Show Current Sun Position and Shadow of House (Generate SVG)
Yeah, easter holiday makes it much harder to get time, for my home automation hobbies :smiley: But I have finally got around and tested your solution. Unfortunately there is no change though. I also tried to force reinstall the astral libraries. I can also confirm that OH2 has the right astro data, and astral is off by 2 hours.
It seems that whatever i put in the location parameters, there are no changes in the output data:
self.l = Location(('HOME', 'XXXX', LATITUDE, LONGITUDE, 'Europe/XXXXX', ALTITUDE))
So with your original location data, WATFORD and Europe/London, That should be 1 hour difference from Oslo. But no change if I use Oslo or London :confused:
Try that:
self.debug = False
		self.oh = openhab()
		self.astr = Astral()
		self.l = Location(('HOME', 'WATFORD', LATITUDE, LONGITUDE, 'Europe/London', ALTITUDE))
		self.sun = self.l.sun()
		ts = time.time()
                print(ts)
		ts = ts - (2 * 86400)
                print(ts)
		self.azimuth = float(self.astr.solar_azimuth(datetime.fromtimestamp(ts), LATITUDE, LONGITUDE))
		print(self.azimuth)
		self.elevation = float(self.astr.solar_elevation(datetime.fromtimestamp(ts), LATITUDE, LONGITUDE))
		print(self.elevation)
What does your log show?
Hi @vzorglub and @sjef86,
I’m also using Astral now and I also encountered the issue with the wrong timezone.
I found in the Astral documentation that you need to localize your timestamps by using pytz.
(see Astral v3.0 — Astral 3.0 documentation)
This is my init function:
    def __init__(self):
        self.debug = False
        timezone = pytz.timezone('Europe/Brussels')
        self.l = Location(('HOME', 'TOWN', LATITUDE, LONGITUDE, 'Europe/Brussels', ALTITUDE)) # The HOME and TOWN values are not important. Replace Europe/London with your local time string
        now = timezone.localize(datetime.now())
        self.azimuth = float(self.astr.solar_azimuth(now, LATITUDE, LONGITUDE))
        self.elevation = float(self.astr.solar_elevation(now, LATITUDE, LONGITUDE))
        self.sunrise_azimuth = float(self.astr.solar_azimuth(self.sun['sunrise'], LATITUDE, LONGITUDE))
        self.sunset_azimuth = float(self.astr.solar_azimuth(self.sun['sunset'], LATITUDE, LONGITUDE))
        for i in range(0,24):
            a = float(self.astr.solar_azimuth(timezone.localize(datetime.combine(date.today(), time(i))), LATITUDE, LONGITUDE))
            if (a == None): a = 0
            DEGS.append(float(a))
It is possible that you will need to import pytz and some parts of datetime (if not imported yet):
from datetime import datetime, date, time
import pytz
Maybe you also need to install pytz via pip.
By using the localize() the timestamp will be set to the correct timezone.
I compared the generated output and it matches the “old” method that uses OpenHAB data.
I hope this helps!
Greetings,
Frederic
Thanks @FredericMa
That would not have occured to me as I am in GMT…
@sjef86
Does that work?
Hi @vzorglub and @FredericMa,
I tried to replace my existing code with yours, Frederic. But now I get this error:
 python /etc/openhab2/scripts/shaddow.py
Traceback (most recent call last):
  File "/etc/openhab2/scripts/shaddow.py", line 37, in <module>
    class shaddow(object):
  File "/etc/openhab2/scripts/shaddow.py", line 46, in shaddow
    self.l = Location(('HOME', 'TOWN', LATITUDE, LONGITUDE, 'Europe/Oslo', ALTITUDE))
NameError: name 'self' is not defined
@sjef86, @FredericMa
Works for me! Thanks
But I had to make a few changes:
Import section:
from __future__ import print_function
import math
# import time
from datetime import datetime, timedelta, date, time
import sys
import pytz
from astral import Astral
from astral import Location
Init function
	def __init__(self):
		self.debug = False
		self.oh = openhab()
		timezone = pytz.timezone('Europe/London')
		for i in xrange(0,24,HOURS):
Main function (At the bottom)
	t1 = datetime.now()
	t2 = datetime.now()
Note that I have removed the print statements
Change 'Europe/London' with 'London/Olso' as required
Did you check that pytz was installed?
sudo pip install pytz
Did you add the statement import pytz at the top of the script?
