remove the 2 jars from the addons folder and try
‘feature:install openhab-transport-coap’ on the OH console
Thanks for your quick reply. That installs the dependencies back to Version 2.0.0 and the old error returns.
2022-10-02 12:11:05.765 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.shelly-3.4.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.shelly [344]
Unresolved requirement: Import-Package: org.eclipse.californium.core; version="[2.7.0,3.0.0)"
issue ’ feature:list | grep coap’ on the console
that’s what I see on a OH 3.3 installtion
openhab-core-io-transport-coap │ 3.3.0 │ │ Uninstalled │ distro-3.3.0 │
openhab-transport-coap │ 3.3.0 │ │ Uninstalled │ distro-3.3.0 │ CoAP Transport
openhab.tp-coap │ 3.3.0 │ │ Uninstalled │ distro-3.3.0 │ Californium CoAP library
I found the definition for openhab.tp-coap, as you can see it requires a good bunch of files
<feature name="openhab.tp-coap" description="Californium CoAP library" version="${project.version}">
<capability>openhab.tp;feature=coap;version=2.7.3</capability>
<bundle>mvn:org.eclipse.californium/californium-osgi/2.7.3</bundle>
<bundle>mvn:org.eclipse.californium/californium-core/2.7.3</bundle>
<bundle>mvn:org.eclipse.californium/element-connector/2.7.3</bundle>
<bundle>mvn:org.eclipse.californium/scandium/2.7.3</bundle>
<bundle>mvn:org.eclipse.orbit.bundles/net.i2p.crypto.eddsa/0.3.0.v20220506-1020</bundle>
</feature>
try
feature:install openhab-core-io-transport-coap
feature:install openhab.tp-coap
I also created a .kar, which usually brings necessary dependencies
org.openhab.binding.shelly-3.4.0-SNAPSHOT.kar
remove the .jar before installing
Thanks again for your effort. All 3 mentioned features are already installed in my openhab 3.3 but it does not work, still the dependency problem with californium 2.0.0. Is the definition for openhab.tp-coap you posted from Version 3.3.0? Strange that it installs californium 2.0.0 then…
Then i tried your kar file, it also causes errors in my openhab 3.3
2022-10-02 15:19:08.826 [WARN ] [internal.service.FeaturesServiceImpl] - Can't load features repository mvn:org.openhab.core.features.karaf/org.openhab.core.features.karaf.openhab-core/3.4.0-SNAPSHOT/xml/features
java.lang.RuntimeException: Error resolving artifact org.openhab.core.features.karaf:org.openhab.core.features.karaf.openhab-core:xml:features:3.4.0-SNAPSHOT: [Could not find artifact org.openhab.core.features.karaf:org.openhab.core.features.karaf.openhab-core:xml:features:3.4.0-SNAPSHOT in openhab (https://openhab.jfrog.io/openhab/libs-release/)] : mvn:org.openhab.core.features.karaf/org.openhab.core.features.karaf.openhab-core/3.4.0-SNAPSHOT/xml/features
at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:121) ~[bundleFile:?]
at org.apache.karaf.features.internal.service.RepositoryImpl.<init>(RepositoryImpl.java:51) ~[bundleFile:?]
at org.apache.karaf.features.internal.service.RepositoryCacheImpl.create(RepositoryCacheImpl.java:51) ~[bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.getFeatureCache(FeaturesServiceImpl.java:611) [bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.ensureCacheLoaded(FeaturesServiceImpl.java:582) [bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.getRepository(FeaturesServiceImpl.java:530) [bundleFile:?]
at org.apache.karaf.kar.internal.KarServiceImpl.findMissingDependency(KarServiceImpl.java:165) [bundleFile:?]
at org.apache.karaf.kar.internal.KarServiceImpl.install(KarServiceImpl.java:116) [bundleFile:?]
at org.apache.karaf.kar.internal.KarServiceImpl.install(KarServiceImpl.java:95) [bundleFile:?]
at org.apache.karaf.kar.internal.KarServiceImpl.install(KarServiceImpl.java:87) [bundleFile:?]
at org.apache.karaf.deployer.kar.KarArtifactInstaller.install(KarArtifactInstaller.java:50) [bundleFile:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.install(DirectoryWatcher.java:950) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.install(DirectoryWatcher.java:884) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:489) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.7.4]
Caused by: java.io.IOException: Error resolving artifact org.openhab.core.features.karaf:org.openhab.core.features.karaf.openhab-core:xml:features:3.4.0-SNAPSHOT: [Could not find artifact org.openhab.core.features.karaf:org.openhab.core.features.karaf.openhab-core:xml:features:3.4.0-SNAPSHOT in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:555) ~[?:?]
at org.ops4j.pax.url.mvn.internal.Connection.getInputStream(Connection.java:123) ~[?:?]
at java.net.URL.openStream(URL.java:1165) ~[?:?]
at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:114) ~[bundleFile:?]
