Shelly Binding
I posted this :point_down: two days ago and was asked to repost here. I hope that dropping a link is fine, too.
Hi, I believe same problem here. After upgrade to 4.1.0 no update status on the shellyplus1 input ..
Also reposting here as this seems to be the right place (sorry, new in the game)
2023-12-29 14:43:49.304 [INFO ] [org.openhab.core.Activator          ] - Starting openHAB 4.1.0 (build Release Build)
2023-12-29 14:43:51.214 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Vienna'.
2023-12-29 14:43:51.246 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_AT'.
2023-12-29 14:43:57.265 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://10.10.1.20:8080/shelly/wsevent's Observer
2023-12-29 14:44:14.971 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://10.10.1.20:8080/shelly/manager
2023-12-29 14:44:22.326 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-12-29 14:44:24.402 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2023-12-29 14:44:32.442 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2023-12-29 15:18:56.799 [WARN ] [/                                   ] - unavailable
java.lang.RuntimeException: Unable to load org.eclipse.jetty.websocket.server.WebSocketServerFactory
	at org.eclipse.jetty.websocket.servlet.WebSocketServletFactory$Loader.load(WebSocketServletFactory.java:54) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.websocket.servlet.WebSocketServlet.init(WebSocketServlet.java:140) ~[bundleFile:9.4.52.v20230823]
	at javax.servlet.GenericServlet.init(GenericServlet.java:180) ~[bundleFile:4.0.4]
	at org.ops4j.pax.web.service.spi.servlet.OsgiInitializedServlet.init(OsgiInitializedServlet.java:68) ~[bundleFile:?]
	at org.eclipse.jetty.servlet.ServletHolder$Wrapper.init(ServletHolder.java:1345) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:632) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.servlet.ServletHolder.getServlet(ServletHolder.java:486) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.servlet.ServletHolder.prepare(ServletHolder.java:759) ~[bundleFile:9.4.52.v20230823]
	at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHolder.prepare(PaxWebServletHolder.java:295) ~[bundleFile:?]
	at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHandler.doHandle(PaxWebServletHandler.java:316) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:234) ~[bundleFile:9.4.52.v20230823]
	at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:96) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:731) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.52.v20230823]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.52.v20230823]
Caused by: java.lang.ClassNotFoundException: org.eclipse.jetty.websocket.server.WebSocketServerFactory cannot be found by org.openhab.binding.shelly_4.1.0
	at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:541) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:536) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168) ~[org.eclipse.osgi-3.18.0.jar:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:525) ~[?:?]
	at java.lang.Class.forName0(Native Method) ~[?:?]
	at java.lang.Class.forName(Class.java:467) ~[?:?]
	at org.eclipse.jetty.websocket.servlet.WebSocketServletFactory$Loader.load(WebSocketServletFactory.java:48) ~[bundleFile:9.4.52.v20230823]
	... 42 more
2023-12-29 15:18:56.823 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /shelly/wsevent
javax.servlet.ServletException: javax.servlet.ServletException: java.lang.RuntimeException: Unable to load org.eclipse.jetty.websocket.server.WebSocketServerFactory
	at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:103) ~[?:?]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) ~[bundleFile:9.4.52.v20230823]
Caused by: javax.servlet.ServletException: java.lang.RuntimeException: Unable to load org.eclipse.jetty.websocket.server.WebSocketServerFactory
	at org.eclipse.jetty.websocket.servlet.WebSocketServlet.init(WebSocketServlet.java:147) ~[?:?]
	at org.ops4j.pax.web.service.spi.servlet.OsgiInitializedServlet.init(OsgiInitializedServlet.java:68) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder$Wrapper.init(ServletHolder.java:1345) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:632) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.getServlet(ServletHolder.java:486) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.prepare(ServletHolder.java:759) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHolder.prepare(PaxWebServletHolder.java:295) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHandler.doHandle(PaxWebServletHandler.java:316) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[?:?]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[?:?]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505) ~[?:?]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[?:?]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:234) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:96) ~[?:?]
	... 18 more
Caused by: java.lang.RuntimeException: Unable to load org.eclipse.jetty.websocket.server.WebSocketServerFactory
	at org.eclipse.jetty.websocket.servlet.WebSocketServletFactory$Loader.load(WebSocketServletFactory.java:54) ~[?:?]
	at org.eclipse.jetty.websocket.servlet.WebSocketServlet.init(WebSocketServlet.java:140) ~[?:?]
