apella12
(Bob Eckhoff)
April 28, 2024, 12:50pm
21
I don’t see anything odd in the Debug. It might have helped to have a few more seconds to get the poll after the command. I’m assuming the blinds did not go up?
Let’s try a debug while operating the device manually to see what the device is sending to the controller.
Also are the 2PM devices shutter controls? The ZW DB indicates they are binary switches. What are the TYPE:ID numbers of the 2PM and Shutter? Do you have any blinds control device that works for comparison?
I hope I’ll be able to help, but don’t have any blinds control, so have nothing locally to compare.
Edit: also post the XML file in the userdata/zwave folder (var/lib/openhab/zwave). We need to make sure the device is advertising its properties correctly
Good morning Bob
In the meantime, I tried removing the devices, resetting the controller, uninstalling the binding and reinstalling everything, but the result is the same: the “wave shutters” don’t move.
Nothing appears in the log when I manually operate the shutters.
Yes, correct, I have some wave 2PM that I use to turn on the lights and these work well, I have another wave shutter, but this one also has the same problem
<node>
<homeId>0xc0959e6a</homeId>
<nodeId>2</nodeId>
<version>4</version>
<manufacturer>0x460</manufacturer>
<deviceId>0x82</deviceId>
<deviceType>0x3</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
<endpoint>1</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Start/stop quick press [E1]</name>
<profile1>0x20</profile1>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Start/stop level change [E1]</name>
<profile2>0x2</profile2>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<name>On/off moving [E1]</name>
<profile2>0x3</profile2>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<name>On/off top bottom [E1]</name>
<profile2>0x4</profile2>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<name>Start/stop quick press [E2]</name>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>7</int>
<associationGroup>
<index>7</index>
<name>Set level [E2]</name>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_CLASS_B_MOTOR_CONTROL</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<versionSupported>2</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__APPLICATION__STATUS>
</COMMAND__CLASS__APPLICATION__STATUS>
</entry>
<entry>
<multiLevelSwitchCommandClass>
<version>3</version>
<versionSupported>4</versionSupported>
<switchTypePrimary>DOWN_UP</switchTypePrimary>
<switchTypeSecondary>UNDEFINED</switchTypeSecondary>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<COMMAND__CLASS__METER>
<versionSupported>6</versionSupported>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_KWh</meterScale>
<meterScale>E_W</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</COMMAND__CLASS__METER>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL>
<version>2</version>
<useDestEndpointAsSource>false</useDestEndpointAsSource>
<endpointsAreTheSameDeviceClass>false</endpointsAreTheSameDeviceClass>
</COMMAND__CLASS__MULTI__CHANNEL>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>0</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>50</value>
</entry>
<entry>
<int>71</int>
<index>71</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>72</int>
<index>72</index>
<size>2</size>
<value>150</value>
</entry>
<entry>
<int>73</int>
<index>73</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>76</int>
<index>76</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>78</int>
<index>78</index>
<size>1</size>
<value>2</value>
</entry>
<entry>
<int>80</int>
<index>80</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>85</int>
<index>85</index>
<size>1</size>
<value>30</value>
</entry>
<entry>
<int>91</int>
<index>91</index>
<size>2</size>
<value>12000</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>HEAT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmType>SYSTEM</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>1120</deviceManufacturer>
<deviceType>3</deviceType>
<deviceId>130</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>7</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.19</protocolVersion>
<applicationVersion>12.17</applicationVersion>
<hardwareVersion>3</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
<entry>
<int>1</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>1</endpointId>
<entry>
<endpoint reference="../../../.."/>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</entry>
<entry>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
<autoSubscribeGroups/>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
<maxGroups>5</maxGroups>
</entry>
<entry>
</entry>
</endPoint>
</entry>
<entry>
<int>2</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>2</endpointId>
<entry>
</entry>
<entry>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
<maxGroups>3</maxGroups>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>4</int>
</nodeNeighbors>
<lastReceived>2024-04-30 19:34:47.618 UTC</lastReceived>
</node>
apella12
(Bob Eckhoff)
May 1, 2024, 7:03pm
23
This is a little concerning. I wonder if the controller needs to be in Association group 2?
Have you tried using the blinds control channels on EP1 and EP2 instead of the EP0?
Lastly, using the console do you have any orphan links related to this node? openhab:links orphan list
Use openhab:links orphan purge
if needed.
Hi Bob
I followed your last advice but nothing…
However, I noticed that the STOP command from the rollershutter item is executed and the states are received (after lowering the polling time), and that the channel, although it is a rollershutter type, still supports commands from a dimmer item .
