Show Current Sun Position and Shadow of House (Generate SVG)
Super @vzorglub and @rotulet!
Thanks to both of you for the fast fix!
Kurt
Dumb question.
Do I need to do anything special to run the python scripts? If I put them in the scripts folder, is that sufficient or do they need to be executed?
See post #1
I’ve now got it running using your code, vzorglub and all looking good, except the actual graphics don’t update in HabPanel. Only if I delete the widget and add it again will it update to show the correct sun position.
I’m using this in the widget template:
<object data="/static/matrix-theme/shaddow.svg?{{itemValue('Sun_Elevation')}}" type="image/svg+xml"></object>
Logs show that Sun_Elevation and Sun_Azimuth are all updating every 300 seconds. Any ideas why it won’t update?
Are you sure that your svg file is saved in /html/matrix-theme ?
If yes, then I have no idea. Not good with html and web dev.
Yeah, it’s being created there each time. It looks great, just not changing. Mmm…
I just don’t understand why I’m not getting any circles around the image?
This is how it looks for me:
Which code are you using,
from what post number?
Sorry, I’m using the original code (on top/first post).
(I tried the astral version but it failed saying “astral.AstralError: Sun never reaches 6 degrees below the horizon, at this location”. Apparently I live too far north?) :wink:
Where do you live if I may ask?
In Norway, in the northern parts
Nice,
Now the original script uses persistence to draw the circles so the whole set-up needs to run for a full 24 hours from midnight to midnight before the persistence can pick up all the values needed to draw the circles.
Let it run for 48 hours and you should be good.
Ah! Thanks! :slightly_smiling_face:
@pmpkk Can you please share this widget that has energy cost, gas usage etc? It looks fantastic.
I got errors when i run the script:
File “/etc/openhab2/scripts/shaddow.py”, line 5, in
from myopenhab import openhab
File “/etc/openhab2/scripts/myopenhab.py”, line 3, in
import requests
ImportError: No module named requests
Anyone can help?
You need to download the myopenhab.py script and put it in the same folder as shaddow.py for your fisrt issue
For the second, you need to run:
pip install requests from the console
Hi Guys, really cool!!!
please find below orange version (with brighter sun during the day) and moon.
code here.
    import math
    import time
    from datetime import datetime, timedelta, date
    import sys
    from myopenhab import mapValues
    from myopenhab import getJSONValue
    WIDTH = 100
    HEIGHT = 100
    PRIMARY_COLOR = '#cc3300'
    LIGHT_COLOR = '#ff7b00'
    HOUSE_COLOR = '#3f3f3f'
    STROKE_WIDTH = '0.5'
    SUN_COLOR = '#ffff66'
    SUN_COLOR_OFF = '#808033'
    SUN_RADIUS = 5
    MOON_COLOR = '#afafaf'
    MOON_RADIUS = 4
    FILENAME = '/etc/openhab2/html/matrix-theme/shaddow.svg'
    # Shape of the house in a 100 by 100 units square
    SHAPE = [{'x': 32.7, 'y': 29.2}, \
    		{'x': 66.5, 'y': 34.6}, \
    		{'x': 65.1, 'y': 42.2}, \
    		{'x': 70.8, 'y': 42.9}, \
    		{'x': 66.5, 'y': 69.2}, \
    		{'x': 45.4, 'y': 65.9}, \
    		{'x': 45.7, 'y': 63.8}, \
    		{'x': 27.4, 'y': 61.0}]
    HOURS = 1
    DEGS = []
    class shaddow(object):
        Shaddow Object
        def __init__(self):
            self.debug = False
            self.oh = openhab()
            self.azimuth = float(self.oh.getState('LocalSun_Position_Azimuth'))
            self.elevation = float(self.oh.getState('LocalSun_Position_Elevation'))
            self.sr = self.oh.getState('LocalSun_Rise_Azimuth')
            self.ss = self.oh.getState('LocalSun_Set_Azimuth')
            self.sunrise_azimuth = float(self.sr) if self.sr != 'NULL' else 0
            self.sunset_azimuth = float(self.ss) if self.ss != 'NULL' else 0
            self.moon_azimuth = float(self.oh.getState('LocalMoon_Position_Azimuth'))
            self.moon_elevation = float(self.oh.getState('LocalMoon_Position_Elevation'))
            ts = time.time()
            utc_offset = (datetime.fromtimestamp(ts) - datetime.utcfromtimestamp(ts)).total_seconds()/3600
            for h in xrange(0,24,HOURS):
