According to the code lastUpdate should get updated if any of the channel values has changed (device provided updated values). Please provide a log showing a sensor update. Keep in mind, same limitation: update means state / battery / temperature etc., no uptime, wifiSignal etc.
Many thanks iâll give it a try,
to get the updated binding i run apt-get update && upgrade? or reinstall?
Cheers
No, you have to install the DEV build, see: https://github.com/markus7017/myfiles/blob/master/shelly/READMEbeta.md
download the jar here
donât forget to deinstall the version, which comes in PaperUI
Sure. Here is a cycle of some changes OPEN/CLOSED
as well as vibration ON/OFF
. None update to the sensors#lastUpdate
included:
2020-05-12 20:36:28.638 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Message from /192.168.9.17:5683 (MID=25398): {"G":[[0,66,48],[0,55,0],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:36:28.641 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: Duplicate serial 256 will be processed, because payload is different: {"G":[[0,66,48],[0,55,0],[0,77,100],[0,88,-1],[0,99,0]]} vs. {"G":[[0,66,48],[0,55,1],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:36:28.645 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Sensor data {"G":[[0,66,48],[0,55,0],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:36:28.649 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 5 CoAP sensor updates received
2020-05-12 20:36:28.661 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#state updated with CLOSED (type class org.eclipse.smarthome.core.library.types.OpenClosedType).
2020-05-12 20:36:28.666 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 1 channels updated from CoIoT status
2020-05-12 20:36:28.686 [vent.ItemStateChangedEvent] - ShellyTuer changed from OPEN to CLOSED
2020-05-12 20:36:54.142 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Message from /192.168.9.17:5683 (MID=63203): {"G":[[0,66,35],[0,55,0],[0,77,100],[0,88,-1],[0,99,1]]}
2020-05-12 20:36:54.146 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: Duplicate serial 256 will be processed, because payload is different: {"G":[[0,66,35],[0,55,0],[0,77,100],[0,88,-1],[0,99,1]]} vs. {"G":[[0,66,48],[0,55,0],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:36:54.151 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Sensor data {"G":[[0,66,35],[0,55,0],[0,77,100],[0,88,-1],[0,99,1]]}
2020-05-12 20:36:54.156 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 5 CoAP sensor updates received
2020-05-12 20:36:54.170 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#vibration updated with ON (type class org.eclipse.smarthome.core.library.types.OnOffType).
2020-05-12 20:36:54.176 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 1 channels updated from CoIoT status
2020-05-12 20:36:54.180 [vent.ItemStateChangedEvent] - ShellyTuer_vibration changed from OFF to ON
2020-05-12 20:37:51.081 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Message from /192.168.9.17:5683 (MID=57768): {"G":[[0,66,20],[0,55,1],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:37:51.085 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: Duplicate serial 256 will be processed, because payload is different: {"G":[[0,66,20],[0,55,1],[0,77,100],[0,88,-1],[0,99,0]]} vs. {"G":[[0,66,35],[0,55,0],[0,77,100],[0,88,-1],[0,99,1]]}
2020-05-12 20:37:51.088 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Sensor data {"G":[[0,66,20],[0,55,1],[0,77,100],[0,88,-1],[0,99,0]]}
2020-05-12 20:37:51.092 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 5 CoAP sensor updates received
2020-05-12 20:37:51.112 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#state updated with OPEN (type class org.eclipse.smarthome.core.library.types.OpenClosedType).
2020-05-12 20:37:51.122 [vent.ItemStateChangedEvent] - ShellyTuer changed from CLOSED to OPEN
2020-05-12 20:37:51.133 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#vibration updated with OFF (type class org.eclipse.smarthome.core.library.types.OnOffType).
