890747[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...","labe}
2022-04-21 13:53:12.147 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@9d32269[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.148 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@deca70c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ind":"S}
2022-04-21 13:53:12.148 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@deca70c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ind":"S} complete=false committing=false callback=Blocker@4cd1ad37{null}
2022-04-21 13:53:12.140 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@15890747[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...","labe} complete=false committing=false callback=Blocker@54b40d7c{null}
2022-04-21 13:53:12.195 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5918c200[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.196 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5d274d7c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.166 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5fc875a1[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.310 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5bf7ea07[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...aurus"}}
2022-04-21 13:53:12.196 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5d274d7c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1c1a4747{null}
2022-04-21 13:53:12.310 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5bf7ea07[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...aurus"}} complete=false committing=false callback=Blocker@1acae03c{null}
2022-04-21 13:53:12.331 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@3ac27906[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.361 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@79e957f8[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.365 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@36e820b4[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.365 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@32d7b236[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.366 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@32d7b236[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@73eab80d{null}
2022-04-21 13:53:12.360 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3efdfa01[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.362 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@7dd6cc9a[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:false,}
2022-04-21 13:53:12.383 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3efdfa01[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@7fc0f03a{null}
2022-04-21 13:53:12.384 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@12eb415e[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.396 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@16d4c75c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...AURUS",}
2022-04-21 13:53:12.397 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@16d4c75c[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...AURUS",} complete=false committing=false callback=Blocker@57e9cd67{null}
2022-04-21 13:53:12.397 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@3ba6342d[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.398 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3f99b706[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...6505352}
2022-04-21 13:53:12.382 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@7dd6cc9a[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:false,} complete=false committing=false callback=Blocker@3cebc6a1{null}
2022-04-21 13:53:12.403 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@52901397[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.404 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@56af8d9a[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.405 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@56af8d9a[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@179287a1{null}
2022-04-21 13:53:12.399 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3f99b706[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...6505352} complete=false committing=false callback=Blocker@7ea4bd3d{null}
2022-04-21 13:53:12.412 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@6bc00638[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.412 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5ce91da[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.421 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5ce91da[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@2cbd27ee{null}
2022-04-21 13:53:12.439 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5d8fb748[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.440 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@59b038a6[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.442 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@59b038a6[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@188d329d{null}
2022-04-21 13:53:12.447 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@16663058[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.448 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@1259b6cb[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@dcf6b69[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@38e33d9[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@9f0fe8f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3f095d60[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE}
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@9f0fe8f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@48cdf4b4{null}
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3f095d60[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE} complete=false committing=false callback=Blocker@7fea86c6{null}
2022-04-21 13:53:12.454 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@351f8022[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.454 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@312002de[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...bel":"V}
2022-04-21 13:53:12.454 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@312002de[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...bel":"V} complete=false committing=false callback=Blocker@701d08e5{null}
2022-04-21 13:53:12.472 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@7c560aa6[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.450 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@1259b6cb[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@5364bcf0{null}
2022-04-21 13:53:12.480 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@78699173[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"zwave}
