It seems that the names in the thing file cannot contain spaces. Should that be so ?
in MainUI spaces for thing names are allowed. Not sure for file based configuration
So the name displayed in the Shelly Manager is not the Shelly label but its network address and when I display the menu, the name is empty. But it shows up in the GUI.
The shelly name comes from the device itself (settings â device name). Not sure what effect it has but try to set your devices to discoverable: yes
I had never given my Shellys a name in the device. Now Iâve done it and the Shelly manager is working again. Interesting that it worked without it until now.
Thank you
Quite useful: if you add new devices the binding uses the device name for the thingâs name.
Especially if you are using the dev binding from time to time you need to delete and re-add all things. By setting the device name in the device this task is done within a couple of seconds
This is not the reason. I have three shelly-plug-s which donât even have the option to set a device name, but showing up with their network name in shelly manager. Might be that setting the device name just triggered a network announcement on the shelly devices which was then cought by the binding and shelly manager, finally resulting in showing up.
Not related to the problem in any way but Plug S do have the option to set a device name (unless you have a very old FW)
I know, I have a newer one with actual fw and three old ones which are stuck on old fwâŠ.
Hello Everyone,
Iâd like to ask you about pointing me to right direction. Iâve bought recently Shelly Duo RGBW2 bulb. Iâve added that bulb using shelly
binding and Shelly Bulb (SHBLB-1)
type of the thing. Iâm able to power it, but I can not control the color. Even I set the mode
for color nothing happened (I can just see the brightness is changing). Even I change the mode directly in web interface of the Bulb itself, I can not than control the color of the bulb.
Also the setting the temperature of the bulb doesnât works, but maybe it is coupled with some general issue. Any advice is welcome.
Thx
Y
Shelly Plus Smoke is out and it can be ordered now. Is it supported by the Shelly Binding?
Hi Markus, here you go. this is a debug log between two of such messages:
2023-02-18 18:31:56.669 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyLightHandler tried updating the thing status although the handler was already disposed.
2023-02-18 18:31:56.671 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-49d23a: 22 CoAP sensor updates received
2023-02-18 18:31:56.671 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-49d23a: CoIoT Sensor data {"G":[[0,9103,1],[0,1101,1],[0,5101,42],[0,1201,1],[0,5201,28],[0,1301,0],[0,5301,1],[0,1401,0],[0,5401,1],[0,4101,9.87],[0,4103,653],[0,4201,6.58],[0,4203,435],[0,4301,0.00],[0,4303,0],[0,4401,0.00],[0,4403,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"white"]]} (serial=59137)
2023-02-18 18:31:56.675 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-49d23a: 22 CoAP sensor updates received
2023-02-18 18:31:56.688 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-49d23a: 2 channels updated from CoIoT status, serial=59137
2023-02-18 18:31:57.239 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-a638e4: CoIoT Message from /192.168.178.79:5683 (MID=29522): {"G":[[0,9103,1],[0,1101,0],[0,5101,16],[0,1201,0],[0,5201,54],[0,1301,0],[0,5301,0],[0,1401,0],[0,5401,0],[0,4101,0.00],[0,4103,0],[0,4201,0.00],[0,4203,0],[0,4301,0.00],[0,4303,0],[0,4401,0.00],[0,4403,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"white"]]}
2023-02-18 18:31:57.241 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-a638e4: Serial 512 was already processed, ignore update
2023-02-18 18:31:59.943 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d484e5: CoIoT Message from /192.168.178.24:5683 (MID=3412): {"G":[[0,9103,1],[0,1101,0],[0,5101,70],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,50.48],[0,3105,122.87],[0,6101,0],[0,9101,"white"]]}
2023-02-18 18:31:59.945 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d484e5: Serial 512 was already processed, ignore update
2023-02-18 18:32:00.016 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-e098069657aa: CoIoT Message from /192.168.178.22:5683 (MID=21187): {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
2023-02-18 18:32:00.018 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-e098069657aa: Serial 512 was already processed, ignore update
