Shelly Binding
Hello, here is the information you want.
Thanks for your great commitment!
settings.json (1.7 KB) status.json (891 Bytes)
Hi Markus
I also recently got my Shelly 3em.
I’m available for testing the binding though, if possible on OH 2.4
Cheers
Nuno
ok, let‘s see what I could prepare by mid next week
thx
fyi: the lastest 2.5.5 distro also contains my PR 6764 even this was not mentioned the the release notes
Unfortunately the ‘next few days’ were a bit longer than anticipated, sry for that. :grimacing:
Today I tried the latest build (from about six days ago) I could find in your repository in combination with my RGBW2s. I tried controlling them with both coap enabled and coap disabled. In both cases I get the same timeout messages as before.
Also there are no button and relay events and action urls enabled since the RGBW2 is not supporting those as far as I know.
I think he means - as he saids - the Thing config.
There you have an attribute, called eventsCoIoT. You have to set it to eventsCoIoT=true
E.g.
Thing shelly:shellyrgbw2:12345                     	"Shelly RGBW 12345" 	[deviceIp="192.168.2.xxx", userId="xxx", password="xxx", eventsButton=false, eventsSwitch=false, eventsCoIoT=true]
CoIoT is always enabled in the shelly. You don’t have to enable or disable it in the WebApp, but you can enable or disable it in your Openhab Thing-Config.
In the WebApp of your RGBW2 you just have to clear the Action URLs.
Hope that helps a bit.
Cheers
Mario
The Shelly RGBW2s don’t have action URLs implemented in the current firmware (v1.5.7).
With ‘coap enabled/disabled’ I meant setting ‘eventsCoIoT=true/false’ in the things config file. :slightly_smiling_face:
fyi:
  • I added support for the ext temp sensors of Shelly 1/1PM (for now the additional channels are static and become N/A when the temp sensors are not installed. I’ll change this to dynamic creation of channels. thanks @hmerk for testing
  • Next will be Shelly Duo, testing with @igi
  • Basic info for EM3 is above, testing with @RolfV, @violine
  • @jcosta46 I just received an EM for testing and will look into the totalEnergy problem
  • @javaboon Did you tried the build with the build I provided?
@RolfV, @violine first build for EM3 is ready to test
https://github.com/markus7017/myfiles/blob/master/shelly/org.openhab.binding.shelly-2.5.2-SNAPSHOT.jar?raw=true
Hi Markus,
great! Thank you!
I updated the binding. It works!
In the appendix I have given the physical names and their units as examples for 1 phase.
Maybe you want to change that?
Look at the status output and the output in the PaperUI. Not all values are output.
@violine ok, will have a look to that
general: please don’t use the version in the repo for know, I inform here when problem is fixed
fyi: problem is fixed, dev build ok
external temp sensors for 1/1PM are now supported
does someone has a Shelly Door Window and could help with testing?
Hello Markus,
I’m counting the same problem described by @dilisi. Shortly I got the “UNINITIALIZED” status for Shely HT sensors after system (RPI) reboot and the OH will not receive sensor’s updates . You can find details in my last post on the community:
Unknown status for Shelly H&T Sensor after reboot.
I found until now that if I’ll restart the OH2 service after a system reboot, the define ShellyThings will change the state in “ONLINE”. But If I will again restart the OH2 service the state will again become “UNKNOWN” and I received the following error:
2020-02-29 20:34:42.145 [hingStatusInfoChangedEvent] - ‘shelly:shellyht:f2b672’ changed from INITIALIZING to UNKNOWN
2020-02-29 20:34:42.156 [hingStatusInfoChangedEvent] - ‘shelly:shellyht:f2b670’ changed from INITIALIZING to UNKNOWN
2020-02-29 20:34:47.322 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.authorizationFailed(ShellyBaseHandler.java:616) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.lambda$0(ShellyBaseHandler.java:134) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Please let me know if I should use your developed builds (The official 2.5 SNAPSHOT build or your private 2.5 DEV build ) considering that I’m using now openHAB 2.5.1-2 (Release Build). Please let me know how to proceed next
Thank you in advance!
yes, please the the dev build
is the device password protected?
Thank you for your prompt respond.
the device is with password protected. The password and user ID that I configure in the sensor WEB API (Internet & Security - > RESTRICT LOGIN ) I’m using inside of Shelly Binding Configuration and also for ShellyThings.
please provide a TRACE Log with the latest DEV build
Hi Markus,
Do you mean the problem with the 3EM?
Nope, for the HT issue above
but I already integrated the missing channels for EM3, will upload a new version later
In general:
  • If the device is in sleep mode there is no way to make it up (AFAIK, also no Wake-on-LAN)
  • the thing will state in state UNKNOWN until the device wakes up and can be initialized - that’s normal
  • even the device is in sleep mode and OH is restarted: that changes nothing to the device status, so it still remembers the IP address of the listener
  • a new event if triggered when the device wakes-up and send to the listener (http callback and/or CoIoT packet)
  • this is received by the binding and triggers an auto-initialization, you should see that in the log
  • once initialized the thing goes ONLINE
If that does not work for you or @dilisi I need a TRACE log showing initialization, restart and next device wakeup/event
My described problem has already been fixed (Shelly Binding). I also have no problem with the openHAB 2.5.1-2 (Release Build).
