Dear HT and HT Plus users…
after trying, reading, frustation and more I find now the rootcause, why the HT plus are not like the HT
send to my two DEV and TEST system every 10 min their values…
HT’s are using CoIoT and sending more or less every 10 min to all clients, in my case my three system their values and OH and all systems are using them. All my other used Shelly Products act like that. Multiable use on different system from different sensors.
The HT PLUS do not have any more CoIoT. They use now WEBSOCKETS. WOW something new, I have not heard so far about that.
When creating the first the ITEM on the OH system the information for the WEBSOCKET is created and sended to the HT PLUS configuration.
This means, that only ONE, (1) OH system is able to get the values from the HT’s every 10 min.
I was not aware of this that GEN2 devices with battery (USB Powered in my case) only works this way. Normal GEN2 devices line, like my Shelly plus 1 with his AddOn works like before without this settings for WEBSOCKET.
I found this in the documenation for OH under chapter Shelly:
Generation 2: WebSockets
The Plus and Pro series of devices use WebSockets for device communication. Usually the binding establishes a WebSocket connection to the device (http port 80). However, battery powered devices like the Plus HT are not reachable while the device is in sleep mode. For those the binding sets up a so called “Outbound WebSocket” during device initialization. Afterwards the device wakes up and calls the configured URL, which is the processed by the binding. The device UI shows the URL when active. Battery powered devices could only report events to a single host, take care if you have multiple openHAB instances on the same network.
In the config from device it looks like that:
As summery for me, it’s now over, to have three 1:1 configed OH systems, which are all the time getting from all sensors all their data…
Have a issue free weekend OH and Shelly users…