So I linked both items on the channel, with two simple rules I give the up and down commands from the rollershutter item:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: ZWave_Node_003_Wave_Shutter_ZWaveTM_shutter_tapparella_bagno_Blinds_Control
command: UP
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
itemName: ZWave_Node_003_Wave_Shutter_ZWaveTM_shutter_tapparella_bagno_Blinds_Position
command: "0"
type: core.ItemCommandAction
It is recommended to raise the polling period, which by default is set to 86400s and to raise the Command Poll Period so that the device detects the status once the movement is finished
For the moment it may be fine, waiting for the device to be fully supported
Levin1
(Levin)
June 4, 2024, 7:10pm
25
I updated to OH 4.1.3 but I don’t see the new/correct channels. Is the database change not merged to 4.1.3? Where can I find if the current database was merged to 4.1.3?
apella12
(Bob Eckhoff)
June 4, 2024, 9:47pm
26
In all likelihood the updated config is not in any 4.1.x version. The builds were switched to 4.2 snapshots in December 23. The latest Wave shutter update was May 31. You could follow the guide I posted on Feb 13 to get the XML out of the current snapshot and add it to your 4.1.3 binding.
But to answer your question you can look at the 4.1.x here
Levin1
(Levin)
June 9, 2024, 6:19pm
27
I tried to add the new XML using your mentioned guide.
Unfortunatelly I still don’t see the updated channels.
I went through all steps except of step 4 because I’m not on OH3.
Is there anything else that needs to be done to show the new channels? I also deleted and re-added the Thing.
apella12
(Bob Eckhoff)
June 9, 2024, 7:44pm
28
What jar did you modify? Where was it on your OH system?
Also you could try to uninstall the Zwave binding from the UI, and put the latest OH4.2 snapshot in the addons folder. It might work, but if it doesn’t, just delete it and readd the UI zwave binding. I forget the exact wording of the error, but you will need to use the karaf console to add feature:install openhab.transport.serial
It is a zwave dependency but was removed when you deleted the binding from the UI.
Levin1
(Levin)
June 10, 2024, 10:59am
29
I used the following command to copy the jar:
cp /var/lib/openhab/tmp/kar/openhab-addons-4.1.3/org/openhab/addons/bundles/org.openhab.binding.zwave/4.1.3/org.openhab.binding.zwave-4.1.3.jar /home/openhabian/jarmodify
apella12
(Bob Eckhoff)
June 10, 2024, 2:16pm
30
That looks ok.
Looking at the XML you pulled from the zwave main code to upgrade does it show blinds control channels and does the type:id match what your device is showing?
Levin1
(Levin)
June 10, 2024, 3:31pm
31
I already checked the xml regarding “blinds_control” in the channels.
What exactly do you mean by “what my device is showing”?
Maybe it’s about the xml file name? I was unsure about the naming. The XML shows thing-type id=“shelly_waveshutter_00_000” listed=“false” and my xml is named waveshutter_0_0.xml
apella12
(Bob Eckhoff)
June 10, 2024, 3:42pm
32
The type:ID is on the UI properties page in decimal and hex in the XML. The jar update should use the _0_0.xml name. If you used the other name get rid of the jar, pull another copy and update again.
Levin1
(Levin)
June 10, 2024, 5:44pm
33
In UI on the things code page I can see thingTypeUID: zwave:shelly_waveshutter_00_000. My xml is named waveshutter_0_0.xml
apella12
(Bob Eckhoff)
June 10, 2024, 6:04pm
34
If you did the jar update with waveshutter_0_0.xml & the jar file noted above it should have worked. How did you get the updated jar into OH? Did you do the update in the karaf or copy that file to addons (after uninstalling zwave from the UI)? In karaf does bundle:list -s
show one zwave?
Levin1
(Levin)
June 10, 2024, 6:52pm
35
I think I did exactly what is stated on your guide.
bundle:list shows “269 x Active x 80 x 4.1.3 x openHAB Add-ons :: Bundles :: ZWave Binding”
I did not uninstall the binding so far.
I used the following commands to update jar and binding
jar uf org.openhab.binding.zwave-4.1.3.jar ./OH-INF/thing/waveshutter/waveshutter_0_0.xml
On openhab-cli:
bundle:update 269 file:///home/openhabian/jarmodify/org.openhab.binding.zwave-4.1.3.jar
apella12
(Bob Eckhoff)
June 10, 2024, 6:57pm
36
the wave shutter is in the shelly folder?
Levin1
(Levin)
June 10, 2024, 6:59pm
37
I’m not sure which shelly folder you mean
Should the folder “waveshutter” be named “shelly”?
apella12
(Bob Eckhoff)
June 10, 2024, 7:00pm
38
.OH_INF/thing/shelly/waveshutter_0_0.xml ?
EDIT
yes
Levin1
(Levin)
June 10, 2024, 7:09pm
39
Ok, I did the Jar and binding update again and it worked. The channel showed correctly after i deleted and re-added the thing from inbox.
Thank you for your support. I don’t know why I didn’t name the folder “shelly”…
Levin1
(Levin)
June 10, 2024, 7:49pm
40
It seems I have the same issue as Davide_Carboni.
Rollershutter Item does nothing. Dimmer Item linked to blinds_control channel seems to react somehow, but it’s not like it should be. But I noticed that the rollershutter item receives state updates.
I have a fibaro roller shutter which is working well on the same shutter.
Is there any information I can provide for further analysis?
