hi,
3.4.3 dev build solved my problems with shellyplus smoke and shellyplus H&T. thanks!
what about future updates. I assume the dev build is somewhen integrated in the normal OH build. what is the procedure then to switch to the normal OH build?
The PR is already pending, but needs review & merge
are you on 3.4.2 or 4.0.0-SNAPSHOT?
If 4.0 you may need to switch to the latest SNAPSHOt
I am on 3.4.3-2
I changed the auto off to 0.2 the item was correctly update but in the shelly app remain to previous value (42.42)
here the trace log with grep on the only shelly that i have to change:
2023-04-17 11:27:00.462 [TRACE] [helly.internal.api2.Shelly2RpcSocket] - Scaldabagno: Inbound Rpc message: {"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","method":"NotifyStatus","params":{"ts":1681723620.88,"switch:0":{"id":0,"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1681723619,"total":96406.062}}}}
2023-04-17 11:27:00.468 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1pm-sc_bagno: NotifyStatus update received: {"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","method":"NotifyStatus","params":{"ts":1.68172362088E9,"switch:0":{"id":0,"aenergy":{"total":96406.062,"by_minute":[0.0,0.0,0.0],"minute_ts":1681723619}}}}
2023-04-17 11:27:00.473 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_bagno: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:06.539 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP POST for http://172.24.74.76/rpc {"id":19437255,"src":"shellyplus1pm-sc_bagno","method":"Shelly.GetStatus"}
2023-04-17 11:27:06.591 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP Response 200: {"id":19437255,"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","result":{"ble":null,"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"loopback", "output":false, "apower":0.0, "voltage":218.8, "current":0.000, "aenergy":{"total":96406.062,"by_minute":[0.000,0.000,0.000],"minute_ts":1681723625},"temperature":{"tC":44.6, "tF":112.2}},"sys":{"mac":"7C87CE64A7D8","restart_required":false,"time":"11:27","unixtime":1681723627,"uptime":2715155,"ram_size":234484,"ram_free":156724,"fs_size":458752,"fs_free":94208,"cfg_rev":59,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":null},"wifi":{"sta_ip":"172.24.74.76","status":"got ip","ssid":"WcNet","rssi":-60},"ws":{"connected":false}}}
2023-04-17 11:27:06.595 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_bagno: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:06.598 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1pm-sc_bagno: Updating 1 relay(s)
here log without grep:
2023-04-17 11:27:01.076 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: CoIoT Message from /172.24.74.73:5683 (MID=49019): {"G":[[0,9103,0],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,5139],[0,6103,"normal"],[0,3104,42.36],[0,6101,0],[0,9101,"roller"],[0,4108,224.55]]}
2023-04-17 11:27:01.077 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:01.078 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: CoIoT Sensor data {"G":[[0,9103,0],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,5139],[0,6103,"normal"],[0,3104,42.36],[0,6101,0],[0,9101,"roller"],[0,4108,224.55]]} (serial=40309)
2023-04-17 11:27:01.080 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: 16 CoAP sensor updates received
2023-04-17 11:27:01.082 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[0]: id=9103, Value=0.0 (cfgChanged, Type=EVC, Range=U16, Link=4: device)
2023-04-17 11:27:01.084 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[1]: id=1102, Value=stop (roller, Type=S, Range=open/close/stop, Link=3: roller_0)
2023-04-17 11:27:01.087 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[2]: id=1103, Value=100.0 (rollerPos, Type=S, Range=0/100;-1, Link=3: roller_0)
2023-04-17 11:27:01.089 [DEBUG] [y.internal.api1.Shelly1CoIoTVersion2] - shelly25-roller-rs_sala: CoAP update roller position: control=0, position=100
2023-04-17 11:27:01.090 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[3]: id=2101, Value=0.0 (input, Type=S, Range=0/1, Link=1: relay_0)
2023-04-17 11:27:01.091 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[4]: id=2102, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=1: relay_0)
2023-04-17 11:27:01.093 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[5]: id=2103, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=1: relay_0)
2023-04-17 11:27:01.094 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_sala: Check button[0] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=40309, count=0, lastEventCount[0]=0
2023-04-17 11:27:01.096 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[6]: id=2201, Value=0.0 (input, Type=S, Range=0/1, Link=2: relay_1)
2023-04-17 11:27:01.097 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[7]: id=2202, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=2: relay_1)
2023-04-17 11:27:01.102 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[8]: id=2203, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=2: relay_1)
2023-04-17 11:27:01.104 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_sala: Check button[1] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=40309, count=0, lastEventCount[1]=0