Woeps, forgot those 2 indeed… I already got rid of the time import since I removed the duration calculation a while ago.
@sjef86 have you copied the exact code? Maybe something went wrong while copying and pasting?
@FredericMa
Hi there, thanks for you good find indeed!!
I copied the code manually, I don’t like copying and pasting because you don’t get inside the code and get to learn and understand it.
I got it to work after a few tries.
@sjef86
With python be very careful with trailing spaces at the end of lines and with your indents
Thanks again…
Thanks guys! I finally got it working here :slight_smile: having some indent problems after copy/paste. I added:
	t1 = datetime.now()
	t2 = datetime.now()
And now everything is working great!! :smiley:
Thanks once more
Br
Chris
diffToFasade was bedeuted das genau? Was muss ich eintragen ? Eine haus seite zeigt genau nach norden bei mir.
The whole code without persistence and timezone corrected
You will need the Astral library (pip install Astral) and the pytz library (sudo pip install pytz)
svg generated is in the shared html folder
import math
# import time
import sys
import pytz
from myopenhab import openhab
from myopenhab import mapValues
from myopenhab import getJSONValue
WIDTH = 100
HEIGHT = 100
PRIMARY_COLOR = '#1b3024'
LIGHT_COLOR = '#26bf75'
STROKE_WIDTH = '1'
FILENAME = '/etc/openhab2/html/shaddow.svg'
LATITUDE = XX.XXXXXX # Your Latitude
LONGITUDE = XX.XXXXX # Your Longitude
ALTITUDE = XXX # Your Altitude
# Shape of the house in a 100 by 100 units square
SHAPE = [{'x': 23.18, 'y': 19.35}, \
		{'x': 70.11, 'y': 15.53}, \
		{'x': 75.32, 'y': 52.49}, \
		{'x': 79.96, 'y': 52.38}, \
		{'x': 80.65, 'y': 65.59}, \
		{'x': 76.83, 'y': 66.05}, \
		{'x': 78.68, 'y': 77.64}, \
		{'x': 31.52, 'y': 82.16}, \
		{'x': 30.13, 'y': 73.24}, \
		{'x': 18.54, 'y': 74.63}, \
		{'x': 14.72, 'y': 46.70}, \
		{'x': 26.07, 'y': 44.61}]
HOURS = 1
DEGS = []
	Shaddow Object
	def __init__(self):
		self.debug = False
		self.oh = openhab()
		timezone = pytz.timezone('Europe/London') # Enter your time zone
		self.l = Location(('HOME', 'TOWN', LATITUDE, LONGITUDE, 'Europe/London', ALTITUDE))
		print(self.azimuth)
		for i in xrange(0, 24, HOURS):
			DEGS.extend([float(a)])
	def generatePath(self,stroke,fill,points,attrs=None):
		p = ''
		p = p + '<path stroke="' + stroke + '" stroke-width="' + STROKE_WIDTH + '" fill="' + fill + '" '
		if (attrs != None): p = p + ' ' + attrs + ' '
		p = p + ' d="'
		for point in points:
			if (points.index(point) == 0):
				p = p + 'M' + str(point['x']) + ' ' + str(point['y'])
			else:
				p = p + ' L' + str(point['x']) + ' ' + str(point['y'])
		p = p + '" />'
		return p
	def generateArc(self,dist,stroke,start,end,attrs=None):
		p = ''
		try:
			angle = end-start
			if (angle<0):
				angle = 360 + angle
			p = p + '<path d="M' + str(self.degreesToPoint(start,dist)['x']) + ' ' + str(self.degreesToPoint(start,dist)['y']) + ' '
			p = p + 'A' + str(dist) + ' ' + str(dist) + ' 0 '
			if (angle<180):
				p = p + '0 1 '
			else:
				p = p + '1 1 '
			p = p + str(self.degreesToPoint(end,dist)['x']) + ' ' + str(self.degreesToPoint(end,dist)['y']) + '"'
			p = p + ' stroke="' + stroke + '"'
			if (attrs != None):
			else:
				p = p + ' stroke-width="' + STROKE_WIDTH + '" fill="none" '
			p = p + ' />'
		except:
			p = ''
		return p
	def degreesToPoint(self,d,r):
