okđ
Duo is implemented
@violine please check EM3 channels, please note: total is in the channel as kw/h, not W/min as the device reports
okđ
Duo is implemented
Hi Markus,
Is the download address the same?
https://github.com/markus7017/myfiles/blob/master/shelly/org.openhab.binding.shelly-2.5.2-SNAPSHOT.jar?raw=true
yes, thatâs the location getting continuous updates
Hello thank you for the nice binding. Can everybody help me. I have the follow error when Openhab start.
[ERROR] [y.mdns.internal.MDNSDiscoveryService] - Participant âorg.openhab.binding.shelly.internal.discovery.ShellyDiscoveryParticipantâ threw an exception
java.lang.IllegalArgumentException: Illegal character in authority at index 7: http://ikhh._sub._http._tcp.local.â address: '/192.168.178.XXX/settings
How i can update the binding. Only with the snapshot file or can i update the binding to 2.5.2 with a another way ?
Thank a lot for support
Here is a good information:
https://community.openhab.org/t/solved-openhabian-how-do-i-update-one-binding-to-latest-snapshot-only/69324/4
Please use the Karaf-console
https://www.openhab.org/docs/administration/console.html
Uninstall the version via PaperUI then add the jar file to /usr/share/openhab2/addons
and restart OH.
Hello Markus,
Thank you again for your complete answer. Iâm not sure why is still not working for me. I tried again to add the Shelly sensors via Paper UI to openhab2 after:
2020-03-01 20:21:53.194 [WARN ] [y.internal.handler.ShellyBaseHandler] - shellyht-f2b670: WARNING: Firmware might be too old (or beta release), installed: /20181128-144724 (), required minimal v1.5.2. The binding was tested with version 1.50+ only. Older versions might work, but do not support all features or show technical issues. Please consider upgrading to v1.5.0 or newer!
2020-03-01 20:21:53.202 [me.event.ThingUpdatedEvent] - Thing âshelly:shellyht:f2b670â has been updated.
2020-03-01 20:21:53.613 [me.event.ThingUpdatedEvent] - Thing âshelly:shellyht:f2b670â has been updated.
2020-03-01 20:21:53.637 [me.event.ThingUpdatedEvent] - Thing âshelly:shellyht:f2b670â has been updated.
2020-03-01 20:21:53.639 [hingStatusInfoChangedEvent] - âshelly:shellyht:f2b670â changed from UNKNOWN to ONLINE
2020-03-01 20:21:53.668 [vent.ItemStateChangedEvent] - Shellyht_Temp_Birouri changed from NULL to 21.90 °C
2020-03-01 20:21:55.813 [vent.ItemStateChangedEvent] - Shellyht_Temp_Birouri changed from 21.90 °C to 21.88 °C
2020-03-01 20:22:32.315 [temChannelLinkRemovedEvent] - Link âShellyht_Temp_Birouri => shelly:shellyht:f2b670:sensors#temperatureâ has been removed.
2020-03-01 20:25:20.410 [.ItemChannelLinkAddedEvent] - Link âShellyht_Birouri_Temperature-shelly:shellyht:f2b670:sensors#temperatureâ has been added.
2020-03-01 20:25:43.175 [me.event.ThingUpdatedEvent] - Thing âshelly:shellyht:f2b670â has been updated.
2020-03-01 20:25:45.166 [hingStatusInfoChangedEvent] - âshelly:shellyht:f2b670â changed from ONLINE to UNKNOWN
2020-03-01 20:25:50.168 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.authorizationFailed(ShellyBaseHandler.java:616) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.lambda$0(ShellyBaseHandler.java:134) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
And after weakup event:
2020-03-01 21:28:57.924 [hingStatusInfoChangedEvent] - 'shelly:shellyht:f2b670' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-01 21:28:57.971 [hingStatusInfoChangedEvent] - 'shelly:shellyht:f2b670' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-01 21:28:58.505 [me.event.InboxRemovedEvent] - Discovery Result with UID 'shelly:shellyht:f2b672' has been removed.
2020-03-01 21:29:00.003 [hingStatusInfoChangedEvent] - 'shelly:shellyht:f2b670' changed from INITIALIZING to UNKNOWN
2020-03-01 21:29:04.997 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
Please let me know if I still need to install your dev build even Iâm using now openHAB 2.5.1-2 (Release Build).
Another thing:
Iâm not sure if the checkbox present i the sensor Web GUI â Internet & Security â Enable action execution via CoAP (CoIOT) protocol.
I checked it since I sow that itâs used for sensor comunication (by default was not checked) âŠ
Also as you can see in the log message the sensors have old firmware (20181128-144724). I tried to upgrade via Web GUI or following those instructions but It didnât work.