2023-04-17 11:27:01.106 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[9]: id=4102, Value=0.0 (rollerPower, Type=P, Range=0/2300;-1, Link=3: roller_0)
2023-04-17 11:27:01.107 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[10]: id=4104, Value=5139.0 (rollerEnergy, Type=E, Range=U32;-1, Link=3: roller_0)
2023-04-17 11:27:01.109 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[11]: id=6103, Value=normal (rollerStopReason, Type=A, Range=normal/safety_switch/obstacle/overpower, Link=3: roller_0)
2023-04-17 11:27:01.113 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[12]: id=3104, Value=42.36 (deviceTemp, Type=T, Range=-40/300;999, Link=4: device)
2023-04-17 11:27:01.114 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[13]: id=6101, Value=0.0 (overtemp, Type=A, Range=0/1;-1, Link=4: device)
2023-04-17 11:27:01.115 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[14]: id=9101, Value=roller (mode, Type=S, Range=relay/roller, Link=4: device)
2023-04-17 11:27:01.116 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Sensor value[15]: id=4108, Value=224.55 (voltage, Type=V, Range=null, Link=4: device)
2023-04-17 11:27:01.122 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: CoIoT Message from /172.24.74.73:5683 (MID=49019): {"G":[[0,9103,0],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,5139],[0,6103,"normal"],[0,3104,42.36],[0,6101,0],[0,9101,"roller"],[0,4108,224.55]]}
2023-04-17 11:27:01.123 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_sala: Thing is shutting down, ignore CoIOT message
2023-04-17 11:27:01.349 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_sala: HTTP GET for http://172.24.74.73/status
2023-04-17 11:27:01.393 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_sala: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.73","rssi":-82},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723621,"serial":30109,"has_update":false,"mac":"40F520015BF8","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"cloud","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730821,"counters":[0.000, 0.000, 0.000],"total":2719},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730821,"counters":[0.000, 0.000, 0.000],"total":2420}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":42.36,"overtemperature":false,"tmp":{"tC":42.36,"tF":108.26, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37740,"fs_size":233681,"fs_free":144827,"voltage":224.55,"uptime":1361516}
2023-04-17 11:27:01.394 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:01.395 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_sala: Updating 1 rollers
2023-04-17 11:27:01.396 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: Update roller position to 100/0, state=stop
2023-04-17 11:27:01.400 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: 0 more updates requested
2023-04-17 11:27:03.789 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: CoIoT Message from /172.24.74.75:5683 (MID=63685): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,7308],[0,6103,"normal"],[0,3104,43.08],[0,6101,0],[0,9101,"roller"],[0,4108,225.86]]}
2023-04-17 11:27:03.791 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Thing is shutting down, ignore CoIOT message
2023-04-17 11:27:03.793 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: CoIoT Message from /172.24.74.75:5683 (MID=63685): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,7308],[0,6103,"normal"],[0,3104,43.08],[0,6101,0],[0,9101,"roller"],[0,4108,225.86]]}
2023-04-17 11:27:03.795 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_bagno: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:03.797 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: CoIoT Sensor data {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,7308],[0,6103,"normal"],[0,3104,43.08],[0,6101,0],[0,9101,"roller"],[0,4108,225.86]]} (serial=30157)
2023-04-17 11:27:03.799 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: 16 CoAP sensor updates received
2023-04-17 11:27:03.801 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[0]: id=9103, Value=1.0 (cfgChanged, Type=EVC, Range=U16, Link=4: device)
2023-04-17 11:27:03.803 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[1]: id=1102, Value=stop (roller, Type=S, Range=open/close/stop, Link=3: roller_0)
2023-04-17 11:27:03.805 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[2]: id=1103, Value=100.0 (rollerPos, Type=S, Range=0/100;-1, Link=3: roller_0)
2023-04-17 11:27:03.807 [DEBUG] [y.internal.api1.Shelly1CoIoTVersion2] - shelly25-roller-rs_bagno: CoAP update roller position: control=0, position=100
2023-04-17 11:27:03.809 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[3]: id=2101, Value=0.0 (input, Type=S, Range=0/1, Link=1: relay_0)
2023-04-17 11:27:03.811 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[4]: id=2102, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=1: relay_0)
2023-04-17 11:27:03.813 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[5]: id=2103, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=1: relay_0)
2023-04-17 11:27:03.815 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_bagno: Check button[0] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=30157, count=0, lastEventCount[0]=0
