Hi, I set log trace and updated things.
2020-09-22 10:02:27.181 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:02:27.182 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:02:27.427 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-72},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:02","unixtime":1600768947,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302527}
2020-09-22 10:02:42.468 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:02:42.469 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:02:42.676 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-71},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:02","unixtime":1600768962,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302542}
2020-09-22 10:02:56.360 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: Updating status
2020-09-22 10:02:56.361 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP GET for http://192.168.0.190/status
2020-09-22 10:02:56.566 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Wurstsemmel","ip":"192.168.0.190","rssi":-78},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":233,"has_update":false,"mac":"98F4ABD11ECE","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"brightness":40,"white":30,"temp":3840}],"meters":[{"power":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-065050/v1.8.3@4a8bc427"},"ram_total":51176,"ram_free":36852,"fs_size":233681,"fs_free":161142,"uptime":13709}
2020-09-22 10:02:56.566 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP GET for http://192.168.0.190/status
2020-09-22 10:02:56.774 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Wurstsemmel","ip":"192.168.0.190","rssi":-78},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":233,"has_update":false,"mac":"98F4ABD11ECE","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"brightness":40,"white":30,"temp":3840}],"meters":[{"power":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-065050/v1.8.3@4a8bc427"},"ram_total":51176,"ram_free":36860,"fs_size":233681,"fs_free":161142,"uptime":13709}
2020-09-22 10:02:56.775 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: Updating light status in white mode, 1 channel(s)
2020-09-22 10:02:56.775 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: Colors loaded for lightId 0: power=OFF, RGBW=0/0/0/0, gain=0, brightness=40, color temp=3840 (min=2700, max=6500
2020-09-22 10:02:56.775 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: update white.color picker
2020-09-22 10:02:56.776 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: Updating 1 standard meter(s)
2020-09-22 10:02:56.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Shutting down
2020-09-22 10:02:56.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Shelly statusJob stopped
2020-09-22 10:02:56.944 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: Stopping CoAP Listener
2020-09-22 10:02:56.944 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: CoAP Request was canceled
2020-09-22 10:02:56.946 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Thing config updated, re-initialize
2020-09-22 10:02:58.953 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Using userId admin from bindingConfig
2020-09-22 10:02:58.954 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Device config: IP address=192.168.0.191, HTTP user/password=admin/***, update interval=60
2020-09-22 10:02:58.954 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Configured Events: Button: true, Switch (on/off): false, Push: true, Roller: true, Sensor: true, CoIoT: true, Enable AutoCoIoT: true
2020-09-22 10:02:58.955 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Start initializing thing Shelly ix3 (SHIX3-1), type shellyix3, ip address 192.168.0.191, CoIoT: true
2020-09-22 10:02:58.955 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/shelly
2020-09-22 10:02:59.001 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"type":"SHIX3-1","mac":"68C63AFA98B2","auth":true,"fw":"20200827-070910/v1.8.3@4a8bc427","longid":1,"num_inputs":3, "num_outputs":0}
2020-09-22 10:02:59.002 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/settings
2020-09-22 10:02:59.820 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"device":{"type":"SHIX3-1","mac":"68C63AFA98B2","hostname":"shellyix3-68C63AFA98B2","num_inputs":3, "num_outputs":0},"wifi_ap":{"enabled":false,"ssid":"shellyix3-68C63AFA98B2","key":""},"wifi_sta":{"enabled":true,"ssid":"Shellynetz","ipv4_method":"static","ip":"192.168.0.191","gw":null,"mask":"255.255.255.0","dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyix3-68C63AFA98B2","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"192.168.0.1","enabled":true},"login":{"enabled":true,"unprotected":false,"username":"admin"},"pin_code":"","name":"I3","fw":"20200827-070910/v1.8.3@4a8bc427","factory_reset_from_switch":true,"discoverable":true,"build_info":{"build_id":"20200827-070910/v1.8.3@4a8bc427","build_timestamp":"2020-08-27T07:09:10Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Berlin","lat":50.110901,"lng":8.682130,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"10:02","unixtime":1600768979,"led_status_disable":false,"actions":{"active":false,"names":["btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url","btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url","btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-04-21", "batch_id":1},"longpush_duration_ms":{"min":500, "max":3000},"multipush_time_between_pushes_ms":{"max":500},"inputs":[{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"http://admin:admin@192.168.0.190/light/0?turn=on","btn_off_url":"http://admin:admin@192.168.0.190/light/0?turn=off","shortpush_url":"http://admin:admin@192.168.0.190/light/0?turn=on&brightness=30&white=30","longpush_url":"http://admin:admin@192.168.0.190/light/0?turn=off","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""},{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"","btn_off_url":"","shortpush_url":"","longpush_url":"","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""},{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"","btn_off_url":"","shortpush_url":"","longpush_url":"","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""}]}