2022-04-21 13:53:12.485 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5b672b10[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.486 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5f58b423[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.486 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5f58b423[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1e65be18{null}
2022-04-21 13:53:12.481 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@78699173[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"zwave} complete=false committing=false callback=Blocker@39549b48{null}
2022-04-21 13:53:12.511 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@498fc3f[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.512 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@a778f3[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ultTags}
2022-04-21 13:53:12.512 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@a778f3[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ultTags} complete=false committing=false callback=Blocker@419a72c8{null}
2022-04-21 13:53:12.515 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@765fae8d[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.516 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@2e4ba98[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:12.516 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@2e4ba98[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@3e9a1e8f{null}
2022-04-21 13:53:12.699 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@2715696b[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:12.699 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@232af9d6[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...6700000}
2022-04-21 13:53:12.700 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@232af9d6[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...6700000} complete=false committing=false callback=Blocker@6217f3ed{null}
2022-04-21 13:53:16.956 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5cec6083[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:16.957 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@3e3a4a21[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"Virgo}
2022-04-21 13:53:16.957 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@3e3a4a21[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"Virgo} complete=false committing=false callback=Blocker@11e19425{null}
2022-04-21 13:53:17.015 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@5b465362[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.003 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@11a0363f[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.015 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@6a112828[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.018 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@6dfcfc12[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE}
2022-04-21 13:53:17.020 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@6dfcfc12[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"STATE} complete=false committing=false callback=Blocker@1b8cb2e2{null}
2022-04-21 13:53:17.019 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@6a112828[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@132ed2fe{null}
2022-04-21 13:53:17.040 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@34b543b5[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.040 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@1266169f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.041 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@1266169f[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@1ead3fcc{null}
2022-04-21 13:53:17.042 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@f9025a2[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.041 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@22f4305e[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.045 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5fc8d7f0[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.046 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5fc8d7f0[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@21620d6a{null}
2022-04-21 13:53:17.042 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@6554ad27[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.057 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@578cbe5e[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.068 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@550f928d[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.069 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@550f928d[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@22b0420c{null}
2022-04-21 13:53:17.064 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@6554ad27[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@12eaf6cd{null}
2022-04-21 13:53:17.077 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@4293986[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.078 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@5c960847[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ultTags}
2022-04-21 13:53:17.078 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@5c960847[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...ultTags} complete=false committing=false callback=Blocker@5f392260{null}
2022-04-21 13:53:17.086 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@70bbe05[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.087 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@1d8b6eae[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...label":}
2022-04-21 13:53:17.087 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@1d8b6eae[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...label":} complete=false committing=false callback=Blocker@71acb0a2{null}
2022-04-21 13:53:17.085 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@697f3194[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.095 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@68705699[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.100 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@68705699[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@5b3a98c2{null}
2022-04-21 13:53:17.139 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@18697f24[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.140 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@22bdf665[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.140 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@1d26c39e[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...,"label}
