please find below:
2020-05-16 11:37:22.181 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Shelly device discovered: IP-Adress=10.0.0.11, type=shellysense
2020-05-16 11:37:22.185 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/settings
2020-05-16 11:37:22.652 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:37","unixtime":1589629043,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:37:22.673 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/ir/list
2020-05-16 11:37:23.263 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: []
2020-05-16 11:37:23.272 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: Sense stored key list loaded, 0 entries.
2020-05-16 11:37:23.275 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Shelly settings : {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:37","unixtime":1589629043,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:37:23.276 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: thingType=shellysense, deviceType=SHSEN-1, mode=<standard>
2020-05-16 11:37:23.280 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Adding Shelly thing, UID=shelly:shellysense:4b3fa4
2020-05-16 11:37:27.287 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Shelly device discovered: IP-Adress=10.0.0.11, type=shellysense
2020-05-16 11:37:27.290 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/settings
2020-05-16 11:37:27.438 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:37","unixtime":1589629048,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:37:27.453 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/ir/list
2020-05-16 11:37:28.056 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: []
2020-05-16 11:37:28.060 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: Sense stored key list loaded, 0 entries.
2020-05-16 11:37:28.062 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Shelly settings : {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:37","unixtime":1589629048,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:37:28.064 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: thingType=shellysense, deviceType=SHSEN-1, mode=<standard>
2020-05-16 11:37:28.066 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellysense-4b3fa4: Adding Shelly thing, UID=shelly:shellysense:4b3fa4
2020-05-16 11:37:35.521 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellysense:4b3fa4' to inbox.
2020-05-16 11:37:35.524 [home.event.InboxAddedEvent] - Discovery Result with UID 'shelly:shellysense:4b3fa4' has been added.
2020-05-16 11:40:42.351 [me.event.InboxRemovedEvent] - Discovery Result with UID 'shelly:shellysense:4b3fa4' has been removed.
2020-05-16 11:40:42.358 [DEBUG] [shelly.internal.ShellyHandlerFactory] - shellysense-4b3fa4 - 10.0.0.11: Create new thing of type shelly:shellysense using ShellyRelayHandler
2020-05-16 11:40:42.451 [hingStatusInfoChangedEvent] - 'shelly:shellysense:4b3fa4' changed from UNINITIALIZED to INITIALIZING
2020-05-16 11:40:44.481 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Device config: IP address=10.0.0.11, HTTP user/password=<non>/<none>, update interval=3600
2020-05-16 11:40:44.487 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Configured Events: Button: false, Switch (on/off): true, Push: true, Roller: true, Sensor: false, CoIoT: true, Enable AutoCoIoT: true
2020-05-16 11:40:44.495 [hingStatusInfoChangedEvent] - 'shelly:shellysense:4b3fa4' changed from INITIALIZING to UNKNOWN
2020-05-16 11:40:44.494 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Start initializing thing shellysense-4b3fa4 - 10.0.0.11, type shellysense, ip address 10.0.0.11, CoIoT: true
2020-05-16 11:40:44.609 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Starting CoAP Listener
2020-05-16 11:40:44.611 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoAP Request was canceled
2020-05-16 11:40:44.637 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/shelly
2020-05-16 11:40:44.769 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"type":"SHSEN-1","mac":"D436394B3FA4","auth":false,"fw":"20200309-104151/v1.6.0@43056d58"}
2020-05-16 11:40:44.772 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/settings
2020-05-16 11:40:44.798 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=8277): {"blk":[{"I":1, "D":"Sensors"}],"sen":[{"I":11, "D":"Motion", "T":"M", "R":"0/1", "L":1},{"I":22, "D":"Charger", "T":"S", "R":"0/1", "L":1},{"I":33, "D":"Temperature", "T":"T", "R":"-40/125", "L":1},{"I":44, "D":"Humidity", "T":"H", "R":"0/100", "L":1},{"I":66, "D":"Lux", "T":"L", "R":"0/1", "L":1},{"I":77, "D":"Battery", "T":"B", "R":"0/100", "L":1}]}
2020-05-16 11:40:44.806 [hingStatusInfoChangedEvent] - 'shelly:shellysense:4b3fa4' changed from UNKNOWN to ONLINE