2023-02-18 18:32:00.295 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d0e053: CoIoT Message from /192.168.178.34:5683 (MID=57259): {"G":[[0,9103,0],[0,1101,1],[0,5101,40],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,23.02],[0,4103,1067],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,31.75],[0,3105,89.15],[0,6101,0],[0,9101,"white"]]}
2023-02-18 18:32:00.297 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d0e053: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,40],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,23.02],[0,4103,1067],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,31.75],[0,3105,89.15],[0,6101,0],[0,9101,"white"]]} (serial=1280)
2023-02-18 18:32:00.299 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d0e053: 18 CoAP sensor updates received
2023-02-18 18:32:00.307 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellydimmer-d0e053: 3 channels updated from CoIoT status, serial=1280
2023-02-18 18:32:00.573 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyix3-68c63afa94dd: CoIoT Message from /192.168.178.72:5683 (MID=32143): {"G":[[0,9103,0],[0,2101,1],[0,2102,""],[0,2103,3],[0,2201,0],[0,2202,""],[0,2203,0],[0,2301,0],[0,2302,""],[0,2303,0]]}
2023-02-18 18:32:00.575 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyix3-68c63afa94dd: Serial 1536 was already processed, ignore update
2023-02-18 18:32:02.435 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-e09806961050: CoIoT Message from /192.168.178.67:5683 (MID=7870): {"G":[[0,9103,1],[0,1101,0],[0,2101,1],[0,2102,""],[0,2103,0]]}
2023-02-18 18:32:02.437 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-e09806961050: Serial 2048 was already processed, ignore update
2023-02-18 18:32:04.925 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068cecb0: CoIoT Message from /192.168.178.35:5683 (MID=12658): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,60],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,140],[0,6103,"normal"],[0,3104,49.86],[0,6101,0],[0,9101,"roller"],[0,4108,232.77]]}
2023-02-18 18:32:04.927 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068cecb0: CoIoT Sensor data {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,60],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,140],[0,6103,"normal"],[0,3104,49.86],[0,6101,0],[0,9101,"roller"],[0,4108,232.77]]} (serial=4864)
2023-02-18 18:32:04.929 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068cecb0: 16 CoAP sensor updates received
2023-02-18 18:32:04.931 [DEBUG] [y.internal.api1.Shelly1CoIoTVersion2] - shellyswitch25-e098068cecb0: CoAP update roller position: control=40, position=60
2023-02-18 18:32:06.045 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyplug-s-9d8de0: CoIoT Message from /192.168.178.75:5683 (MID=45519): {"G":[[0,9103,0],[0,1101,1],[0,4101,5.11],[0,4103,467],[0,6102,0],[0,6109,0.00],[0,3104,30.20],[0,3105,86.37],[0,6101,0]]}
2023-02-18 18:32:06.047 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyplug-s-9d8de0: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,4101,5.11],[0,4103,467],[0,6102,0],[0,6109,0.00],[0,3104,30.20],[0,3105,86.37],[0,6101,0]]} (serial=1792)
2023-02-18 18:32:06.049 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyplug-s-9d8de0: 9 CoAP sensor updates received
2023-02-18 18:32:06.054 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyplug-s-9d8de0: 2 channels updated from CoIoT status, serial=1792
2023-02-18 18:32:06.883 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-84cca8a81036: CoIoT Message from /192.168.178.78:5683 (MID=33731): {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
2023-02-18 18:32:06.885 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly1-84cca8a81036: Serial 512 was already processed, ignore update
2023-02-18 18:32:07.369 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068d4ef7: CoIoT Message from /192.168.178.36:5683 (MID=46775): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,0],[0,6103,"normal"],[0,3104,52.38],[0,6101,0],[0,9101,"roller"],[0,4108,232.16]]}
2023-02-18 18:32:07.371 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068d4ef7: CoIoT Sensor data {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,0],[0,6103,"normal"],[0,3104,52.38],[0,6101,0],[0,9101,"roller"],[0,4108,232.16]]} (serial=3072)
2023-02-18 18:32:07.374 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyswitch25-e098068d4ef7: 16 CoAP sensor updates received
2023-02-18 18:32:07.376 [DEBUG] [y.internal.api1.Shelly1CoIoTVersion2] - shellyswitch25-e098068d4ef7: CoAP update roller position: control=0, position=100
2023-02-18 18:32:07.382 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybulbduo-d0dba6: CoIoT Message from /192.168.178.76:5683 (MID=60554): {"G":[[0,9103,1],[0,1101,0],[0,5101,70],[0,5103,3688],[0,5104,26],[0,4101,0.00],[0,4103,0]]}