		coordinates = {'x': 0, 'y': 0}
		cx = WIDTH / 2
		cy = HEIGHT / 2
		d2 = 180 - d
		coordinates['x'] = cx + math.sin(math.radians(d2))*r
		coordinates['y'] = cy + math.cos(math.radians(d2))*r
		return coordinates
	def generateSVG(self):
		realSun = self.degreesToPoint(self.azimuth, 10000)
		if self.debug:
			print(realSun)
		sun = self.degreesToPoint(self.azimuth, WIDTH / 2)
		minPoint = -1
		maxPoint = -1
		i = 0
		minAngle = 999
		maxAngle = -999
		for point in SHAPE:
			#Angle of close light source
			angle = -math.degrees(math.atan2(point['y']-sun['y'],point['x']-sun['x']))
			#Angle of distant light source (e.g. sun)
			angle = -math.degrees(math.atan2(point['y']-realSun['y'],point['x']-realSun['x']))
			distance = math.sqrt(math.pow(sun['y']-point['y'],2) + math.pow(sun['x']-point['x'],2))
			if (angle<minAngle):
				minAngle = angle
				minPoint = i
			if (angle>maxAngle):
				maxAngle = angle
				maxPoint = i
			point['angle'] = angle
			point['distance'] = distance
			if self.debug:
				print(str(i).ljust(10),":", str(point['x']).ljust(10), str(point['y']).ljust(10), str(round(angle,7)).ljust(10), str(round(distance)).ljust(10))
			i = i + 1
		if self.debug:
			print("Min Point = ",minPoint)
			print("Max Point = ",maxPoint)
			print("")
		i = minPoint
		k = 0
		side1Distance = 0
		side2Distance = 0
		side1Done = False
		side2Done = False
		side1 = []
		side2 = []
		while True:
			if (side1Done == False):
				side1Distance = side1Distance + SHAPE[i]['distance']
				if(i != minPoint and i != maxPoint): SHAPE[i]['side'] = 1
				if (i == maxPoint): side1Done = True
				side1.append( { 'x': SHAPE[i]['x'], 'y': SHAPE[i]['y'] } )
			if (side1Done == True):
				side2Distance = side2Distance + SHAPE[i]['distance']
				if(i != minPoint and i != maxPoint): SHAPE[i]['side'] = 2
				if (i == minPoint): side2Done = True
				side2.append( { 'x': SHAPE[i]['x'], 'y': SHAPE[i]['y'] } )
			i = i + 1
			if( i > len(SHAPE)-1): i = 0
			if (side1Done and side2Done): break
			k = k + 1
			if (k == 20): break
		svg = '<?xml version="1.0" encoding="utf-8"?>'
		svg = svg + '<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">'
		svg = svg + '<svg version="1.1" id="Layer_1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" x="0px" y="0px" viewBox="-10 -10 120 120" xml:space="preserve">'
		minPointShaddowX = SHAPE[minPoint]['x'] + WIDTH * math.cos(math.radians(minAngle))
		minPointShaddowY = SHAPE[minPoint]['y'] - HEIGHT * math.sin(math.radians(minAngle))
		maxPointShaddowX = SHAPE[maxPoint]['x'] + WIDTH * math.cos(math.radians(maxAngle))
		maxPointShaddowY = SHAPE[maxPoint]['y'] - HEIGHT * math.sin(math.radians(maxAngle))
		shaddow = [ {'x': maxPointShaddowX, 'y': maxPointShaddowY } ] + \
				side2 + \
				[ {'x': minPointShaddowX, 'y': minPointShaddowY } ]
		svg = svg + '<defs><mask id="shaddowMask">'
		svg = svg + '	  <rect width="100%" height="100%" fill="black"/>'
		svg = svg + '	  <circle cx="' + str(WIDTH/2) + '" cy="' + str(HEIGHT/2) + '" r="' + str(WIDTH/2-1) + '" fill="white"/>'
		svg = svg + '</mask></defs>'
		svg = svg + self.generatePath('none',PRIMARY_COLOR,SHAPE)
		shaddow_svg = self.generatePath('none','black',shaddow,'mask="url(#shaddowMask)" fill-opacity="0.5"')
		if (self.elevation>0):
			svg = svg + self.generatePath(LIGHT_COLOR,'none',side1)
		else:
			svg = svg + self.generatePath(PRIMARY_COLOR,'none',side1)