2020-05-12 20:37:51.136 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 2 channels updated from CoIoT status
2020-05-12 20:37:51.142 [vent.ItemStateChangedEvent] - ShellyTuer_vibration changed from ON to OFF
For reference, this is the current linking of the channels:
Group gShellyTuer
Contact ShellyTuer "EingangstĂŒr [%s]" (gShellyTuer, gMapdb) {channel="shelly:shellydw:tuer:sensors#state" }
Switch ShellyTuer_vibration "ErschĂŒtterung" (gShellyTuer) {channel="shelly:shellydw:tuer:sensors#vibration" }
String ShellyTuer_reason "Aufwachgrund [%s]" (gShellyTuer) {channel="shelly:shellydw:tuer:device#wakeupReason" }
DateTime ShellyTuer_last "Lebenszeichen [%1$ta, %1$te. %1$tb %1$tk:%1$tM]" (gShellyTuer) {channel="shelly:shellydw:tuer:sensors#lastUpdate" }
String ShellyTuer_error "Letzter Fehler [%s]" (gShellyTuer) {channel="shelly:shellydw:tuer:sensors#lastError" }
Number ShellyTuer_batt "Batterie" (gShellyTuer) {channel="shelly:shellydw:tuer:battery#batteryLevel" }
Number ShellyTuer_uptime "Laufzeit [%d s]" <clock_grey> (gShellyTuer) {channel="shelly:shellydw:tuer:device#uptime"}
Number ShellyTuer_rssi "SignalstÀrke [%d]" <wifi> (gShellyTuer) {channel="shelly:shellydw:tuer:device#wifiSignal"}
ok, I could confirm a bug. The timestamp is set, but after the updates to the channels have been performed. Iâll provide a new build once I completed another change.
ok, new DEV build
- fix for sensors#lastUpdate
- Watt updates are filtered, diff must be > 1W
- KW/h updates are filtered, diff must be > 0.05 kw/h (50W)
Are the thresholds suitable? I want to prevent the logfile getting flooded by power updates, on the other side the threshold shouldnât drop useful updates.
Feedback welcome.
Thanks markus it is working fine even the rule fires correctly,
020-05-13 00:15:25.147 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplug-7bcca9: Thing goes OFFLINE: message.offline.status-error-watchdog
2020-05-13 00:15:25.157 [hingStatusInfoChangedEvent] - 'shelly:shellyplug:7bcca9' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Watchdog expired - device did not update status, going OFFLINE.
2020-05-13 00:15:25.290 [INFO ] [e.model.script.heating-control.rules] - Heating control failed while in mode OFFLINE
2020-05-13 00:16:36.567 [WARN ] [y.internal.handler.ShellyBaseHandler] - shellyplug-7bcca9: Event triggered: RESTARTED
2020-05-13 00:16:36.571 [me.event.ThingUpdatedEvent] - Thing 'shelly:shellyplug:7bcca9' has been updated.
2020-05-13 00:16:36.593 [vent.ChannelTriggeredEvent] - shelly:shellyplug:7bcca9:device#alarm triggered RESTARTED
2020-05-13 00:16:36.607 [me.event.ThingUpdatedEvent] - Thing 'shelly:shellyplug:7bcca9' has been updated.
2020-05-13 00:16:36.618 [hingStatusInfoChangedEvent] - 'shelly:shellyplug:7bcca9' changed from OFFLINE (COMMUNICATION_ERROR): Watchdog expired - device did not update status, going OFFLINE. to ONLINE
2020-05-13 00:16:36.642 [INFO ] [e.model.script.heating-control.rules] - Heating control failed while in mode ONLINE
Thanks for testing, but this sounds incorrect âHeating control failed while in mode ONLINEâ. I assume is just a matter of your message?
Perfect - can confirm itâs now working as it expected:
2020-05-13 16:20:54.626 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: CoIoT Sensor data {"G":[[0,66,260],[0,55,1],[0,77,97],[0,88,-1],[0,99,0]]}
2020-05-13 16:20:54.630 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 5 CoAP sensor updates received
2020-05-13 16:20:54.647 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#lastUpdate updated with 2020-05-13T16:20:54.000+0200 (type class org.eclipse.smarthome.core.library.types.DateTimeType).
2020-05-13 16:20:54.654 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydw-tuer: Channel sensors#state updated with OPEN (type class org.eclipse.smarthome.core.library.types.OpenClosedType).