                t = datetime.combine(date.today(), datetime.min.time()) + timedelta(hours=-utc_offset+h-24)
           	    a = self.oh.getStateHistoryFromInflux('LocalSun_Position_Azimuth',t.strftime('%Y-%m-%dT%H:%M:%S') + 'Z')
           	    if (a == None): a = 0
           	    DEGS.extend([a])
        def generatePath(self,stroke,fill,points,attrs=None):
    		p = ''
    		p = p + '<path stroke="' + stroke + '" stroke-width="' + STROKE_WIDTH + '" fill="' + fill + '" '
    		if (attrs != None): p = p + ' ' + attrs + ' '
    		p = p + ' d="'
    		for point in points:
    			if (points.index(point) == 0):
    				p = p + 'M' + str(point['x']) + ' ' + str(point['y'])
    			else:
    				p = p + ' L' + str(point['x']) + ' ' + str(point['y'])
    		p = p + '" />'
    		return p
        def generateArc(self,dist,stroke,start,end,attrs=None):
    		p = ''
    		try:
    			angle = end-start
    			if (angle<0):
    				angle = 360 + angle
    			p = p + '<path d="M' + str(self.degreesToPoint(start,dist)['x']) + ' ' + str(self.degreesToPoint(start,dist)['y']) + ' '
    			p = p + 'A' + str(dist) + ' ' + str(dist) + ' 0 '
    			if (angle<180):
    				p = p + '0 1 '
    			else:
    				p = p + '1 1 '
    			p = p + str(self.degreesToPoint(end,dist)['x']) + ' ' + str(self.degreesToPoint(end,dist)['y']) + '"'
    			p = p + ' stroke="' + stroke + '"'
    			if (attrs != None):
    			else:
    				p = p + ' stroke-width="' + STROKE_WIDTH + '" fill="none" '
    			p = p + ' />'
    		except:
    			p = ''
    		return p
        def degreesToPoint(self,d,r):
    		coordinates = {'x': 0, 'y': 0}
    		cx = WIDTH / 2
    		cy = HEIGHT / 2
    		d2 = 180 - d
    		coordinates['x'] = cx + math.sin(math.radians(d2))*r
    		coordinates['y'] = cy + math.cos(math.radians(d2))*r
    		return coordinates
        def generateSVG(self):
    		realSun = self.degreesToPoint(self.azimuth, 10000)
    		if self.debug: print realSun
    		sun = self.degreesToPoint(self.azimuth, WIDTH / 2)
    		minPoint = -1
    		maxPoint = -1
    		i = 0
    		minAngle = 999
    		maxAngle = -999
    		for point in SHAPE:
    			#Angle of close light source
    			angle = -math.degrees(math.atan2(point['y']-sun['y'],point['x']-sun['x']))
    			#Angle of distant light source (e.g. sun)
    			angle = -math.degrees(math.atan2(point['y']-realSun['y'],point['x']-realSun['x']))
    			distance = math.sqrt(math.pow(sun['y']-point['y'],2) + math.pow(sun['x']-point['x'],2))
    			if (angle<minAngle):
    				minAngle = angle
    				minPoint = i
    			if (angle>maxAngle):
    				maxAngle = angle
    				maxPoint = i
    			point['angle'] = angle
    			point['distance'] = distance
    			if self.debug: print str(i).ljust(10),":", str(point['x']).ljust(10), str(point['y']).ljust(10), str(round(angle,7)).ljust(10), str(round(distance)).ljust(10)
    			i = i + 1
    		if self.debug:
    			print "Min Point = ",minPoint
    			print "Max Point = ",maxPoint
    			print ""
    		i = minPoint
    		k = 0
    		side1Distance = 0
    		side2Distance = 0
    		side1Done = False
    		side2Done = False
    		side1 = []
    		side2 = []
    		while True:
    			if (side1Done == False):
    				side1Distance = side1Distance + SHAPE[i]['distance']
    				if(i != minPoint and i != maxPoint): SHAPE[i]['side'] = 1
    				if (i == maxPoint): side1Done = True
    				side1.append( { 'x': SHAPE[i]['x'], 'y': SHAPE[i]['y'] } )
    			if (side1Done == True):
    				side2Distance = side2Distance + SHAPE[i]['distance']
    				if(i != minPoint and i != maxPoint): SHAPE[i]['side'] = 2
    				if (i == minPoint): side2Done = True
    				side2.append( { 'x': SHAPE[i]['x'], 'y': SHAPE[i]['y'] } )
    			i = i + 1
    			if( i > len(SHAPE)-1): i = 0
    			if (side1Done and side2Done): break
    			k = k + 1
    			if (k == 20): break
    		svg = '<?xml version="1.0" encoding="utf-8"?>'
    		svg = svg + '<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">'
    		svg = svg + '<svg version="1.1" id="Layer_1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" x="0px" y="0px" viewBox="-10 -10 120 120" xml:space="preserve">'