		if (self.elevation>0): svg = svg + shaddow_svg
		svg = svg + self.generateArc(WIDTH/2,PRIMARY_COLOR,self.sunset_azimuth,self.sunrise_azimuth)
		svg = svg + self.generateArc(WIDTH/2,LIGHT_COLOR,self.sunrise_azimuth,self.sunset_azimuth)
		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(self.sunrise_azimuth,WIDTH/2-2), self.degreesToPoint(self.sunrise_azimuth,WIDTH/2+2)])
		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(self.sunset_azimuth,WIDTH/2-2), self.degreesToPoint(self.sunset_azimuth,WIDTH/2+2)])
		for i in range(0,len(DEGS)):
			if (i == len(DEGS)-1):
				j = 0
			else:
				j = i + 1
			if (i % 2 == 0):
				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,DEGS[i],DEGS[j],'stroke-width="3" fill="none" stroke-opacity="0.2"')
			else:
				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,DEGS[i],DEGS[j],'stroke-width="3" fill="none"')
		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(DEGS[0],WIDTH/2+5), self.degreesToPoint(DEGS[0],WIDTH/2+11)])
		svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(DEGS[(len(DEGS))/2],WIDTH/2+5), self.degreesToPoint(DEGS[(len(DEGS))/2],WIDTH/2+11)])
		svg = svg + '<circle cx="' + str(sun['x']) + '" cy="' + str(sun['y']) + '" r="3" stroke="' + LIGHT_COLOR + '" stroke-width="' + STROKE_WIDTH + '" fill="' + LIGHT_COLOR + '" />'
		svg = svg + '</svg>'
		if self.debug:
			print(svg)
		f = open(FILENAME, 'w')
		f.write(svg)
		f.close()
def main():
	t1 = datetime.now()
	s = shaddow()
	args = sys.argv
	if(len(args) == 1):
		dummy = 0
		#print('\033[91mNo parameters specified\033[0;0m')
	else:
		if(args[1] == "update"):
			s.generateSVG()
	t2 = datetime.now()
	#print("Done in " + str(t2-t1) + " seconds")
if __name__ == '__main__':
	main()
I added the moon with an approx drawing of its phase. It needs the pylunar library (sudo pip install pylunar).
I also added a background color to have a better shadow view and beveled the sun drawing.
import math
# import time
import sys
import pytz
import pylunar
WIDTH = 100
HEIGHT = 100
BG_COLOR = '#555555'
SUN_COLOR = '#ffff66'
SUN_RADIUS = 5
MOON_COLOR = '#999999'
MOON_RADIUS = 3
STROKE_WIDTH = '1'
LATITUDE = XXX
LONGITUDE = XXX
ALTITUDE = XXX
SHAPE = [{'x': 14.00637, 'y': 26.779708}, \
		{'x': 25.393663, 'y': 51.717879}, \
		{'x': 31.542801, 'y': 49.098802}, \
		{'x': 48.62374, 'y': 86.79074}, \
		{'x': 58.530685, 'y': 82.008077}, \
		{'x': 63.313348, 'y': 91.231785}, \
		{'x': 88.479264, 'y': 79.161254}, \
		{'x': 76.978099, 'y': 53.3121}, \
		{'x': 73.266786, 'y': 54.804337}, \
		{'x': 69.74343, 'y': 48.223985}, \
		{'x': 65.992327, 'y': 49.584331}, \
		{'x': 48.698439, 'y': 11.044762}]
HOURS = 1
DEGS = []
class shadow(object):
	Shadow Object
	def __init__(self):
		self.debug = False
		self.oh = openhab()
		timezone = pytz.timezone('Europe/Paris') # Enter your time zone
		self.l = Location(('HOME', 'YOUR TOWN', LATITUDE, LONGITUDE, 'Europe/Paris', ALTITUDE))
		self.now = timezone.localize(datetime.now())
		self.sun_azimuth = float(self.astr.solar_azimuth(self.now, LATITUDE, LONGITUDE))
		print('Sun azimuth: ' + str(self.sun_azimuth))
		self.sun_elevation = float(self.astr.solar_elevation(self.now, LATITUDE, LONGITUDE))
		print('Sun elevation: ' + str(self.sun_elevation))
		self.moon_info = pylunar.MoonInfo(self.decdeg2dms(LATITUDE), self.decdeg2dms(LONGITUDE))
		self.moon_info.update(self.now)
		self.moon_azimuth = self.moon_info.azimuth()