2022-04-21 13:53:17.141 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@1d26c39e[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...,"label} complete=false committing=false callback=Blocker@36da1446{null}
2022-04-21 13:53:17.140 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@7f8070c4[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.147 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@7f8070c4[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@79409a7e{null}
2022-04-21 13:53:17.196 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@436997c8[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.196 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@4fa11a95[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:17.197 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@4fa11a95[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@318906ec{null}
2022-04-21 13:53:17.216 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@7efffa3b[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.226 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@42edb8ce[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...lTypeUI}
2022-04-21 13:53:17.231 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@42edb8ce[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...lTypeUI} complete=false committing=false callback=Blocker@65ebeeab{null}
2022-04-21 13:53:17.279 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@ccc442e[p=0,l=104,c=104,r=104]={<<<{"Shelly016_Update":{"sta...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:17.280 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@7b2f44f9[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"zwave}
2022-04-21 13:53:17.281 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@7b2f44f9[p=0,l=110,c=32768,r=110]={<<<data: {"Shelly016_Update"...04-21T13:53:11+02:00"}}>>>DEF"},"Sh...:"zwave} complete=false committing=false callback=Blocker@5f2e80dc{null}
2022-04-21 13:53:20.505 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 1834 HeapByteBuffer@57e61ef0[p=0,l=1834,c=8192,r=1834]={<<<POST /rest/events/states/...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:20.506 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@5b527279::SocketChannelEndPoint@101c1ba9{l=/127.0.0.1:8080,r=/127.0.0.1:33318,OPEN,fill=-,flush=-,to=0/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5b527279[p=HttpParser{s=START,0 of -1},g=HttpGenerator@271bfcfa{s=START}]=>HttpChannelOverHttp@900be89{s=HttpChannelState@76730248{s=IDLE rs=BLOCKING os=OPEN is=IDLE awp=false se=false i=true al=0},r=0,c=false/false,a=IDLE,uri=null,age=0} filled 1834 HeapByteBuffer@57e61ef0[p=0,l=1834,c=8192,r=1834]={<<<POST /rest/events/states/...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:20.507 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@5b527279::SocketChannelEndPoint@101c1ba9{l=/127.0.0.1:8080,r=/127.0.0.1:33318,OPEN,fill=-,flush=-,to=1/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5b527279[p=HttpParser{s=START,0 of -1},g=HttpGenerator@271bfcfa{s=START}]=>HttpChannelOverHttp@900be89{s=HttpChannelState@76730248{s=IDLE rs=BLOCKING os=OPEN is=IDLE awp=false se=false i=true al=0},r=0,c=false/false,a=IDLE,uri=null,age=0} parse HeapByteBuffer@57e61ef0[p=0,l=1834,c=8192,r=1834]={<<<POST /rest/events/states/...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00} null
2022-04-21 13:53:20.508 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@57e61ef0[p=0,l=1834,c=8192,r=1834]={<<<POST /rest/events/states/...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:20.567 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@5b527279::SocketChannelEndPoint@101c1ba9{l=/127.0.0.1:8080,r=/127.0.0.1:33318,OPEN,fill=-,flush=-,to=61/30000}{io=0/0,kio=0,kro=1}->HttpConnection@5b527279[p=HttpParser{s=CONTENT,0 of 91},g=HttpGenerator@271bfcfa{s=START}]=>HttpChannelOverHttp@900be89{s=HttpChannelState@76730248{s=HANDLING rs=BLOCKING os=OPEN is=IDLE awp=false se=false i=true al=0},r=1,c=false/false,a=HANDLING,uri=//doornroosje.oniria.xyz/rest/events/states/65422801-c5df-4235-94ff-8565dc8f8a32,age=20} parse HeapByteBuffer@57e61ef0[p=1743,l=1834,c=8192,r=91]={POST /res...R=1\r\n\r\n<<<["Shelly016_Temperature",...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00} null
2022-04-21 13:53:20.569 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=CONTENT HeapByteBuffer@57e61ef0[p=1743,l=1834,c=8192,r=91]={POST /res...R=1\r\n\r\n<<<["Shelly016_Temperature",...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:20.570 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - onContent HttpChannelOverHttp@900be89{s=HttpChannelState@76730248{s=HANDLING rs=BLOCKING os=OPEN is=IDLE awp=false se=false i=true al=0},r=1,c=false/false,a=HANDLING,uri=//doornroosje.oniria.xyz/rest/events/states/65422801-c5df-4235-94ff-8565dc8f8a32,age=22} Content@5e2c5a9f{HeapByteBufferR@673edfc0[p=1743,l=1834,c=8192,r=91]={POST /res...R=1\r\n\r\n<<<["Shelly016_Temperature",...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}}
2022-04-21 13:53:20.571 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@5568e6e8[c=0,q=0,[0]=null,s=STREAM] addContent Content@5e2c5a9f{HeapByteBufferR@673edfc0[p=1743,l=1834,c=8192,r=91]={POST /res...R=1\r\n\r\n<<<["Shelly016_Temperature",...d2","Shelly016_Update"]>>>O_entries...\x00\x00\x00\x00\x00\x00\x00}}
2022-04-21 13:53:20.588 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array HeapByteBuffer@7f8d7370[p=0,l=284,c=284,r=284]={<<<{"Shelly016_Helderheid2":...04-21T13:53:11+02:00"}}>>>})
2022-04-21 13:53:20.589 [DEBUG] [org.eclipse.jetty.server.HttpOutput ] - write(array) s=OPEN,api=BLOCKING,sc=false,e=null aggregated !flush DirectByteBuffer@251e2a01[p=0,l=290,c=32768,r=290]={<<<data: {"Shelly016_Helderh...04-21T13:53:11+02:00"}}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00}
2022-04-21 13:53:20.589 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@251e2a01[p=0,l=290,c=32768,r=290]={<<<data: {"Shelly016_Helderh...04-21T13:53:11+02:00"}}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00} complete=false committing=false callback=Blocker@54f15fc8{null}
2022-04-21 13:53:28.244 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'BU_hel' changed from 10317 to 9782 through Shelly016_Helderheid
2022-04-21 13:53:28.245 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'SE_hel' changed from 8686 to 6548 through Shelly016_Helderheid
Just tried the latest binding, but the same result. Illuminance, battery, wifi are all working as expected. But temperature does nothing. On the sensor GUI, values are correct, but they are never communicated to openHAB?
HT&T status gets updated via CoIoT messages. Please disable jetty logging and use regular DEBUG log only
Did you tried the regular DEV build or the -gen2.jar?
For the moment, I’m running org.openhab.binding.shelly-3.3.0-gen2.jar.