    		minPointShaddowX = SHAPE[minPoint]['x'] + WIDTH * math.cos(math.radians(minAngle))
    		minPointShaddowY = SHAPE[minPoint]['y'] - HEIGHT * math.sin(math.radians(minAngle))
    		maxPointShaddowX = SHAPE[maxPoint]['x'] + WIDTH * math.cos(math.radians(maxAngle))
    		maxPointShaddowY = SHAPE[maxPoint]['y'] - HEIGHT * math.sin(math.radians(maxAngle))
    		shaddow = [ {'x': maxPointShaddowX, 'y': maxPointShaddowY } ] + \
    				side2 + \
    				[ {'x': minPointShaddowX, 'y': minPointShaddowY } ]
    		svg = svg + '<defs><mask id="shaddowMask">'
    		svg = svg + '      <rect width="100%" height="100%" fill="black"/>'
    		svg = svg + '      <circle cx="' + str(WIDTH/2) + '" cy="' + str(HEIGHT/2) + '" r="' + str(WIDTH/2-1) + '" fill="white"/>'
    		svg = svg + '</mask></defs>'
    		svg = svg + self.generatePath('none',HOUSE_COLOR,SHAPE)
    		shaddow_svg = self.generatePath('none','black',shaddow,'mask="url(#shaddowMask)" fill-opacity="0.5"')
    		if (self.elevation>0):
    			svg = svg + self.generatePath(LIGHT_COLOR,'none',side1)
    		else:
    			svg = svg + self.generatePath(PRIMARY_COLOR,'none',side1)
    		if (self.elevation>0): svg = svg + shaddow_svg
    		svg = svg + self.generateArc(WIDTH/2,PRIMARY_COLOR,self.sunset_azimuth,self.sunrise_azimuth)
    		svg = svg + self.generateArc(WIDTH/2,LIGHT_COLOR,self.sunrise_azimuth,self.sunset_azimuth)
    		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(self.sunrise_azimuth,WIDTH/2-2), self.degreesToPoint(self.sunrise_azimuth,WIDTH/2+2)])
    		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(self.sunset_azimuth,WIDTH/2-2), self.degreesToPoint(self.sunset_azimuth,WIDTH/2+2)])
    		for i in range(0,len(DEGS)):
    			if (i == len(DEGS)-1):
    				j = 0
    			else:
    				j = i + 1
    			if (i % 2 == 0):
    				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,DEGS[i],DEGS[j],'stroke-width="3" fill="none" stroke-opacity="0.1"')
    			else:
    				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,DEGS[i],DEGS[j],'stroke-width="3" fill="none" stroke-opacity="0.3"')
    		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(DEGS[0],WIDTH/2+5), self.degreesToPoint(DEGS[0],WIDTH/2+11)])
    		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(DEGS[(len(DEGS))/2],WIDTH/2+5), self.degreesToPoint(DEGS[(len(DEGS))/2],WIDTH/2+11)])
    		# sun
    		#svg = svg + '<circle cx="' + str(sun['x']) + '" cy="' + str(sun['y']) + '" r="3" stroke="' + LIGHT_COLOR + '" stroke-width="' + STROKE_WIDTH + '" fill="' + LIGHT_COLOR + '" />'
    			sun_c = SUN_COLOR
    		else:
    			sun_c = SUN_COLOR_OFF
    		svg = svg + '<circle cx="' + str(sun['x']) + '" cy="' + str(sun['y']) + '" r="' + str(SUN_RADIUS) + '" stroke="none" stroke-width="0" fill="' + sun_c + '55" />'
    		svg = svg + '<circle cx="' + str(sun['x']) + '" cy="' + str(sun['y']) + '" r="' + str(SUN_RADIUS -1) + '" stroke="none" stroke-width="0" fill="' + sun_c + '99" />'
    		svg = svg + '<circle cx="' + str(sun['x']) + '" cy="' + str(sun['y']) + '" r="' + str(SUN_RADIUS -2) + '" stroke="' + sun_c + '" stroke-width="0" fill="' + sun_c + '" />'
    		# moon
    		moon = self.degreesToPoint(self.moon_azimuth, WIDTH / 2)
    		svg = svg + '<circle cx="' + str(moon['x']) + '" cy="' + str(moon['y']) + '" r="' + str(MOON_RADIUS -1) + '" stroke="' + MOON_COLOR + '" stroke-width="0" fill="' + MOON_COLOR + '" />'
    		svg = svg + '</svg>'
    		if self.debug: print svg
    		f = open(FILENAME, 'w')
    		f.write(svg)
    		f.close()
    def main():
        t1 = time.time()
        s = shaddow()
        args = sys.argv
        if(len(args) == 1):
            print '\033[91mNo parameters specified\033[0;0m'
        else:
            if(args[1] == "update"):
                s.generateSVG()
        t2 = time.time()
        print "Done in " + str(t2-t1) + " seconds"
    if __name__ == '__main__':
        main()
What do you mean by brighter sun during the day?
when the elevation of the sun is >0 then the color is switched to bright yellow. :slight_smile:
It does that already. I thought you implemented the sun getting brighter and dimmer in the course of the day.