Maybe this is related to my issue.
Please let me know what I could do next!
Thank you for your support !
That means
Donât use the version you in stall in PaperUI, this has to be deinstalled. Get the DEV build from the link provided and copy it to the addons folder
no need for
Hello Markus,
Please let me know how I can install the latest firmware. I tried to upgrade via Web GUI or following those instructions but It didnât work. In the WEB GUI I found the message that Iâm using the last version and If I tried the instruction from the upper link I recieved the following msg:
{âstatusâ:âupdatingâ,âhas_updateâ:false,ânew_versionâ:ââ,âold_versionâ:â20181128-144724/???â}
check the information here: https://github.com/markus7017/myfiles/blob/master/shelly/READMEbeta.md
replace 2.5.1 by 2.5.2
Is the HT connected to the Internet?
Hi Markus,
I have a ShellyEM connected to my solar panels and iâm receiving data. Both P1 and P2 are connected. I also have grafana and influxdb to visualise and calculate the wattâs.
But i have an issue when the returned valueâs are 0, it seems like that 0 valueâs are not always stored for some reason. See screenshot below, (green line)
When i execute a query for the P1 i see only these valueâs listed while the solar panels are connected for 2/3 weeks from now. I should expect more especially during the night.
select * from ShellyEMSHEM_Meter1_Watt where value=0
time value
1582211969696000000 0
1582215169884000000 0
1582303050969000000 0
1582385102060000000 0
1582469083687000000 0
1582472886131000000 0
1582476387330000000 0
1582560833034000000 0
1582648599437000000 0
1582735990639000000 0
1582820637895000000 0
1582903561061000000 0
1582995963708000000 0
1583081902047000000 0
1583166024211000000 0
When I connect to my shellyem using http://x.x.x.x/status
I see 0 valueâs during evening/night.
for example, the database contains valueâs like these.
select * from ShellyEMSHEM_Meter1_Watt limit 20
time value
1582211849006000000 -71.44
1582211909337000000 -68.78
1582212694125000000 -108.99
1582212754495000000 -107.73
1582212814841000000 -100.92
1582212875269000000 -95.66
1582212935623000000 -100.37
1582212995974000000 -103.7
1582213056391000000 -102.95
1582213116740000000 -104.27
1582213177155000000 -97.87
1582213237515000000 -95.73
1582213297862000000 -96.13
1582213358271000000 -93.03
1582213418640000000 -88.02
1582213479003000000 -86.93
1582213539468000000 -84.2
1582213599883000000 -84.85
1582213660210000000 -83.27
Thank you!
Whatâs in your persistence file? (You are storing these values through persistence to InfluxDB?) The default is every change which means that a long set of 0âs wonât get stored. You might want to force an update periodically by time. Or try every update. See this on persistence. Apologies if youâve already done this.
Good point! iâm very new to openhab but i think you put to the right direction.
I had configured on everyChange, and I changed that to everyMinute which seems like to solution. Grafana is showing me also 0 values.
Strategies {
everyMinute : â0 * * * * ?â
everyHour : â0 0 * * * ?â
everyDay : â0 0 0 * * ?â
Items {
gHeatAct*, gHeatSet*, gHeatValve* : strategy = everyChange, everyHour
ShellyEMSHEM_Meter1_Watt,ShellyEMSHEM_Meter2_Watt : strategy = everyMinute
Thank you!
Very cool! Do you like to contribute a how-to as a practical use case?
Hi Markus,
No problem! let me know where
I would suggest adding this to the README
Just send me a text block+the image (markup format) and I will copy that into the README
fyi:
Iâm planning to close the current PR at the weekend. This comes together with firmware 1.6 for the Shelly devices, which include significant CoIoT improvements (fixes + new status values). This allows using CoIoT updates for most of the sensor values near-realtime. Due to reduced polling it also addresses the timeout issue (I see ghat ver rare, but itâs not gone).
Itâs 1.6-rc5, which is already close to the final release coming in March. @igor and I did already lots of testing, quality is good and we have an excellent back channel to their dev team.
If you are interested to support with testing send me a PM and Iâll provide infos to get access to the latest DEV build and beta firmware
Again, Iâm still looking for someone with Door Window. Alterco canât provide test samples, because they have Corona impacted productions delays.
hi!
found this page at https://www.shelly-support.eu/forum
i c that you need somthing bout DW. what you need? iâve 2 devices here. one an garage door, ond on desk near me.
new in OH but over 50 shellys on stage dancing the time warp again!
wir können uns aber auch gern auf deutsch untehaltenâŠ
simon / da_Woody