Some new logs.
Seems that temperature is getting in (ref 08:02:38.953), but not picked up by my item?
2022-04-23 08:00:29.388 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Ignore API Timeout, retry later
2022-04-23 08:02:38.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: CoIoT Message from /192.168.110.25:5683 (MID=48999): {"G":[[0,9103,0],[0,3108,0],[0,3119,0],[0,3109,-1],[0,6110,1],[0,3106,502],[0,3110,"bright"],[0,3101,11.20],[0,3102,52.16],[0,3115,0],[0,3111,99],[0,9102,["sensor","light"]]]}
2022-04-23 08:02:38.941 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw2-078187: CoIoT Message from /192.168.110.25:5683 (MID=48999): {"G":[[0,9103,0],[0,3108,0],[0,3119,0],[0,3109,-1],[0,6110,1],[0,3106,502],[0,3110,"bright"],[0,3101,11.20],[0,3102,52.16],[0,3115,0],[0,3111,99],[0,9102,["sensor","light"]]]}
2022-04-23 08:02:38.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: CoIoT Sensor data {"G":[[0,9103,0],[0,3108,0],[0,3119,0],[0,3109,-1],[0,6110,1],[0,3106,502],[0,3110,"bright"],[0,3101,11.20],[0,3102,52.16],[0,3115,0],[0,3111,99],[0,9102,["sensor","light"]]]} (serial=256)
2022-04-23 08:02:38.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Channel device#heartBeat updated with 2022-04-23T08:02:38.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2022-04-23 08:02:38.943 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: CoIoT Sensor data {"G":[[0,9103,0],[0,3108,0],[0,3119,0],[0,3109,-1],[0,6110,1],[0,3106,502],[0,3110,"bright"],[0,3101,11.20],[0,3102,52.16],[0,3115,0],[0,3111,99],[0,9102,["sensor","light"]]]} (serial=256)
2022-04-23 08:02:38.944 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: 12 CoAP sensor updates received
2022-04-23 08:02:38.944 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw2-078187: Channel device#heartBeat updated with 2022-04-23T08:02:38.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2022-04-23 08:02:38.945 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw2-078187: CoIoT Sensor data {"G":[[0,9103,0],[0,3108,0],[0,3119,0],[0,3109,-1],[0,6110,1],[0,3106,502],[0,3110,"bright"],[0,3101,11.20],[0,3102,52.16],[0,3115,0],[0,3111,99],[0,9102,["sensor","light"]]]} (serial=256)
2022-04-23 08:02:38.945 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Send event device#alarm to channel VIBRATION
2022-04-23 08:02:38.946 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Duplicate vibration events will be absorbed for the next 6 sec
2022-04-23 08:02:38.946 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly016_Update' changed from 2022-04-23T07:56:56.000+0200 to 2022-04-23T08:02:38.000+0200
2022-04-23 08:02:38.946 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw2-078187: 12 CoAP sensor updates received
2022-04-23 08:02:38.947 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: 12 CoAP sensor updates received
2022-04-23 08:02:38.948 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Send event device#alarm to channel VIBRATION
2022-04-23 08:02:38.948 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Vibration event absorbed, 6 sec remaining
2022-04-23 08:02:38.949 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Duplicate vibration events will be absorbed for the next 6 sec
2022-04-23 08:02:38.949 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Event filtered: SENSOR
2022-04-23 08:02:38.950 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Channel sensors#lux updated with 502 lx (type class org.openhab.core.library.types.QuantityType).
2022-04-23 08:02:38.951 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: message.event.triggered
2022-04-23 08:02:38.952 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw2-078187: Channel sensors#lux updated with 502 lx (type class org.openhab.core.library.types.QuantityType).
2022-04-23 08:02:38.953 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw2-078187: Channel sensors#temperature updated with 11.2 °C (type class org.openhab.core.library.types.QuantityType).
2022-04-23 08:02:38.954 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw2-078187: 2 channels updated from CoIoT status, serial=256
2022-04-23 08:02:38.955 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw2-078187: Channel sensors#lastUpdate updated with 2022-04-23T08:02:38.000+0200 (type class org.openhab.core.library.types.DateTimeType).