2023-04-17 11:27:03.817 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[6]: id=2201, Value=0.0 (input, Type=S, Range=0/1, Link=2: relay_1)
2023-04-17 11:27:03.818 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[7]: id=2202, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=2: relay_1)
2023-04-17 11:27:03.820 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[8]: id=2203, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=2: relay_1)
2023-04-17 11:27:03.822 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_bagno: Check button[1] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=30157, count=0, lastEventCount[1]=0
2023-04-17 11:27:03.824 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[9]: id=4102, Value=0.0 (rollerPower, Type=P, Range=0/2300;-1, Link=3: roller_0)
2023-04-17 11:27:03.827 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[10]: id=4104, Value=7308.0 (rollerEnergy, Type=E, Range=U32;-1, Link=3: roller_0)
2023-04-17 11:27:03.830 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[11]: id=6103, Value=normal (rollerStopReason, Type=A, Range=normal/safety_switch/obstacle/overpower, Link=3: roller_0)
2023-04-17 11:27:03.832 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[12]: id=3104, Value=43.08 (deviceTemp, Type=T, Range=-40/300;999, Link=4: device)
2023-04-17 11:27:03.834 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[13]: id=6101, Value=0.0 (overtemp, Type=A, Range=0/1;-1, Link=4: device)
2023-04-17 11:27:03.836 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[14]: id=9101, Value=roller (mode, Type=S, Range=relay/roller, Link=4: device)
2023-04-17 11:27:03.838 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: Sensor value[15]: id=4108, Value=225.86 (voltage, Type=V, Range=null, Link=4: device)
2023-04-17 11:27:03.846 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_bagno: 1 channels updated from CoIoT status, serial=30157
2023-04-17 11:27:03.861 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_bagno: HTTP GET for http://172.24.74.75/status
2023-04-17 11:27:03.919 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_bagno: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.75","rssi":-67},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723623,"serial":52597,"has_update":false,"mac":"84CCA8A09D08","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"cloud","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730823,"counters":[0.000, 0.000, 0.000],"total":3675},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730823,"counters":[0.000, 0.000, 0.000],"total":3633}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":43.08,"overtemperature":false,"tmp":{"tC":43.08,"tF":109.55, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37688,"fs_size":233681,"fs_free":144827,"voltage":225.86,"uptime":2378921}
2023-04-17 11:27:03.922 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_bagno: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:03.924 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_bagno: Updating 1 rollers
2023-04-17 11:27:03.926 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_bagno: Update roller position to 100/0, state=stop
2023-04-17 11:27:03.931 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_bagno: 0 more updates requested
2023-04-17 11:27:04.402 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_sala: HTTP GET for http://172.24.74.73/status
2023-04-17 11:27:04.450 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_sala: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.73","rssi":-82},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723625,"serial":30109,"has_update":false,"mac":"40F520015BF8","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"cloud","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730825,"counters":[0.000, 0.000, 0.000],"total":2719},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730825,"counters":[0.000, 0.000, 0.000],"total":2420}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":42.36,"overtemperature":false,"tmp":{"tC":42.36,"tF":108.26, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37556,"fs_size":233681,"fs_free":144827,"voltage":224.55,"uptime":1361519}
2023-04-17 11:27:04.454 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:04.457 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_sala: Updating 1 rollers
2023-04-17 11:27:04.459 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_sala: Update roller position to 100/0, state=stop
2023-04-17 11:27:05.483 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_camera: CoIoT Message from /172.24.74.72:5683 (MID=20070): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,86],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,29534],[0,6103,"normal"],[0,3104,46.30],[0,6101,0],[0,9101,"roller"],[0,4108,226.27]]}
2023-04-17 11:27:05.486 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_camera: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:05.488 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_camera: Serial 21554 was already processed, ignore update