... 15 more
The binding was “active” due to “bundle:list” but had a strange version and name and did not work:
348 │ Active │ 80 │ 0 │ wrap_file__var_lib_openhab_tmp_kar_org.openhab.binding.shelly-3.4.0-SNAPSHOT_org_lastnpe_eea_eea-all_2.2.1_eea-all-2.2.1.jar
Regards,
Daniel
I expect that OH 3.3 comes with Californium 2.0, whereas 3.4 milestone build has switched to 2.7
I added the jar build to the Community Market Place, The binding does not yet show up, you need to enable the market place and previews (both options in Settings:Community Marketplace)
- remove the files from the addons folder
- Go to Settings:Bindings and search for “Shelly Beta with Plus/Pro support”
- install the binding
Hi Markus,
thanks again, I see the binding in the marketplace but when I install it nothing happens. No binding/bundle ist listed in karaf console, nothing in the logfiles. A little crazy, would at least expect some logfile entries about the install or a failure…
try again, I changed the url
as always: If something has changed it might require adjustments. When installing the binding from the UI the loader automatically resolves dependencies like we have with Coap/Californium, but if you copy the jar to the addons folder you need to do the prep yourself. Obviously the included Coap version has changed + the bundle now requires more files then 2.0.
thanks for helping
Hi Markus,
nothing to thank for, I have to thank for your work and kind support!
I tried again to install but get an error in the UI when trying to install:
Sadly nothing in the logfiles to further indicate what went wrong.
I think something is wrong with definition of openhab-transport-coap in 3.4M2. It installed version 2.0.0, whereas the build environment references 2.7.3. I setup a test environment and need to investigate.
Does somebody else has 3.4 M2+ with the binding running?
I found this PR
and this one
That could cause the situation that 3.3/3.4M2 needs Californium 2.0, whereas new builds require 2.7.3
for now try the previous build: https://github.com/markus7017/myfiles/blob/a12594a9967f98f5c4fac54f668fd406664f5b16/shelly/org.openhab.binding.shelly-3.4.0-SNAPSHOT.jar?raw=true
Hi Markus,
thanks for the link to the older jar, this one works like a charm for my shelly 1 plus. Thanks a lot and hopefully the binding with gen2 support will come with 3.4
Thanks for your work, great support and kind regards,
Daniel
With the previous build you linked to i can see all channels for dimmer2.
So now everything is working.
Me too,
i was not seeing the channel Power2 of a Shelly 2.5 with the previous build is ok.
Hello @markus7017 ,
now I had the time to test again.
I just copied latest build from you into my add-on folder. Shelly2pm+ is now found and working (in Switch mode).
I didn’t use californium 2.7!
Thx, I’m very happy with this!!
CU Frank
Status is as follows
- OH 3.3…3.4M2 bringt Californium 2.0
- 2 weeks ago they bumped the version to 2.7.3
- a new build of the binding will be build with this dependency
- 3.4M3 will bringt Californium 2.7.3
- it doesn’t work if the dependency in the binding jar doesn’t match the OH platform
- at the moment I’m looking for a way to build a new 3.3 version
I think I found a solution
- 3.4.0-M2 build, which also serves 3.3.0
- 3.4.0-M3 build, which runs on the current SNAPSHOT build of the Distro and M3+
Please help testing, I have on the 3.4-SNAPSHOT environment. When copying the jar to the addons folder make sure to delete the existing one (different name). Use bundle:list to see status, the new builds show up as “Shelly Binding for Gen1+2”.
Hi markus,
I did test your 3.4.0-M2 on my OH 3.3.0 regarding the shelly 1 plus device but I only get status Offline with error message: unexpected error: WebSocket connection closed abnormal. Older devices like shelly1 and shellyswitch25 are working fine.
In openhab.log I do not get an error message, I just found “Added new thing ‘shelly:shellyplus1:3c610572ed5c’ to inbox.” there.
Under Bundle:List I have the follwoing entry:
257 │ Active │ 80 │ 3.4.0.202210071549 │ openHAB Add-ons :: Bundles :: Sh
I fixed a JSON parsing problem and improved logging in this situation, please try again
Many thanks Markus, Problem solved I will do some further testing soon.