2022-04-23 08:02:38.958 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Channel sensors#temperature updated with 11.2 °C (type class org.openhab.core.library.types.QuantityType).
2022-04-23 08:02:38.959 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydw2-078187: 2 channels updated from CoIoT status, serial=256
2022-04-23 08:02:38.959 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'BU_hel' changed from 1337 to 1346 through Shelly016_Helderheid
2022-04-23 08:02:38.960 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'ALL_hel' changed from 448 to 450 through Shelly016_Helderheid
2022-04-23 08:02:38.963 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly016_Helderheid' changed from 429 lx to 502 lx
2022-04-23 08:02:38.964 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'SE_hel' changed from 215 to 251 through Shelly016_Helderheid
2022-04-23 08:02:42.592 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Vibration events are absorbed for 3 more seconds
2022-04-23 08:02:42.593 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Vibration events are absorbed for 3 more seconds
2022-04-23 08:02:45.593 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Vibration events are absorbed for 0 more seconds
2022-04-23 08:02:45.594 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydw2-078187: Vibration events are absorbed for 0 more seconds
My items:
Number:Temperature	Shelly016_Temperature	"Serre [%.1f C]"	<sun>		(BU_temx, BU_temS)	  	    { channel = "shelly:shellydw2:650cfeab88:sensors#temperature" }
Number:Illuminance	Shelly016_Helderheid	"Serre [%.1f Lux]"	<sun>		(ALL_hel, BU_hel, SE_hel)	{ channel = "shelly:shellydw2:650cfeab88:sensors#lux" }
String			    Shelly016_Helderheid2	"Serre [%.1f Lux]"	<sun>						{ channel = "shelly:shellydw2:650cfeab88:sensors#illumination" }
Contact		     	Shelly016_Contact	"Serre [%s]"		<contact>	(ent_SER)			{ channel = "shelly:shellydw2:650cfeab88:sensors#state" }
Number:Angle		Shelly016_Tilt		"Serre [%.f]"		<sun>						{ channel = "shelly:shellydw2:650cfeab88:sensors#tilt" }
Number			    Shelly016_Batterij	"Serre deur [%s %%]"	<battery> 	(allBat)			{ channel = "shelly:shellydw2:650cfeab88:battery#batteryLevel" }
Switch		     	Shelly016_BatterijLaag	"Batterij laag [%s]"	<contact>					{ channel = "shelly:shellydw2:650cfeab88:battery#lowBattery" }
String			    Shelly016_Trigger	"Trigger Serre [%s]"	<motion>					{ channel = "shelly:shellydw2:650cfeab88:device#alarm" }
Number			    Shelly016_WIFI		"Serre venster 2 [%s]"	<network>					{ channel = "shelly:shellydw2:650cfeab88:device#wifiSignal" }
String			    Shelly016_Naam		"Naam [%s]"		<log>						{ channel = "shelly:shellydw2:650cfeab88:device#deviceName" }
DateTime	     	Shelly016_Update	"Laatste update [%s]"	<clock>						{ channel = "shelly:shellydw2:650cfeab88:device#heartBeat"}
Seems that my item in the text file wasn’t picked up properly? When I add an item over the GUI:
Wrong item:
Number:Temperature      Shelly018_TemperatureText       "Serre [%.1f C]"        <sun>           (BU_temx, BU_temS)              { channel = "shelly:shellyht:6ad3ca8bc5:sensors#temperature" }
Correct item (with %unit%) :
Number:Temperature   Shelly018_TemperatureText       "Serre [%.1f  %unit%]"        <sun>           (BU_temx, BU_temS)              { channel = "shelly:shellyht:6ad3ca8bc5:sensors#temperature" }
strange
Don’t you havevto include the degree symbol. Th wrong definition just uses C… not °C
100% correct.
or maybe even better: %unit%
While working on Plus/Pro roller/cover support I was thinking to remove Coap1 support. This impacts users running very old firmware. Is anybody here to give a good reason why to keep Coap1 (Gen2 devices have Coap2 since v1.8)?
No reply means “gets removed” with the PR adding Plus/Pro
I would say let 'er rip. It may force firmware updates for some
Thanks Dev!, power switch now working fantastically for Plus 1’s using the latest 3-3-0gen2.jar