2023-04-17 11:27:05.490 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_camera: CoIoT Message from /172.24.74.72:5683 (MID=20070): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,86],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,29534],[0,6103,"normal"],[0,3104,46.30],[0,6101,0],[0,9101,"roller"],[0,4108,226.27]]}
2023-04-17 11:27:05.491 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_camera: Thing is shutting down, ignore CoIOT message
2023-04-17 11:27:05.501 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: CoIoT Message from /172.24.74.74:5683 (MID=32593): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,57078],[0,6103,"normal"],[0,3104,42.87],[0,6101,0],[0,9101,"roller"],[0,4108,224.95]]}
2023-04-17 11:27:05.503 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Thing is shutting down, ignore CoIOT message
2023-04-17 11:27:05.504 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: CoIoT Message from /172.24.74.74:5683 (MID=32593): {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,57078],[0,6103,"normal"],[0,3104,42.87],[0,6101,0],[0,9101,"roller"],[0,4108,224.95]]}
2023-04-17 11:27:05.506 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:05.507 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: CoIoT Sensor data {"G":[[0,9103,1],[0,1102,"stop"],[0,1103,100],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4102,0.00],[0,4104,57078],[0,6103,"normal"],[0,3104,42.87],[0,6101,0],[0,9101,"roller"],[0,4108,224.95]]} (serial=19710)
2023-04-17 11:27:05.508 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: 16 CoAP sensor updates received
2023-04-17 11:27:05.510 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[0]: id=9103, Value=1.0 (cfgChanged, Type=EVC, Range=U16, Link=4: device)
2023-04-17 11:27:05.511 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[1]: id=1102, Value=stop (roller, Type=S, Range=open/close/stop, Link=3: roller_0)
2023-04-17 11:27:05.511 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[2]: id=1103, Value=100.0 (rollerPos, Type=S, Range=0/100;-1, Link=3: roller_0)
2023-04-17 11:27:05.512 [DEBUG] [y.internal.api1.Shelly1CoIoTVersion2] - shelly25-roller-rs_cucina: CoAP update roller position: control=0, position=100
2023-04-17 11:27:05.514 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[3]: id=2101, Value=0.0 (input, Type=S, Range=0/1, Link=1: relay_0)
2023-04-17 11:27:05.515 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[4]: id=2102, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=1: relay_0)
2023-04-17 11:27:05.516 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[5]: id=2103, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=1: relay_0)
2023-04-17 11:27:05.517 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_cucina: Check button[0] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=19710, count=0, lastEventCount[0]=0
2023-04-17 11:27:05.518 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[6]: id=2201, Value=0.0 (input, Type=S, Range=0/1, Link=2: relay_1)
2023-04-17 11:27:05.519 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[7]: id=2202, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=2: relay_1)
2023-04-17 11:27:05.520 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[8]: id=2203, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=2: relay_1)
2023-04-17 11:27:05.522 [TRACE] [y.internal.api1.Shelly1CoIoTProtocol] - shelly25-roller-rs_cucina: Check button[1] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=19710, count=0, lastEventCount[1]=0
2023-04-17 11:27:05.523 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[9]: id=4102, Value=0.0 (rollerPower, Type=P, Range=0/2300;-1, Link=3: roller_0)
2023-04-17 11:27:05.524 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[10]: id=4104, Value=57078.0 (rollerEnergy, Type=E, Range=U32;-1, Link=3: roller_0)
2023-04-17 11:27:05.526 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[11]: id=6103, Value=normal (rollerStopReason, Type=A, Range=normal/safety_switch/obstacle/overpower, Link=3: roller_0)
2023-04-17 11:27:05.527 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[12]: id=3104, Value=42.87 (deviceTemp, Type=T, Range=-40/300;999, Link=4: device)
2023-04-17 11:27:05.528 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[13]: id=6101, Value=0.0 (overtemp, Type=A, Range=0/1;-1, Link=4: device)
2023-04-17 11:27:05.530 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[14]: id=9101, Value=roller (mode, Type=S, Range=relay/roller, Link=4: device)
2023-04-17 11:27:05.531 [TRACE] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: Sensor value[15]: id=4108, Value=224.95 (voltage, Type=V, Range=null, Link=4: device)
2023-04-17 11:27:05.535 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shelly25-roller-rs_cucina: 1 channels updated from CoIoT status, serial=19710
2023-04-17 11:27:07.535 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_cucina: HTTP GET for http://172.24.74.74/status
