Good afternoon. I am a new user to OH.
I have a Shelly DUO RGBW GU10 light bulb (https://www.shelly.cloud/en-es/products/product-overview/shelly-duo-rgbw-gu-10) and want to control it from OH.
I have added it as a thing using Shelly Binding’s auto discovery function. It is detected as shellycolorbulb. Once I have added the thing and all the channels to my model, I can only control the bulb in color mode. Both controls for white mode appear to have no effect. It looks like a control for changing mode to white (as it is present on the bulb’s web interface) is missing. I check out the documentation for Shelly Binding and it turns out that shellycolorbulb indeed does not have a mode channel.
I have tried @davorf 's suggestion:
since shellybulb appears to have mode channel, but it doesn’t change the bulb’s actual mode and thus I can’t control white channels.
I have also tried adding the thing manually as shellybulbduo, which only features white mode channels, and only the brightness channel is working, IF I set the mode manally to white via the web interface.
I am running OH 3.4.4 release build.
It looks like this has been discussed before by @davorf and @z4nD4R but doesn’t seems to have been solved.