		print('Moon azimuth: ' + str(self.moon_azimuth))
		self.moon_elevation = self.moon_info.altitude()
		print('Moon elevation: ' + str(self.moon_elevation))
		if (self.sun_elevation>0):
			self.elevation = self.sun_elevation
		else:
			self.elevation = self.moon_elevation
	def decdeg2dms(self,dd):
		negative = dd < 0
		dd = abs(dd)
		minutes,seconds = divmod(dd*3600,60)
		degrees,minutes = divmod(minutes,60)
		if negative:
			if degrees > 0:
				degrees = -degrees
			elif minutes > 0:
				minutes = -minutes
			else:
				seconds = -seconds
		return (degrees,minutes,seconds)
		p = ''
		p = p + ' d="'
			else:
		p = p + '" />'
		return p
	def generateArc(self,dist,stroke,fill,start,end,attrs=None):
		p = ''
		try:
			angle = end-start
			if (angle<0):
				angle = 360 + angle
			if (angle<180):
				p = p + '0 1 '
			else:
				p = p + '1 1 '
			if (fill != None):
				p = p + ' fill="' + fill + '" '
			else:
				p = p + ' fill="none" '
			if (attrs != None):
			else:
				p = p + ' stroke-width="' + STROKE_WIDTH + '"'
			p = p + ' />'
		except:
			p = ''
		return p
		cx = WIDTH / 2
		cy = HEIGHT / 2
		d2 = 180 - d
		return coordinates
		realSun_pos = self.degreesToPoint(self.sun_azimuth, 10000)
		if self.debug:
			print(realSun_pos)
		sun_pos = self.degreesToPoint(self.sun_azimuth, WIDTH / 2)
		moon_pos = self.degreesToPoint(self.moon_azimuth, WIDTH / 2)
		minPoint = -1
		maxPoint = -1
		i = 0
		minAngle = 999
		maxAngle = -999
		for point in SHAPE:
			angle = -math.degrees(math.atan2(point['y']-sun_pos['y'],point['x']-sun_pos['x']))
			#Angle of distant light source (e.g. sun_pos)
			angle = -math.degrees(math.atan2(point['y']-realSun_pos['y'],point['x']-realSun_pos['x']))
			distance = math.sqrt(math.pow(sun_pos['y']-point['y'],2) + math.pow(sun_pos['x']-point['x'],2))
				minAngle = angle
				minPoint = i
				maxAngle = angle
				maxPoint = i
			if self.debug:
			i = i + 1
		if self.debug:
			print("")
		i = minPoint
		k = 0
		side1Distance = 0
		side2Distance = 0
		side1Done = False
		side2Done = False
		side1 = []
		side2 = []
		while True:
			i = i + 1
			k = k + 1
			if (k == 20): break
                # background
		svg = svg + '<circle cx="' + str(WIDTH/2) + '" cy="' + str(HEIGHT/2) + '" r="' + str(WIDTH/2-1) + '" fill="' + BG_COLOR + '"/>'
		minPointShadowX = SHAPE[minPoint]['x'] + WIDTH * math.cos(math.radians(minAngle))
		minPointShadowY = SHAPE[minPoint]['y'] - HEIGHT * math.sin(math.radians(minAngle))
		maxPointShadowX = SHAPE[maxPoint]['x'] + WIDTH * math.cos(math.radians(maxAngle))
		maxPointShadowY = SHAPE[maxPoint]['y'] - HEIGHT * math.sin(math.radians(maxAngle))
		shadow = [ {'x': maxPointShadowX, 'y': maxPointShadowY } ] + \
				side2 + \
				[ {'x': minPointShadowX, 'y': minPointShadowY } ]
		svg = svg + '<defs><mask id="shadowMask">'
		shadow_svg = self.generatePath('none','black',shadow,'mask="url(#shadowMask)" fill-opacity="0.5"')
			svg = svg + self.generatePath(LIGHT_COLOR,'none',side2)
		else:
			svg = svg + self.generatePath(PRIMARY_COLOR,'none',side2)
		if (self.elevation>0): svg = svg + shadow_svg
		svg = svg + self.generateArc(WIDTH/2,PRIMARY_COLOR,'none',self.sunset_azimuth,self.sunrise_azimuth)
		svg = svg + self.generateArc(WIDTH/2,LIGHT_COLOR,'none',self.sunrise_azimuth,self.sunset_azimuth)
				j = 0
			else:
				j = i + 1
			if (i % 2 == 0):
