Shelly Binding
Now I have disabled CoIoT everywhere and it works.
For what is CoIoT good for?
When I aktivate CoIoT in the binding my Shelly 2.5 Roller is allways sendind :
Blockquote
2020-10-28 16:02:47.506 [vent.ItemStateChangedEvent] - Rollershutter_Terrasse changed from 100.0 to 0.0
2020-10-28 16:03:00.063 [vent.ItemStateChangedEvent] - Rollershutter_Terrasse changed from 0.0 to 100.0
2020-10-28 16:03:03.056 [vent.ItemStateChangedEvent] - Rollershutter_Terrasse changed from 100.0 to 0.0
2020-10-28 16:03:45.065 [vent.ItemStateChangedEvent] - Rollershutter_Terrasse changed from 0.0 to 100.0
The device needs to be online while you want to add it to your OH setup. If already added delete the device. Press the button to wakeup the device, run OH discovery, add the thing. This automatically initializes the device and also the CoAP listener. The device will then send a CoAP event if something happens and a status update every 12h. CoAP has the big advantage that the updates are near-realtime and it’s less battery consuming compared to http.
please open an issue on GitHub with prefix [shelly]
please create a bug on GitHub with the prefix [shelly]
nevertheless: make sure that only 1 instance of the binding is loaded (bundle:list on the OH console). I remember this problem and should be fixed, but if still see it…
I checked the console:
openhab> bundle:list | grep Shelly
228 x Active x 80 x 2.5.10 x openHAB Add-ons :: Bundles :: Shelly Binding
So I think only one instance is running.
Did you installed the version from PaperUI or the DEV build?
I installed it from PaperUI.
Hi, I have the same problem with Shelly3em. Independant from Interval setting and AutoCoIoT there are every second a new messurement in the logfile. Did you found solution for the logging interval?
OH has an integrated feature to filter the event log, see the discussion here 1
The configuration is added as a new section to openhab2-userdata/etc/org.ops4j.pax.logging.cfg
Based on this you could use the following config:
# custom filtering rules
log4j2.appender.event.filter.uselessevents.type = RegexFilter
log4j2.appender.event.filter.uselessevents.regex = .*(heartBeat|LastUpdate|lastUpdate|LetzteAktualisierung|Uptime|Laufzeit|ZuletztGesehen).*
log4j2.appender.event.filter.uselessevents.onMatch = DENY
log4j2.appender.event.filter.uselessevents.onMisMatch = NEUTRAL
This filters events for items heartBeat, lastUpdate, LetzteAktualisierung, Uptime, Laufzeit, ZuletztGesehen. Replace those strings with the items you want to filter. Use a list of items to reduce logging.
Please note: Once events are filtered they are “lost”, you can’t find them later.
you need to use the DEV build
Latest DEV build: 2.5.10 - 3.0.0 - README - Installation - Firmware Index - Firmware Archive - API Doc
thy markus7017, but I do not want to exclude the events, I only want to reduce the events, like every two minutes. I want to setup a rule, which runs on everyChange, but only every two minutes.
Has someone an other idea, why the setting “Update Interval” in the Shelly3EM thing is not working?
In my setup, the update interval works with the 3EM, I get an update every 5 minutes like I configured. I’m not using any dev release.
that’s strange @wars . Which OH-Release, shelly firmware and shelly update interval you have; or have you acticated MQTT in shelly settings?