2020-05-13 16:20:54.658 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydw-tuer: 2 channels updated from CoIoT status
2020-05-13 16:20:54.679 [vent.ItemStateChangedEvent] - ShellyTuer_last changed from 2020-05-13T16:18:14.000+0200 to 2020-05-13T16:20:54.000+0200
2020-05-13 16:20:54.683 [vent.ItemStateChangedEvent] - ShellyTuer changed from CLOSED to OPEN
So, sensors#lastUpdate
now gets updated when any of the sensor values/states have changed.
Many thanks for your quick fix! Excellent!
Really aprecciate your responsiveness and continous improvement of this binding!
it is just my message , it is working fine,
cheers
I added this to PR #7595, so gets into 2.5.5, latest 2.5.6
This will get into the next PR, wonât expect this for 2.5.5, but depends when this release is closed.
Hi all,
After my first ShellyHT drained off may battery in about 2 weeks, I have got an replacement. I used same procedure to add this to my environment and can access WI once waked up. Status has been send this afternoon, than I hade to restart OpenHab and now Status is no longer updated, even when I wake device up. Any idea where this behaviour comes from??
Iâm not using (xxx) cloud, which has been disabled on all my Shelly devices as I only rely on this Binding to get values etc.
In addition I recognised different behaviour when I wake device up. LED is flashing slowly (just as I remember this from my first device) but after 3 or 4 times, itâs flashing faster. I have no clue why this is happening nor did I found anything at google :-/ while I trust this is not related to this binding, someone might help also on this?
Hi Markus,
Sorry to trouble you again,
I am unable to get the temperature,humidity,battery,lastupdate,motion and lux from shelly sense despite that the trace shows some channels getting updated:
2020-05-14 11:00:08.785 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,0],[0,33,26.223565],[0,44,75.096347],[0,66,35.064935],[0,77,100]]}
2020-05-14 11:00:08.787 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-14 11:00:08.788 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:08.790 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=0.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:08.792 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=26.223565 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-14 11:00:08.795 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=75.096347 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:08.798 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=35.064935 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:08.801 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=100.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:23.665 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=22491): {"G":[[0,11,0],[0,22,0],[0,33,26.185423],[0,44,75.186441],[0,66,33.766234],[0,77,100]]}
2020-05-14 11:00:23.667 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,0],[0,33,26.185423],[0,44,75.186441],[0,66,33.766234],[0,77,100]]}
2020-05-14 11:00:23.669 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-14 11:00:23.671 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:23.672 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=0.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:23.675 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=26.185423 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-14 11:00:23.677 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=75.186441 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:23.679 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=33.766234 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:23.681 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=100.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:23.686 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#humidity updated with 75.2 % (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-14 11:00:23.689 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#lux updated with 33.8 lx (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-14 11:00:23.692 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 2 channels updated from CoIoT status
2020-05-14 11:00:38.336 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=22492): {"G":[[0,11,0],[0,22,0],[0,33,26.204494],[0,44,75.210466],[0,66,35.064935],[0,77,100]]}
2020-05-14 11:00:38.338 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,0],[0,33,26.204494],[0,44,75.210466],[0,66,35.064935],[0,77,100]]}
2020-05-14 11:00:38.341 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-14 11:00:38.343 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:38.346 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=0.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:38.348 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=26.204494 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-14 11:00:38.352 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=75.210466 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:38.355 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=35.064935 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-14 11:00:38.358 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=100.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-14 11:00:38.364 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#lux updated with 35.1 lx (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-14 11:00:38.366 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 1 channels updated from CoIoT status