	... 18 more
	at org.eclipse.jetty.websocket.servlet.WebSocketServletFactory$Loader.load(WebSocketServletFactory.java:48) ~[?:?]
	... 18 more
2023-12-29 16:43:58.321 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://10.10.1.20:8080/shelly/manager
2023-12-29 16:53:08.893 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-08b61fcb6378: Device requires restart to activate changes
2023-12-29 16:53:11.136 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-08b61fcb6378: Device requires restart to activate changes
2023-12-29 17:23:10.731 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Stopped without executing or closing null
I have proposed a fix:
https://github.com/openhab/openhab-addons/pull/16150
sounds great, let me know as soon as it is ready to be tested.
I would like to test it, but I don’t know how.
Thx, tried it out, works fine!
Someone knows if also the door/window 2 devices are affected? They are not updating its state anymore. But I can’t see any websocket configuration on the devices. My H&T plus devices, I was able to switch to mqtt, but I do not have any idea for a workaround for the door window 2 devices.
Hi, yesterday I upgraded from 3.4.4 to 4.1.
I removed the Shelly dev binding, upgraded openhab and added Shelly dev 4.1.0.202312111959
2 things are strange..
My motion sensors are going in ā€œcommunication errorā€ state after a short time of inactivity. Coming back to online if a motion is detected.
second thing: I have no settings of the Shelly binding. And I can’t manually add a Shelly thing. The Shelly binding isn’t ā€œvisibleā€ in the openhab settings.
Luckily, my old data has been carried over.
Screenshot_2024-01-01-10-18-44-027_org.mozilla.firefox
Greets
You need to install COAP services.
In OH console
feature:install openhab-transport-coap
Everytime a clean cache is executed (e.g. during an OH update), remember to reinstall it.
I’ve read with tradfri binding it isn’t needed.. :thinking:
I try it…
Thx and a happy new year to all
Edit: unchanged…
Iā€˜m using the brightness channel of the dimmer as a switch and a dimmer item. Since upgrade from 3.4 to 4.1 the switch is also displayed with values: 0% when off and 1% when on.
How can I prevent the value of the switch from being displayed?
IMG_1126
Hi all,
as the Shelly has built-in MQTT, if you have some troubles with Shelly binding, there is always an alternative which should be more robust against firmware upgrades.
In post below you can find a Thing code for MQTT. Example Shelly Plug Plus S Gen1 and Gen2.
Hey all,
as one of my HT’s (in the garden) will not more report the humidity, I have orded an Shelly1 plus with an
AddOn Modul and a DHT22 sensor for temperature and humidity.
When I try now to include the Shelly 1 plus it is not recordniced right in my OH4.1 system with all the latest offical shelly binding. See here the status from the shelly 1 plus with addon modul:
grafik
After a minute or so, I get the error:
grafik
Any idea, whats wrong?
When I remove from the shelly config, the DHT22 it looks normal:
grafik
So why I cannot add the shelly plus 1, when a DHT22 is added in the shelly web ui settings itself?
Hello again. Next problem to solve: :slightly_smiling_face:
I have a Shelly Button BLU.
On a Shelly Plus 1 the BLU Gateway is activated and therefore the Gateway-script installed and running.
If I push the button I get in the Logs on the Shelly Plus the entry ā€œres.local_name undefinedā€.
shelly_bluetooth_rel:91 ADV b4:35:22:f5:2c:44: mfd={}, svc={"fcd2":"RAAmAWQ6AQ=="}
Does anyone know this behaviour?
Shelly binding does not appear in the list of my installed bindings (MainUI - settings -Add-on Settings). This means I cannot configure the binding anymore (set user, pw, etc.).
Does anyody else has this problem?
yes. I deinstalled dev binding and installed from Addon-store.. Now its there..
Yeah, I just saw the release notes. Good to know in advance that moving from dev binding to release binding will resolve the issue.
Thanks!
which firmware and binding are you running?
Shelly BLU Button 1 SBBT-002C: Fw Version 1.0.8
Shelly Plus 1: Fw Version 1.0.3
Binding 4.1.0
Edit: Solved.
Seems to be a problem of Shelly Plus Fw:
Updated Plus1 to newest 1.1.0 and now it is working.