2023-04-17 11:27:07.593 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_cucina: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.74","rssi":-75},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723627,"serial":65100,"has_update":false,"mac":"40F520018D04","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"cloud","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730827,"counters":[0.000, 0.000, 0.000],"total":27947},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730827,"counters":[0.000, 0.000, 0.000],"total":29131}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":42.87,"overtemperature":false,"tmp":{"tC":42.87,"tF":109.16, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37688,"fs_size":233681,"fs_free":144827,"voltage":224.95,"uptime":11825148}
2023-04-17 11:27:07.599 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:07.602 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_cucina: Updating 1 rollers
2023-04-17 11:27:07.604 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: Update roller position to 100/0, state=stop
2023-04-17 11:27:07.614 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: 0 more updates requested
2023-04-17 11:27:08.118 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_camera: HTTP GET for http://172.24.74.72/status
2023-04-17 11:27:08.203 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_camera: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.72","rssi":-89},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723628,"serial":12884,"has_update":false,"mac":"E8DB84AA3BDE","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"input","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"close","current_pos":86,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730828,"counters":[0.000, 0.000, 0.000],"total":14624},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730828,"counters":[0.000, 0.000, 0.000],"total":14910}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":46.30,"overtemperature":false,"tmp":{"tC":46.30,"tF":115.34, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37716,"fs_size":233681,"fs_free":145329,"voltage":226.27,"uptime":6565493}
2023-04-17 11:27:08.207 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_camera: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:08.210 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_camera: Updating 1 rollers
2023-04-17 11:27:08.212 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_camera: Update roller position to 86/14, state=stop
2023-04-17 11:27:11.536 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '10686' on item 'STAMPA3D_TIME' with pattern 'SCRIPT(graaljs:cputime.script):%s': Couldn't transform value because transformation service of type 'SCRIPT' is not available.
2023-04-17 11:27:11.782 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '4207' on item 'STAMPA3D_REMAINING' with pattern 'SCRIPT(graaljs:cputime.script):%s': Couldn't transform value because transformation service of type 'SCRIPT' is not available.
2023-04-17 11:27:12.985 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_lavello: Status update triggered thing initialization
2023-04-17 11:27:12.988 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_lavello: Start initializing for thing Scalda lavello, type shellyplus1pm, IP address 172.24.74.77, Gen2: true, CoIoT: false
2023-04-17 11:27:12.991 [TRACE] [shelly.internal.api.ShellyHttpClient] - Scalda lavello: HTTP GET for http://172.24.74.77/shelly
2023-04-17 11:27:13.617 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_cucina: HTTP GET for http://172.24.74.74/status
2023-04-17 11:27:13.694 [TRACE] [shelly.internal.api.ShellyHttpClient] - shelly25-roller-rs_cucina: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"WcNet","ip":"172.24.74.74","rssi":-75},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:27","unixtime":1681723633,"serial":65100,"has_update":false,"mac":"40F520018D04","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"cloud","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730833,"counters":[0.000, 0.000, 0.000],"total":27947},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1681730833,"counters":[0.000, 0.000, 0.000],"total":29131}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":43.16,"overtemperature":false,"tmp":{"tC":43.16,"tF":109.68, "is_valid":true},"temperature_status":"Normal","update":{"status":"idle","has_update":false,"new_version":"20221027-092056/v1.12.1-ga9117d3","old_version":"20221027-092056/v1.12.1-ga9117d3","beta_version":"20230329-161747/v1.13.0-rc2-g1b3e5af"},"ram_total":50728,"ram_free":37504,"fs_size":233681,"fs_free":144827,"voltage":224.95,"uptime":11825154}
2023-04-17 11:27:13.698 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: Watchdog restarted (expires in 70 sec)
2023-04-17 11:27:13.701 [TRACE] [.internal.handler.ShellyRelayHandler] - shelly25-roller-rs_cucina: Updating 1 rollers
2023-04-17 11:27:13.703 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-rs_cucina: Update roller position to 100/0, state=stop
is here anyone with experience regarding the shelly plus addon?
I added a plus addon to some of my plus 2 pm roller shellys to interface with some magnetic switches for open window detection.
As far as my understanding of the documentation goes, you just need to delete and add the thing again after configuring the addon itself AND of course the Input in the shelly web interface, wich i did.
(shelly shows the Digital input correctly in the webinterface)
But i cant see a corresponding channel in Openhab.