2020-05-16 11:40:44.805 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Device Description for SHSEN-1#4B3FA4#1: {"blk":[{"I":1, "D":"Sensors"}],"sen":[{"I":11, "D":"Motion", "T":"M", "R":"0/1", "L":1},{"I":22, "D":"Charger", "T":"S", "R":"0/1", "L":1},{"I":33, "D":"Temperature", "T":"T", "R":"-40/125", "L":1},{"I":44, "D":"Humidity", "T":"H", "R":"0/100", "L":1},{"I":66, "D":"Lux", "T":"L", "R":"0/1", "L":1},{"I":77, "D":"Battery", "T":"B", "R":"0/100", "L":1}]}
2020-05-16 11:40:44.820 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id=1: Sensors
2020-05-16 11:40:44.822 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Adding 6 sensor definitions
2020-05-16 11:40:44.824 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 11: Motion, Type=M, Range=0/1, Links=1
2020-05-16 11:40:44.827 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 22: Charger, Type=S, Range=0/1, Links=1
2020-05-16 11:40:44.828 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 33: Temperature, Type=T, Range=-40/125, Links=1
2020-05-16 11:40:44.831 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 44: Humidity, Type=H, Range=0/100, Links=1
2020-05-16 11:40:44.833 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 66: Lux, Type=L, Range=0/1, Links=1
2020-05-16 11:40:44.835 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: id 77: Battery, Type=B, Range=0/100, Links=1
2020-05-16 11:40:44.851 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Properties updated
2020-05-16 11:40:44.852 [me.event.ThingUpdatedEvent] - Thing 'shelly:shellysense:4b3fa4' has been updated.
2020-05-16 11:40:44.920 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:40","unixtime":1589629245,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:40:44.935 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/ir/list
2020-05-16 11:40:45.523 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=8278): {"G":[[0,11,0],[0,22,1],[0,33,29.274924],[0,44,43.686646],[0,66,15.584416],[0,77,99]]}
2020-05-16 11:40:45.528 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,1],[0,33,29.274924],[0,44,43.686646],[0,66,15.584416],[0,77,99]]}
2020-05-16 11:40:45.536 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-16 11:40:45.539 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:45.545 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=1.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:45.549 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=29.274924 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-16 11:40:45.565 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: []
2020-05-16 11:40:45.566 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=43.686646 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-16 11:40:45.570 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=15.584416 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:45.571 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: Sense stored key list loaded, 0 entries.
2020-05-16 11:40:45.574 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=99.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-16 11:40:45.576 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Initializing device shellysense-4b3fa4, type SHSEN-1, Hardware: Rev: , batch ; Firmware: v1.6.0 / 20200309-104151 (43056d58)
2020-05-16 11:40:45.582 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Shelly settings info for shellysense-4b3fa4: {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:40","unixtime":1589629245,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:40:45.586 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Device hasRelays:false (numRelays=0),isRoller:false (numRoller=0),isDimmer:false,isPlugS:false,numMeter=0,isEMeter:false),isSensor:true,isDS:false,hasBattery:false,isSense:true,isLight:false,isBulb:false,isDuo:false,isRGBW2:false,inColor:false,hasLEDs:false,updatePeriod:50sec
2020-05-16 11:40:45.586 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#humidity updated with 43.7 % (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:45.591 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:45.594 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#lux updated with 15.6 lx (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:45.604 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#motion updated with OFF (type class org.eclipse.smarthome.core.library.types.OnOffType).
2020-05-16 11:40:45.611 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#temperature updated with 29.3 °C (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:45.612 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 4 channels updated from CoIoT status
2020-05-16 11:40:45.753 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629246,"serial":8054,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.274924,"is_valid":true,"units":"C"},"hum":{"value":43.686646,"is_valid":true},"lux":{"value":15.584416,"is_valid":true},"bat":{"value":99},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23916,"fs_size":83081,"fs_free":21837,"uptime":176341}
2020-05-16 11:40:45.788 [me.event.ThingUpdatedEvent] - Thing 'shelly:shellysense:4b3fa4' has been updated.
