Hi
I have a balcony solar, so i want to mesaure the export to the grid with openhab so i can utilize all the solar power by trigering smart plugs and sync power consumption with solar.
The issue i have is that connecting Shelly Pro EM3 to Openhab 4 isn’t working as expected.
I installed Shelly binding, added the EM3 Pro to the OH4 with typing in fixed IP of the device and it apears to work, but it stops worrkin in no time at all, like when i turn off EM3 Pro it wont reconect to OH every time, the refresh is not reliable.
I have latest shelly 1.5.1 firmware and openHAB 4.3.2 Release Build.
It appears that either the Shelly API gives trouble or the Binding is not optimized for EM3 Pro yet.
It appears that shelly em3 pro reports reliably to mqtt broker i set up, paralel for testing, but that HTTP API or that interface that the OH uses it seems troublesome, i am unsure on what end the issue persists.
I am thinking of integrating over MQTT, or Modbus if the issue will have to be resolved by binding creator, that seems to be bussy on github with many issues open.
I also tested Shelly Plus S plug that seems to be working fine, so it apears to be EM3 pro related issue mainly.
I also would like to have somewhat active status to see active power in real time whe it changes or at least every 5s, i understand it doesn’t need to send all but heartbeat and active power seem necesarry for our use case.
I have my own meter that only pulls current of 3 phases every 2s and it works for alerting of supply overload.
Thats my current setup with diy EMONLIB meter but it lacks advanced power analisys, that shelly will bring.
Any recomendations on reliable integration appriciated.
Cheers
Matej