In the shelly thing properties, I found “devUpdatePeriod”, which could not be changed:
coapDeviceDescr {“blk”:[{“I”:1,“D”:“relay_0”},{“I”:2,“D”:“emeter_0”},{“I”:3,“D”:“emeter_1”},{“I”:4,“D”:“emeter_2”},{“I”:5,“D”:“device”}],“sen”:[{“I”:9103,“T”:“EVC”,“D”:“cfgChanged”,“R”:“U16”,“L”:5},{“I”:1101,“T”:“S”,“D”:“output”,“R”:“0/1”,“L”:1},{“I”:4105,“T”:“P”,“D”:“power”,“U”:“W”,“R”:[“0/31800”,“-1”],“L”:2},{“I”:4106,“T”:“E”,“D”:“energy”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:2},{“I”:4107,“T”:“E”,“D”:“energyReturned”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:2},{“I”:4108,“T”:“V”,“D”:“voltage”,“U”:“V”,“R”:[“0/265”,“-1”],“L”:2},{“I”:4109,“T”:“I”,“D”:“current”,“U”:“A”,“R”:[“0/120”,“-1”],“L”:2},{“I”:4110,“T”:“S”,“D”:“powerFactor”,“R”:[“0/1”,“-1”],“L”:2},{“I”:4205,“T”:“P”,“D”:“power”,“U”:“W”,“R”:[“0/31800”,“-1”],“L”:3},{“I”:4206,“T”:“E”,“D”:“energy”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:3},{“I”:4207,“T”:“E”,“D”:“energyReturned”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:3},{“I”:4208,“T”:“V”,“D”:“voltage”,“U”:“V”,“R”:[“0/265”,“-1”],“L”:3},{“I”:4209,“T”:“I”,“D”:“current”,“U”:“A”,“R”:[“0/120”,“-1”],“L”:3},{“I”:4210,“T”:“S”,“D”:“powerFactor”,“R”:[“0/1”,“-1”],“L”:3},{“I”:4305,“T”:“P”,“D”:“power”,“U”:“W”,“R”:[“0/31800”,“-1”],“L”:4},{“I”:4306,“T”:“E”,“D”:“energy”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:4},{“I”:4307,“T”:“E”,“D”:“energyReturned”,“U”:“Wh”,“R”:[“U32”,“-1”],“L”:4},{“I”:4308,“T”:“V”,“D”:“voltage”,“U”:“V”,“R”:[“0/265”,“-1”],“L”:4},{“I”:4309,“T”:“I”,“D”:“current”,“U”:“A”,“R”:[“0/120”,“-1”],“L”:4},{“I”:4310,“T”:“S”,“D”:“powerFactor”,“R”:[“0/1”,“-1”],“L”:4},{“I”:6102,“T”:“A”,“D”:“overpower”,“R”:[“0/1”,“-1”],“L”:1}]}
coapVersion 2
coiotAutoEnable true
coiotAutoRefresh true
deviceHwBatch 1
deviceHwRev prod-2020-1
deviceMode
deviceName Shelly3em
deviceType shellyem3
devUpdatePeriod 70
macAddress 40F52000EFE4
modelId SHEM-3
numberMeters 3
numberRelays 1
numberRollers 0
serviceName shellyem3-40f52000efe4
statsTimeoutErrors 4
statsTimeoutsRecovered 4
updateAvailable no
updateCurrentVersion 20200813-140420/v1.8.1@1b2a49be
updateNewVersion 20200813-140420/v1.8.1@1b2a49be
updateStatus idle
vendor Shelly
wifiNetwork keller
I found a solution. It seems, that “update interval” is only working, when CoIoT is disabled.
I thought I disabled CoIoT, but it automatically is activated, when in the shelly binding configuration the parameter “autoCoIoT” is on (what is the default).
Now I switched “autoCoIoT” (in binding config) and “CoIoT” (in thing config) to “off”. Now the “update interval” of 60 is working
In OH version 2.5.8 (openhabian on RP4), with the shelly binding version 2.5.8 installed via PaperUI, the newer things Shelly Button and Shelly Gas are not appearing in the list of things under Configuration/Bindings/Shelly Binding.
I uninstalled the binding and reinstalled, however, this did not correct.
Thanks in advance for any assistance
you need to install the latest version (yes it runs on 2.5.8) or upgrade OH 2.5.10
I have the Shelly UNI (https://shelly.cloud/products/shelly-uni-smart-home-automation-device/)
But it shows up as unsupported by the Shelly Binding, how can we make it work with the binding?
the UNI is currently not supported. I have it on my desk, but didn’t had the time so far to work on it, maybe within the next 2 weeks
Upgrading the binding to the dev version corrected the issue. Thanks!
@markus7017 did one of the newer releases or dev of the shelly binding has the config option “Local IP”?
I am curious if I could update to the Shelly binding included in openHAB 2.5.10 without loosing the config option “Local IP”.
I am still running you test binding.