(OH 3.4.3, lxc container, debian, everything out of the deb packages)
Am i doing anything wrong?
Does the shelly addon not work with OH, plus 2 pm in roller-mode?
can somebody give me a hint here?
I doubt that most users are not on 4.0
- make sure the regular bindig included in the dist is uninstalled
- install coap-transport and DEV build
- go to OH console
- check status of the binding with bundle:list
- should be Active,if not run “bundle:stop ” followed by bundle:start
- if bundle is Active, check log for details, maybe set to TRACE mode
The Plus Addon is not supported by the binding version in the official 3.4.2 dist. You have to install the DEV build. In addition you have to add the desired sensors using the device UI. After that run the discovery and you should get the additional channels.
Check READMEbeta when installing the DEV build for the first time
3.4.3-DEV Gen1/Plus/Pro | 4.0.0-DEV Gen1/Plus/Pro | README | READMEbeta
Avdanced Users - Shelly Manager - Bugs/Features - API Doc | Firmware Index - Firmware Archive
Note: The DEV build is always newer than the version in the official Distro or Milestone builds
I don’t see any request to update Auto ON/OFF for device “shellyplus1pm-sc_bagno”.
You should see a message like “shellyplus1pm-sc_bagno: Set Auto-ON timer to XX”"
This is very strange…
at the moment i’m using openhab 4 Milestone 2 and
27 │ Active │ 80 │ 4.0.0.202304121929 │ openHAB Add-ons :: Bundles :: Shelly Binding Gen1+2
this is my thing:
Thing shelly:shellyplus1pm:SC_BAGNO "Scaldabagno" @ "Bagno" [deviceIp="172.24.74.76", userId="", password=""]
this is my item:
Number SHELLY_AUTO_OFF "AAA Scelly Value [%.1f s]" <energy> {channel="shelly:shellyplus1pm:SC_BAGNO:relay#autoOff" }
i fire this rule:
rule "AA_Test Shelly"
Item SpostaPoveriFind changed from OFF to ON
logInfo("Shelly rule", "shellyplus1pm-sc_bagno")
SHELLY_AUTO_OFF.postUpdate (124)
but in the log i find only this:
2023-04-20 12:18:28.496 [INFO ] [penhab.core.model.script.Shelly rule] - shellyplus1pm-sc_bagno
2023-04-20 12:19:07.302 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP POST for http://172.24.74.76/rpc {"id":51911380,"src":"shellyplus1pm-sc_bagno","method":"Shelly.GetStatus"}
2023-04-20 12:19:07.348 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP Response 200: {"id":51911380,"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","result":{"ble":null,"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"timer", "output":false, "apower":0.0, "voltage":216.1, "current":0.000, "aenergy":{"total":103253.344,"by_minute":[0.000,0.000,0.000],"minute_ts":1681985946},"temperature":{"tC":48.2, "tF":118.7}},"sys":{"mac":"7C87CE64A7D8","restart_required":false,"time":"12:19","unixtime":1681985947,"uptime":2977482,"ram_size":234480,"ram_free":156680,"fs_size":458752,"fs_free":94208,"cfg_rev":70,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":null},"wifi":{"sta_ip":"172.24.74.76","status":"got ip","ssid":"WcNet","rssi":-66},"ws":{"connected":false}}}
2023-04-20 12:19:07.353 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_bagno: Watchdog restarted (expires in 70 sec)
2023-04-20 12:19:07.356 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1pm-sc_bagno: Updating 1 relay(s)
2023-04-20 12:20:07.378 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP POST for http://172.24.74.76/rpc {"id":450210903,"src":"shellyplus1pm-sc_bagno","method":"Shelly.GetStatus"}
2023-04-20 12:20:07.423 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP Response 200: {"id":450210903,"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","result":{"ble":null,"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"timer", "output":false, "apower":0.0, "voltage":217.7, "current":0.000, "aenergy":{"total":103253.344,"by_minute":[0.000,0.000,0.000],"minute_ts":1681986006},"temperature":{"tC":48.1, "tF":118.5}},"sys":{"mac":"7C87CE64A7D8","restart_required":false,"time":"12:20","unixtime":1681986007,"uptime":2977542,"ram_size":234480,"ram_free":156676,"fs_size":458752,"fs_free":94208,"cfg_rev":70,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":null},"wifi":{"sta_ip":"172.24.74.76","status":"got ip","ssid":"WcNet","rssi":-66},"ws":{"connected":false}}}
