Sorry for the late reply,
here you go
{"ble":{"enable":true,"rpc":{"enable":true},"observer":{"enable":false}},"cloud":{"enable":true,"server":"shelly-12-eu.shelly.cloud:6022/jrpc"},"cover:0":{"id":0, "name":null, "motor":{"idle_power_thr":2.00, "idle_confirm_period":0.25},"maxtime_open":60.00, "maxtime_close":60.00, "initial_state":"stopped", "invert_directions":false,"in_mode":"dual","swap_inputs":false, "safety_switch":{"enable":false, "direction":"both", "action":"stop","allowed_move":null},"power_limit":2800,"voltage_limit":280,"undervoltage_limit":0,"current_limit":10.00,"obstruction_detection":{"enable":false, "direction":"both", "action":"stop", "power_thr":189, "holdoff":1.00}},"input:0":{"id":0, "name":null, "type":"switch","invert":false,"factory_reset":true},"input:1":{"id":1, "name":null, "type":"switch","invert":false,"factory_reset":true},"input:100":{"id":100, "name":"Window", "type":"switch","invert":false,"factory_reset":false},"mqtt":{"enable":false,"server":null,"client_id":"shellyplus2pm-c049ef8621e0","user":null,"topic_prefix":"shellyplus2pm-c049ef8621e0","rpc_ntf":true,"status_ntf":false,"use_client_cert":false,"enable_rpc":true,"enable_control":true},"sys":{"device":{"name":"dev_gr_lv_main_cov","mac":"C049EF8621E0","fw_id":"20230308-091102/0.14.1-g22a4cb7","discoverable":true,"eco_mode":false,"profile":"cover","addon_type":"sensor"},"location":{"tz":"Europe/Berlin","lat":49.865710,"lon":8.626040},"debug":{"mqtt":{"enable":false},"websocket":{"enable":true},"udp":{"addr":null}},"ui_data":{},"rpc_udp":{"dst_addr":null,"listen_port":null},"sntp":{"server":"192.53.103.108"},"cfg_rev":21},"voltmeter:100":{"id":100, "name":null, "report_thr": 0.1},"wifi":{"ap":{"ssid":"ShellyPlus2PM-C049EF8621E0","is_open":false, "enable":true, "range_extender": {"enable":false}},"sta":{"ssid":"Brandl-IOT","is_open":false, "enable":true, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"sta1":{"ssid":"WLAN-LAN","is_open":false, "enable":false, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"roam":{"rssi_thr":-80,"interval":60}},"ws":{"enable":false,"server":null,"ssl_ca":"ca.pem"}}
Ich weis leider nicht, wie ich das ganze besser formatieren kann.