2020-09-22 10:02:59.821 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Initializing device shellyix3-68c63afa98b2, type SHIX3-1, Hardware: Rev: prod-2020-04-21, batch 1; Firmware: v1.8.3 / 20200827-070910 (4a8bc427)
2020-09-22 10:02:59.821 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Shelly settings info for shellyix3-68c63afa98b2: {"device":{"type":"SHIX3-1","mac":"68C63AFA98B2","hostname":"shellyix3-68C63AFA98B2","num_inputs":3, "num_outputs":0},"wifi_ap":{"enabled":false,"ssid":"shellyix3-68C63AFA98B2","key":""},"wifi_sta":{"enabled":true,"ssid":"Shellynetz","ipv4_method":"static","ip":"192.168.0.191","gw":null,"mask":"255.255.255.0","dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyix3-68C63AFA98B2","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"192.168.0.1","enabled":true},"login":{"enabled":true,"unprotected":false,"username":"admin"},"pin_code":"","name":"I3","fw":"20200827-070910/v1.8.3@4a8bc427","factory_reset_from_switch":true,"discoverable":true,"build_info":{"build_id":"20200827-070910/v1.8.3@4a8bc427","build_timestamp":"2020-08-27T07:09:10Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Berlin","lat":50.110901,"lng":8.682130,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"10:02","unixtime":1600768979,"led_status_disable":false,"actions":{"active":false,"names":["btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url","btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url","btn_on_url","btn_off_url","shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url","shortpush_longpush_url","longpush_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-04-21", "batch_id":1},"longpush_duration_ms":{"min":500, "max":3000},"multipush_time_between_pushes_ms":{"max":500},"inputs":[{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"http://admin:admin@192.168.0.190/light/0?turn=on","btn_off_url":"http://admin:admin@192.168.0.190/light/0?turn=off","shortpush_url":"http://admin:admin@192.168.0.190/light/0?turn=on&brightness=30&white=30","longpush_url":"http://admin:admin@192.168.0.190/light/0?turn=off","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""},{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"","btn_off_url":"","shortpush_url":"","longpush_url":"","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""},{"name":null,"btn_type":"momentary","btn_reverse":0,"btn_on_url":"","btn_off_url":"","shortpush_url":"","longpush_url":"","double_shortpush_url":"","triple_shortpush_url":"","shortpush_longpush_url":"","longpush_shortpush_url":""}]}
2020-09-22 10:02:59.822 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Device hasRelays:false (numRelays=0),isRoller:false (numRoller=0),isDimmer:false,numMeter=0,isEMeter:false),isSensor:false,isDS:false,hasBattery:false,isSense:false,isLight:false,isBulb:false,isDuo:false,isRGBW2:false,inColor:false,updatePeriod:70sec
2020-09-22 10:02:59.822 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:00.016 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-72},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:02","unixtime":1600768979,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39828,"fs_size":233681,"fs_free":150349,"uptime":302560}
2020-09-22 10:03:00.016 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Auto-CoIoT is enabled, disabling action urls
2020-09-22 10:03:00.016 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyix3-68c63afa98b2: Channel device#alarm updated with NONE (type class org.eclipse.smarthome.core.library.types.StringType).
2020-09-22 10:03:00.017 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Starting CoIoT (autoCoIoT=true/true)
2020-09-22 10:03:00.017 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: Starting CoAP Listener
2020-09-22 10:03:00.017 [ERROR] [.eclipse.californium.core.CoapClient] - could not set and start client endpoint
java.net.SocketException: Invalid argument
at java.net.PlainDatagramSocketImpl.join(Native Method) ~[?:1.8.0_265]
at java.net.AbstractPlainDatagramSocketImpl.join(AbstractPlainDatagramSocketImpl.java:178) ~[?:1.8.0_265]
at java.net.MulticastSocket.joinGroup(MulticastSocket.java:323) ~[?:1.8.0_265]
at org.eclipse.californium.elements.UdpMulticastConnector.start(UdpMulticastConnector.java:89) ~[?:?]
at org.eclipse.californium.core.network.CoapEndpoint.start(CoapEndpoint.java:506) ~[?:?]
at org.eclipse.californium.core.CoapClient.setEndpoint(CoapClient.java:356) ~[?:?]
at org.openhab.binding.shelly.internal.coap.ShellyCoapHandler.start(ShellyCoapHandler.java:118) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.initializeThing(ShellyBaseHandler.java:276) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.lambda$0(ShellyBaseHandler.java:158) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
2020-09-22 10:03:00.019 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Thing successfully initialized.