				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,'none',DEGS[i],DEGS[j],'stroke-width="3" stroke-opacity="0.2"')
			else:
				svg = svg + self.generateArc(WIDTH/2+8,PRIMARY_COLOR,'none',DEGS[i],DEGS[j],'stroke-width="3" ')
		# moon drawing: compute left and right arcs
		phase = self.astr.moon_phase(self.now)
		if self.debug:
			print('phase: ' + str(phase))
		left_radius=MOON_RADIUS
		left_sweep=0
		right_radius=MOON_RADIUS
		right_sweep=0
		if (phase > 14):
			right_radius = MOON_RADIUS - (2.0*MOON_RADIUS* (1.0 - ((phase%14)*0.99 / 14.0)))
			if (right_radius < 0):
				right_radius = right_radius * -1.0
				right_sweep = 0
			else:
				right_sweep = 1
		if (phase < 14):
			left_radius = MOON_RADIUS - (2.0*MOON_RADIUS* (1.0 - ((phase%14)*0.99 / 14.0)))
			if (left_radius < 0):
				left_radius = left_radius * -1.0
				left_sweep = 1
		if (self.moon_elevation>0):
			svg = svg + '<path stroke="none" stroke-width="0" fill="' + MOON_COLOR \
			+ '" d="M ' + str(moon_pos['x']) + ' ' + str(moon_pos['y']-MOON_RADIUS) \
			+ ' A ' + str(left_radius) + ' ' + str(MOON_RADIUS) + ' 0 0 ' + str(left_sweep) + ' ' + str(moon_pos['x']) + ' ' + str(moon_pos['y']+MOON_RADIUS) \
			+ '   ' + str(right_radius) + ' ' + str(MOON_RADIUS) + ' 0 0 ' + str(right_sweep) + ' ' + str(moon_pos['x']) + ' ' + str(moon_pos['y']-MOON_RADIUS) + ' z" />'
		# sun drawing
			svg = svg + '<circle cx="' + str(sun_pos['x']) + '" cy="' + str(sun_pos['y']) + '" r="' + str(SUN_RADIUS) + '" stroke="none" stroke-width="0" fill="' + SUN_COLOR + '55" />'
			svg = svg + '<circle cx="' + str(sun_pos['x']) + '" cy="' + str(sun_pos['y']) + '" r="' + str(SUN_RADIUS -1) + '" stroke="none" stroke-width="0" fill="' + SUN_COLOR + '99" />'
			svg = svg + '<circle cx="' + str(sun_pos['x']) + '" cy="' + str(sun_pos['y']) + '" r="' + str(SUN_RADIUS -2) + '" stroke="' + SUN_COLOR + '" stroke-width="0" fill="' + SUN_COLOR + '" />'
		if self.debug:
			print(svg)
		f.write(svg)
		f.close()
def main():
	t1 = datetime.now()
	s = shadow()
	args = sys.argv
	if(len(args) == 1):
		dummy = 0
	else:
			s.generateSVG()
	t2 = datetime.now()
	main()
Thanks for the update-work!! Also to @vzorglub!
One question though: In the original script, the illuminated part of the house’s fassade would be highlighted in the SVG.
With your code and on my setup, the part where the shadow is cast on is actually highlighted (the part of the house not faced by the sun).
Is there a way to update/modify the script in order to have the side of the house, touched by sunlight being highlighted?
Kurt
Yes, there is a slight bug!!
Look for that bit and change the first one to side1
		else:
I inverted side1 and side2 in this condition as my svg output had the opposite side highlighted! With the correction purpose by @vzorglub I got the attached result. Any idea?
I had to tinker with your code to make it work as I wanted. I didn’t like your background, sorry!!
I use this snippet:
My test is sun_elevation because I don’t want an illuminated side for the moon!!
		if (self.sun_elevation > 0):
		else:
That works for me
Gotcha! This is linked to the clockwise/counter clockwise points in SHAPE used to draw the path! It must be in clockwise to work.
Yep, agree there, I drew mine clockwise. Well spotted young man
Yes, I understand! You can just set BG_COLOR to ‘none’ to cancel the background.
In my case I want to see the moon shadows :star_struck:!
I just commented out the line…