2023-02-18 18:32:07.384 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybulbduo-d0dba6: Serial 512 was already processed, ignore update
2023-02-18 18:32:07.668 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellyrgbw2-49d23a: CoIoT Message from /192.168.178.73:5683 (MID=19037): {"G":[[0,9103,1],[0,1101,1],[0,5101,42],[0,1201,1],[0,5201,28],[0,1301,0],[0,5301,1],[0,1401,0],[0,5401,1],[0,4101,13.60],[0,4103,663],[0,4201,9.07],[0,4203,442],[0,4301,0.00],[0,4303,0],[0,4401,0.00],[0,4403,0],[0,6102,0],[0,2101,0],[0,2102,""],[0,2103,0],[0,9101,"white"]]}
2023-02-18 18:32:07.670 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyLightHandler tried updating the thing status although the handler was already disposed.
I am on 3.4.2 and replaced old dev binding with dist binding.
Unfortunately this is flooding my log (~each 5 seconds one message)
No, it is not yet supported.
@markus7017 : I got a new smoke detector today. Is there anything I can do to help?
To all users of new Shelly Plus Smoke:
Before you go mad (so did I - nearlyâŠ)
1. to start pairing mode: 5x short button press (wake up device and activate WIFI Access Point)
2. to wake up device: 3x short button press (as opposed to the manual which says 3 seconds)
Some more information:
- The device closes an active connection without any notification even though you are currently accessing the internal web server.
- Make sure to cover the speaker with your thumb when pressing the button
After some more investigation I found out how to resolve the following warning message:
Most probably at least one of your devices still has the setting:
CoIoT peer: mcast
If you change this to (OH IP address):5683 the warning goes away
@davorf
Hello!
Thank you for this information. Warning message stopped showing in log after Iâve changed this setting.
Best regards,
Davor
I have one of over 40 Shellyâs which makes problems only in the log file. The shelly1 works in pricipal normal,
but he spamâs the logfile all the time with this information. He is not NOT switching on/off like the logfile shows me:
2023-02-21 14:22:07.216 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:22:08.172 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:22:22.121 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:22:23.219 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:22:37.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:22:38.270 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:22:52.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:22:53.363 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:23:07.150 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:23:08.405 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:23:22.146 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:23:23.446 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:23:37.146 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:23:38.496 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:23:52.149 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:23:53.587 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:24:07.143 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:24:08.632 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
2023-02-21 14:24:22.147 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from OFF to ON
2023-02-21 14:24:23.684 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âAussenlichter_Betriebâ changed from ON to OFF
This happens on my Testsystem PI under 3.4.2-1 and also on my Productionsystem with 3.4.1-1
(booth systems are in the same network and are a 1:1 copy) the IP-Adress is differnet, and the Rules are off on the teststem.
Any idea why this happens?
I habe the smoke and plus plug s on the table, hit this problem and was annoyed , moved to the plusplugs and ran into
problems with the dev environment, annoying too and that was it for the weekend
I need to find some more time
did you checked events.log?
did you tried to delete and re-discover the thing (OH preserves the item linkage).
Are there other Shelly 1s showing the same symptom?
Thatâs strange. The setting changes from multicast (the binding receives traffic from all Shellys) to peer mode (traffic only from selected devices). How many Shellys do you have on the network?
OK, here some answers:
- I have already had deleted the shelly1 and have added him by scanning.â> Same effect
- Today, once more, â Same effect
- 230V Power off and on also was doneâŠ
- The shelly has the latest firmware 20221027-091427/v1.12.1-ga9117d3
- I have nearly 40 shellys in the same network.
- Several shelly1 with the same 1:1 settings, (sure different IP Adresses)