2023-04-20 12:20:07.429 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1pm-sc_bagno: Watchdog restarted (expires in 70 sec)
2023-04-20 12:20:07.433 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1pm-sc_bagno: Updating 1 relay(s)
2023-04-20 12:21:07.455 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP POST for http://172.24.74.76/rpc {"id":179296675,"src":"shellyplus1pm-sc_bagno","method":"Shelly.GetStatus"}
2023-04-20 12:21:07.499 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1pm-sc_bagno: HTTP Response 200: {"id":179296675,"src":"shellyplus1pm-7c87ce64a7d8","dst":"shellyplus1pm-sc_bagno","result":{"ble":null,"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"timer", "output":false, "apower":0.0, "voltage":217.4, "current":0.000, "aenergy":{"total":103253.344,"by_minute":[0.000,0.000,0.000],"minute_ts":1681986066},"temperature":{"tC":47.9, "tF":118.3}},"sys":{"mac":"7C87CE64A7D8","restart_required":false,"time":"12:21","unixtime":1681986067,"uptime":2977602,"ram_size":234480,"ram_free":156672,"fs_size":458752,"fs_free":94208,"cfg_rev":70,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":null},"wifi":{"sta_ip":"172.24.74.76","status":"got ip","ssid":"WcNet","rssi":-67},"ws":{"connected":false}}}
Do you suggest to install in another computer the version 3.4.3 and try with this to avoid 4.0 bugs?
Hi, i installed the Snapshot/dev build like described in your ReadmeBeta.
(uninstallled official Plugin, removed all things (saving the name of the things), install feature via CLI, stop OH, download and copy snap in addons folder, start OH, rediscover things)
However the Shelly addons on my Shelly Plus 2 PM-Roller are still not shown. (No additional channels after readding the things)
The configured Input on the 2PM gets listed in the getConfig Web RTC Call, so at shelly side, everything should be configured correctly.
Did you added the sensors in the device UI?
Of course, they also show in the getConfig WebRTC Call as input 100
HI Sebastian,
I exactly have the same issue like you. Can you please tell me how exactly you solved the issue. Where and how do you configured your NTP server? Or where you unblocked you NTP for shelly devices.
Thanks a lot.
Tom
Hi Tommy,
I initially blocked NTP in my Router.
The Shellys are in a seperate VLAN and network, where everything is blocked by default (less for the shellys, but primarily for other IOT devices like humidifier,etc…)
I allowed the communication for NTP in the network and inserted an NTP server ip in the shelly web ui. After a restart of the shelly they got the correct time and everything worked.
please send me the GetConfig output
Hi all,
I bought two Shelly1 and installed each in a changeover switch. On one switch I do not see the status in OH when I turn on the light directly on the switch, If I do it via the Shelly APP then also not.
With the second everything works as it should.
Both shellys are set up the same and have the same firmware etc.
Does anyone have any ideas?
Working
UID: shelly:shelly1:ed48a28fa9
label: Shelly_HauseingangFlur
thingTypeUID: shelly:shelly1
configuration:
eventsCoIoT: true
deviceIp: 192.168.101.110
password: pw
updateInterval: 60
eventsButton: false
eventsPush: false
eventsSwitch: false
userId: admin
not working
UID: shelly:shelly1:2723fc3373
label: Shelly_Flur_OG
configuration:
eventsCoIoT: true
deviceIp: 192.168.101.106
password: pw
updateInterval: 60
eventsButton: false
eventsPush: false
eventsSwitch: false
userId: admin
2023-04-24 15:08:53.318 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly_HauseingangFlur_Betrieb' changed from OFF to ON
2023-04-24 15:10:53.448 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly_HauseingangFlur_Betrieb' changed from ON to OFF
try to discover and add the things in the UI and see if that makes a difference
This looks like a wrong input/switch config directly in the shelly device.
Please compare both.
Hi @hmerk
i have checked those devices and everything is similar. So i have resetted the faulty one and now every things works as expected.
I think it may be some issue to the bug i found on github, where after reboot of OH no status was visible.
But since reset i did not reboot OH.
I will monitor the status and update this Post.
Many Thanks
Simon