2020-05-16 11:40:45.791 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Auto-CoIoT is enabled, disabling action urls
2020-05-16 11:40:45.793 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Starting CoIoT (autoCoIoT=true/true)
2020-05-16 11:40:45.796 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoAP Listener was already started
2020-05-16 11:40:45.798 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: Set Sensor Reporting URL
2020-05-16 11:40:45.820 [me.event.ThingUpdatedEvent] - Thing 'shelly:shellysense:4b3fa4' has been updated.
2020-05-16 11:40:45.821 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel device#alarm updated with NONE (type class org.eclipse.smarthome.core.library.types.StringType).
2020-05-16 11:40:45.824 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Thing successfully initialized.
2020-05-16 11:40:45.830 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Update status job started, interval=1200*3=3600sec.
2020-05-16 11:40:47.830 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/settings
2020-05-16 11:40:48.008 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"device":{"type":"SHSEN-1","mac":"D436394B3FA4","hostname":"shellysense-4B3FA4"},"wifi_ap":{"enabled":false,"ssid":"shellysense-4B3FA4","key":""},"wifi_sta":{"enabled":true,"ssid":"NickyGhz","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellysense-4B3FA4","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"","name":"","fw":"20200309-104151/v1.6.0@43056d58","discoverable":false,"build_info":{"build_id":"20200309-104151/v1.6.0@43056d58","build_timestamp":"2020-03-09T10:41:51Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Asia/Beirut","lat":33.893799,"lng":35.501801,"tzautodetect":true,"tz_utc_offset":10800,"tz_dst":true,"tz_dst_auto":true,"time":"11:40","unixtime":1589629248,"light_sensor":"NOA1305","schedule":false,"schedule_rules":[],"sensors":{"motion_duration":10,"motion_led":false,"temperature_unit":"C"}}
2020-05-16 11:40:48.029 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/ir/list
2020-05-16 11:40:48.642 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: []
2020-05-16 11:40:48.645 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: Sense stored key list loaded, 0 entries.
2020-05-16 11:40:48.650 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating status
2020-05-16 11:40:48.654 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:48.815 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629249,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.332137,"is_valid":true,"units":"C"},"hum":{"value":43.590546,"is_valid":true},"lux":{"value":15.584416,"is_valid":true},"bat":{"value":99},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":176344}
2020-05-16 11:40:48.822 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating sensor
2020-05-16 11:40:48.827 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:48.983 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629249,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.313066,"is_valid":true,"units":"C"},"hum":{"value":43.755718,"is_valid":true},"lux":{"value":15.584416,"is_valid":true},"bat":{"value":99},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":176344}
2020-05-16 11:40:49.009 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Unable to refresh status: Unable to update status
2020-05-16 11:40:49.061 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: 2 more updates requested
2020-05-16 11:40:52.064 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating status
2020-05-16 11:40:52.066 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:52.209 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-62},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629253,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.332137,"is_valid":true,"units":"C"},"hum":{"value":43.599556,"is_valid":true},"lux":{"value":14.285714,"is_valid":true},"bat":{"value":100},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":176347}
2020-05-16 11:40:52.216 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating sensor
2020-05-16 11:40:52.220 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:52.383 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-54},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629253,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.332137,"is_valid":true,"units":"C"},"hum":{"value":43.599556,"is_valid":true},"lux":{"value":14.285714,"is_valid":true},"bat":{"value":100},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":176348}
2020-05-16 11:40:52.393 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Unable to refresh status: Unable to update status
2020-05-16 11:40:52.408 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: 1 more updates requested
2020-05-16 11:40:55.412 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating status
2020-05-16 11:40:55.414 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:55.575 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-54},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629256,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.351208,"is_valid":true,"units":"C"},"hum":{"value":43.719681,"is_valid":true},"lux":{"value":15.584416,"is_valid":true},"bat":{"value":99},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23916,"fs_size":83081,"fs_free":21837,"uptime":176351}