2020-09-22 10:03:00.019 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Update status job started, interval=20*3=60sec.
2020-09-22 10:03:00.037 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: CoIoT Message from /192.168.0.191:5683 (MID=38261): {"blk":[{"I":1,"D":"input_0"},{"I":2,"D":"input_1"},{"I":3,"D":"input_2"},{"I":4,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":4},{"I":2101,"T":"S","D":"input","R":"0/1","L":1},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":2201,"T":"S","D":"input","R":"0/1","L":2},{"I":2202,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":2},{"I":2203,"T":"EVC","D":"inputEventCnt","R":"U16","L":2},{"I":2301,"T":"S","D":"input","R":"0/1","L":3},{"I":2302,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":3},{"I":2303,"T":"EVC","D":"inputEventCnt","R":"U16","L":3}]}
2020-09-22 10:03:00.037 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Properties updated
2020-09-22 10:03:00.037 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: CoIoT Version 2 detected
2020-09-22 10:03:00.037 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: CoIoT Device Description for SHIX3-1#68C63AFA98B2#2: {"blk":[{"I":1,"D":"input_0"},{"I":2,"D":"input_1"},{"I":3,"D":"input_2"},{"I":4,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":4},{"I":2101,"T":"S","D":"input","R":"0/1","L":1},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":2201,"T":"S","D":"input","R":"0/1","L":2},{"I":2202,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":2},{"I":2203,"T":"EVC","D":"inputEventCnt","R":"U16","L":2},{"I":2301,"T":"S","D":"input","R":"0/1","L":3},{"I":2302,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS/SL/LS",""],"L":3},{"I":2303,"T":"EVC","D":"inputEventCnt","R":"U16","L":3}]}
2020-09-22 10:03:00.038 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id=1: input_0
2020-09-22 10:03:00.038 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id=2: input_1
2020-09-22 10:03:00.038 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id=3: input_2
2020-09-22 10:03:00.038 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id=4: device
2020-09-22 10:03:00.038 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Properties updated
2020-09-22 10:03:00.038 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: Adding 10 sensor definitions
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 9103: cfgChanged, Type=EVC, Range=U16, Links=4
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2101: input, Type=S, Range=0/1, Links=1
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS/SL/LS;, Links=1
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2201: input, Type=S, Range=0/1, Links=2
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2202: inputEvent, Type=EV, Range=S/L/SS/SSS/SL/LS;, Links=2
2020-09-22 10:03:00.039 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2203: inputEventCnt, Type=EVC, Range=U16, Links=2
2020-09-22 10:03:00.040 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2301: input, Type=S, Range=0/1, Links=3
2020-09-22 10:03:00.040 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2302: inputEvent, Type=EV, Range=S/L/SS/SSS/SL/LS;, Links=3
2020-09-22 10:03:00.040 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyix3-68c63afa98b2: id 2303: inputEventCnt, Type=EVC, Range=U16, Links=3
2020-09-22 10:03:02.029 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:03:02.030 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:02.239 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-72},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:03","unixtime":1600768982,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302562}
2020-09-22 10:03:02.240 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyix3-68c63afa98b2: Channel status1#lastEvent updated with S (type class org.eclipse.smarthome.core.library.types.StringType).
2020-09-22 10:03:02.240 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyix3-68c63afa98b2: Channel status1#eventCount updated with 214 (type class org.eclipse.smarthome.core.library.types.DecimalType).
