Ok the bad request is explained. Iâll download the jar file again and see what happens. Letâs hope I made a mistake this morning and thatâll work this time.
no, the bindinng doesnât use mqtt or the cloud connection
the local http api access is independent
you need to delete all things, clean out json db and also do a âopenhab-cli clear-cacheâ
if you have left overs you have a good chance that the channel linking/updates do not work correctly.
refer to the README, section âBefore installing this as an update:â
those mostly explains those strange side effects
I donât know how the binding can get access to the build timestamp. If seems to be possible, because the OH console displays that information, but so far I didnât find a way myself - maybe others could help. The firmware is printed to the low file and can be found in the thing properties. The binding checks for version 1.5+, otherwise youâll see a warning / recommendation to consider an update.
conclusion: RGBW2 should be fully working in color and white mode
@janser1 thanks in supporting us, thatâs excactly the feedback Iâm looking for
please also re-run the test with your relays and the roller (you did them with an old version)
@markus7017 - Test results will take some time as most of the devices are intended for my hometheater and itâll take some time to set everything up. The rolling shutters are for my projection screen and projector lift. The switches are for some lights and the RGBWâs are for mood/accent lights.
Iâm aiming for a one touch start and stop of the entire setup.
he he, I had longer discussion on @Igi on that
I will not drop the gain channel, because all of them can be controlled seperately wheres the color picker doesnât include all of them.
RGBW2? In color or in white mode?
Saturation slider of the color picker or the native brightness slider? (this one should work, did you checked the log?)
@janser1
As @markus7017 already wrote - gain is not brightness. Itâs a little bit confusing.
In the color picker object with the color, brightness and saturation sliders you sent the R/G/B values for your color. R/G/B values are converted from all three sliders and sent to the RGBW2 device.
The gain slider is a separate percent value to set intensity for color defined above.
Just wanting to chime in that the most recent alpha build is working great with a single Shelly1.
Iâve got a bunch on the shelf to install one day⌠And now Iâm not going to have to stare at mqtt, that day might be sooner.
I can see in the logs that Shelly Binding is also finding my âmilight-hubâ (an ESP board controlling lamps). Oh, and my synology NAS⌠Heh. These can be ignored?
This is also appearing in the logs :
âServiceInfo [ServiceInfoImpl@20 name: 'shelly1-4._http._tcp.local.â address: â(null):0â status: âDNS: JmDNS-/172.17.0.1 [/172.17.0.1] state: probing 1 task: nullâ, has NO data
shelly1-****._http._tcp.local.: ]â
please make sure to install the latest build from branch beta1-pre1.
Is that a Shelly device? No other devices are supported.
This discovery result doesnât include the IP address. This could happen, try to run multipe discoveries until you the the IP address, but again: only Shelly devices are supported.