2020-05-16 11:40:55.581 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Updating sensor
2020-05-16 11:40:55.585 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP GET for http://10.0.0.11/status
2020-05-16 11:40:55.741 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellysense-4b3fa4: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"NickyGhz","ip":"10.0.0.11","rssi":-54},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"11:40","unixtime":1589629256,"serial":8055,"has_update":false,"mac":"D436394B3FA4","motion":false,"charger":true,"tmp":{"value":29.351208,"is_valid":true,"units":"C"},"hum":{"value":43.719681,"is_valid":true},"lux":{"value":15.584416,"is_valid":true},"bat":{"value":99},"update":{"status":"idle","has_update":false,"new_version":"20200309-104151/v1.6.0@43056d58","old_version":"20200309-104151/v1.6.0@43056d58"},"ram_total":48020,"ram_free":23956,"fs_size":83081,"fs_free":21837,"uptime":176351}
2020-05-16 11:40:55.750 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: Unable to refresh status: Unable to update status
2020-05-16 11:40:55.765 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellysense-4b3fa4: 0 more updates requested
2020-05-16 11:40:56.104 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=43199): {"G":[[0,11,0],[0,22,1],[0,33,29.370279],[0,44,43.629587],[0,66,14.285714],[0,77,99]]}
2020-05-16 11:40:56.108 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,1],[0,33,29.370279],[0,44,43.629587],[0,66,14.285714],[0,77,99]]}
2020-05-16 11:40:56.112 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-16 11:40:56.116 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:56.120 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=1.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:56.125 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=29.370279 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-16 11:40:56.129 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=43.629587 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-16 11:40:56.134 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=14.285714 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-16 11:40:56.138 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=99.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-16 11:40:56.151 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#humidity updated with 43.6 % (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:56.158 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#lux updated with 14.3 lx (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:56.167 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#temperature updated with 29.4 °C (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:40:56.169 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 3 channels updated from CoIoT status
2020-05-16 11:41:11.124 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=43200): {"G":[[0,11,0],[0,22,1],[0,33,29.351208],[0,44,43.641599],[0,66,15.584416],[0,77,99]]}
2020-05-16 11:41:11.130 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Sensor data {"G":[[0,11,0],[0,22,1],[0,33,29.351208],[0,44,43.641599],[0,66,15.584416],[0,77,99]]}
2020-05-16 11:41:11.134 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 6 CoAP sensor updates received
2020-05-16 11:41:11.137 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[0]: id=11, Value=0.0 (Motion, Type=M, Range=0/1, Link=1: Sensors)
2020-05-16 11:41:11.142 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[1]: id=22, Value=1.0 (Charger, Type=S, Range=0/1, Link=1: Sensors)
2020-05-16 11:41:11.145 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[2]: id=33, Value=29.351208 (Temperature, Type=T, Range=-40/125, Link=1: Sensors)
2020-05-16 11:41:11.151 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[3]: id=44, Value=43.641599 (Humidity, Type=H, Range=0/100, Link=1: Sensors)
2020-05-16 11:41:11.154 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[4]: id=66, Value=15.584416 (Lux, Type=L, Range=0/1, Link=1: Sensors)
2020-05-16 11:41:11.160 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: Sensor value[5]: id=77, Value=99.0 (Battery, Type=B, Range=0/100, Link=1: Sensors)
2020-05-16 11:41:11.166 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#humidity updated with 43.6 % (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:41:11.173 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#lux updated with 15.6 lx (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:41:11.179 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellysense-4b3fa4: Channel sensors#temperature updated with 29.4 °C (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-05-16 11:41:11.182 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: 3 channels updated from CoIoT status
2020-05-16 11:41:26.145 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellysense-4b3fa4: CoIoT Message from /10.0.0.11:5683 (MID=43201): {"G":[[0,11,0],[0,22,1],[0,33,29.389350],[0,44,43.716678],[0,66,15.584416],[0,77,99]]}