2020-05-14 11:00:40.554 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating status
2020-05-14 11:00:40.556 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-14 11:00:40.718 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-61},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:00","unixtime":1589454041,"serial":14,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":false,"tmp":{"value":26.185423,"is_valid":true,"units":"C"},"hum":{"value":75.225481,"is_valid":true},"lux":{"value":35.064935,"is_valid":true},"bat":{"value":100},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23920,"fs_size":83081,"fs_free":21837,"uptime":1105}
2020-05-14 11:00:40.722 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating sensor
2020-05-14 11:00:40.724 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-14 11:00:40.891 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-59},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:00","unixtime":1589454041,"serial":14,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":false,"tmp":{"value":26.166352,"is_valid":true,"units":"C"},"hum":{"value":75.249506,"is_valid":true},"lux":{"value":35.064935,"is_valid":true},"bat":{"value":100},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23916,"fs_size":83081,"fs_free":21837,"uptime":1105}
I noticed in paper ui only the following channels are discovered:
.Things declaration:
Thing shelly:shellysense:4b3fa4 "Shelly Sense (Temp/Humidity/IR)" @ "Elias Bedroom" [deviceIp="10.0.0.11", userId="", password="" , eventsSensorReport="true", eventsCoIoT="true" , updateInterval="60"]
.Items
Number Temperature_i "Temperature [%0.1f °C]" <temperature> (gTemperature, gElias) ["Temperature", "Measurement"] {channel="shelly:shellysense:4b3fa4:sensors#temperature"}
Number Humidity_i "Humidity [%0.1f %%]" <humidity> (gElias) ["Measurement"] {channel="shelly:shellysense:4b3fa4:sensors#humidity"}
Number Lux_i "Brightness [%0.1f Lux]" <lightbulb> (gElias) ["Measurement"] {channel="shelly:shellysense:4b3fa4:sensors#lux"}
Number Battery_i "Battery [%d %%]" <batterylevel> (gElias) ["Measurement"] {channel="shelly:shellysense:4b3fa4:battery#batterylevel"}
Switch Motion_i "Motion detected" <motion> (gElias) ["Measurement"] {channel="shelly:shellysense:4b3fa4:sensors#motion"}
String Lastupdate "LastUpdate: [%s]" <time> (gElias) ["Measurement"] {channel="shelly:shellysense:4b3fa4:sensors#lastUpdate"}
.Sitemap
Text label="Elias Room" icon="boy_2" {
Text item=Temperature_i
Switch item=Motion_i
Text item=Humidity_i
Text item=Lux_i
Text item=Battery_i
Text item=Lastupdate
{"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-61},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:31","unixtime":1589455864,"serial":33,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":false,"tmp":{"value":26.109139,"is_valid":true,"units":"C"},"hum":{"value":76.739057,"is_valid":true},"lux":{"value":40.259740,"is_valid":true},"bat":{"value":100},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":2928}
{"device":{"type":"SHSEN-1","mac":"xxxxxxx","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:32","unixtime":1589455920,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
Can you please advise, many thanks,
Check if it is included in your network first as changing battery might reset it; Just a thought
Yes, itâs included in network and I can access device when I wake it up and if I do restart binding at same time, itâs getting all values properly. But than it stuck again.
wake up has been confgured to take place either 1 degree of temp. or 10% humidity change or once every 2 hours.
Try the dev build above from markus
Another question to the community here,
Does any one knows how can we implement an interlock rule to prevent a shelly rollershutter from processing a close command before an open command has finished?
iâm not good with rules but i think i should look into when roller#input1 changes to OFF and monitor the power consumption (current watts), can anyone help please with such a rule,
Many thanks,
OK, thanks for the hint.
- made a backup
- deinstalled integrated binding
- removed/comment out all Shelly items in *.items
- updated to 2.5.5-snapshot (just to be on latest and corresponding version to Dev Binding)
- copied binding to get installed
- after all was up I experienced same issue as reported => missing californium.core :-/
- found the solution and installed featues, install went through
- my Plug-s became online again, while shallyht was still offline
- pushed button on shellyht and restarted binding => shellyht becomes online
- added/un-comment all shelly items => all were updated, except shellyht (LED was already off again)
- pushed button again, restarted shelly binding and now also shellyht reports the values
Letâs see if it will continue to send those, I 'll watching this and report.
I canât put down a rule right nowâŠanyway I think that this kind of behavior requires a proxy item for the rollershutter, because you canât prevent the default behavior when an item receive a command.
So I can guess the logic would be : ProxyRoller receive an up or down - > rule check the real state/power consumpiton of the RealRollerShutter -> do nothing or forward the command to the RealRollerShutter
Fine i wil try but how can i guarantee interlock when an up command is received for ex?