2020-09-22 10:03:02.240 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: 3 more updates requested
2020-09-22 10:03:05.259 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:03:05.260 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:05.463 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-71},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:03","unixtime":1600768985,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302565}
2020-09-22 10:03:05.464 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: 2 more updates requested
2020-09-22 10:03:08.474 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:03:08.475 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:08.683 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-72},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:03","unixtime":1600768988,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302568}
2020-09-22 10:03:08.684 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: 1 more updates requested
2020-09-22 10:03:11.687 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:03:11.687 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:11.901 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-71},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:03","unixtime":1600768991,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302572}
2020-09-22 10:03:11.902 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: 0 more updates requested
2020-09-22 10:03:19.629 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: Thing config updated, re-initialize
2020-09-22 10:03:19.630 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellybulbduo-d11ece: Stopping CoAP Listener
2020-09-22 10:03:19.632 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellybulbduo-d11ece: CoAP Request was canceled
2020-09-22 10:03:20.887 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP GET for http://192.168.0.190/settings
2020-09-22 10:03:21.418 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP Response 200: {"device":{"type":"SHBDUO-1","mac":"98F4ABD11ECE","hostname":"ShellyBulbDuo-D11ECE","num_outputs":1},"wifi_ap":{"enabled":false,"ssid":"ShellyBulbDuo-D11ECE","key":""},"wifi_sta":{"enabled":true,"ssid":"Wurstsemmel","ipv4_method":"static","ip":"192.168.0.190","gw":null,"mask":"255.255.255.0","dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"ShellyBulbDuo-D11ECE","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"192.168.0.1 ","enabled":true},"login":{"enabled":true,"unprotected":false,"username":"admin"},"pin_code":"","name":"Treppenhaus_Lampe","fw":"20200827-065050/v1.8.3@4a8bc427","discoverable":true,"build_info":{"build_id":"20200827-065050/v1.8.3@4a8bc427","build_timestamp":"2020-08-27T06:50:50Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Berlin","lat":50.110901,"lng":8.682130,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"actions":{"active":false,"names":["out_on_url","out_off_url"]},"hwinfo":{"hw_revision":"prod-2019-12","batch_id":0},"mode":"white","transition":1000,"lights":[{"name":null,"ison":false,"brightness":40,"white":30,"temp":3840,"default_state":"last","auto_on":0.00,"auto_off":0.00,"schedule":false,"out_on_url":"","out_off_url":"","schedule_rules":[]}],"night_mode":{"enabled":false, "start_time":"00:00", "end_time":"00:00", "brightness":0}}
2020-09-22 10:03:21.419 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: Updating status
2020-09-22 10:03:21.419 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP GET for http://192.168.0.190/status
2020-09-22 10:03:21.628 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Wurstsemmel","ip":"192.168.0.190","rssi":-79},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":233,"has_update":false,"mac":"98F4ABD11ECE","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"brightness":40,"white":30,"temp":3840}],"meters":[{"power":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-065050/v1.8.3@4a8bc427"},"ram_total":51176,"ram_free":36856,"fs_size":233681,"fs_free":161142,"uptime":13734}
2020-09-22 10:03:21.629 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP GET for http://192.168.0.190/status
2020-09-22 10:03:21.836 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellybulbduo-d11ece: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Wurstsemmel","ip":"192.168.0.190","rssi":-79},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":233,"has_update":false,"mac":"98F4ABD11ECE","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"brightness":40,"white":30,"temp":3840}],"meters":[{"power":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-065050/v1.8.3@4a8bc427"},"ram_total":51176,"ram_free":36868,"fs_size":233681,"fs_free":161142,"uptime":13734}
2020-09-22 10:03:21.837 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: Updating light status in white mode, 1 channel(s)
2020-09-22 10:03:21.837 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: Colors loaded for lightId 0: power=OFF, RGBW=0/0/0/0, gain=0, brightness=40, color temp=3840 (min=2700, max=6500
2020-09-22 10:03:21.837 [TRACE] [.internal.handler.ShellyLightHandler] - shellybulbduo-d11ece: update white.color picker
2020-09-22 10:03:21.838 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: Updating 1 standard meter(s)
2020-09-22 10:03:21.838 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellybulbduo-d11ece: 0 more updates requested
2020-09-22 10:03:32.938 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyix3-68c63afa98b2: Updating status
2020-09-22 10:03:32.938 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP GET for http://192.168.0.191/status
2020-09-22 10:03:33.145 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyix3-68c63afa98b2: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Shellynetz","ip":"192.168.0.191","rssi":-71},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"10:03","unixtime":1600769012,"serial":510,"has_update":false,"mac":"68C63AFA98B2","cfg_changed_cnt":20,"actions_stats":{"skipped":0},"inputs":[{"input":0,"event":"S","event_cnt":214},{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20200827-070910/v1.8.3@4a8bc427"},"ram_total":51376,"ram_free":39824,"fs_size":233681,"fs_free":150349,"uptime":302593}
I see “stopping coAP listener”
Edit:
I have tradfri binding installed. Should I put the 2 other jarfiles into the addon folder?
